Old 07-28-2009, 12:13 PM   #1
glasswave OP
Oddometer: 936
Motor Life for xr400 before rebiuld needed?
I am wonder how many km you can expect from an well cared for xr400 motor before it starts feeling like a rebuild is nesscessary? I know this is impossible to answer with any sort of real accuracy, but I am just hoping to get a basic idea.
I have about 25000 km now and was hoping I can expect 50,000 or perhaps even more.
glasswave is offline   Reply With Quote
Old 07-28-2009, 12:40 PM   #2
Purcell69
Mors ex Tenebris
Purcell69's Avatar
Location: Moving forward...at the speed of rust in mid-OK
Oddometer: 3,832
Since the XR400 motor is very similar to the XR600/XR650L in design, I would expect it to have a similar life expectancy. Being well cared for is the key to long life. I have read in other threads where stock XR650L's have gone 30,000+ miles without a top-end overhaul. I think if you keep up on the oil changes, there is no reason you should not get 50,000km out of the motor before needing rebuild. Basically, if it's not smoking due to burning oil getting past the rings, you have nothing to worry about.
-Joe
Purcell69 is offline   Reply With Quote
Old 07-28-2009, 05:42 PM   #3
XRider
Almost Lifelike
XRider's Avatar
Oddometer: 1,283
I would agree, if it's not consuming oil or making any terrible noises you're in the pink. It's very hard to quantify the life span of a dirt bike motor but regular oil changes, valve adjustments, and air filter cleanings will make sure you get the most from it.
XR650R Plated Supermoto
XR628R Plated and highly modified
CR500R Still rips after all these beers
RZ350L Kenny Roberts Special
BMW R1200GS Adv Kind of a space ship
XRider is offline   Reply With Quote
Old 07-28-2009, 05:56 PM   #4
oldturtle
Oddometer: 449
IMO the XR400 motor has the potential to out last the 650L primarily because of the efficient oil cooler on 400. I have seen top ends needing rebuild because of mud getting into spark plug hole during plug change on the trails. Other causes of engine wear are related to installation of hop up parts and motor running very hot or high compression with low octane gas. But keep motor stock and well maintained and it is tough to wear um out.
2004 Kaw KDX220
2004 Hon XR250R
2006 Suz DL1000
2009 Suz DR650
2011 Kaw 650Versys
oldturtle is offline   Reply With Quote
Old 07-28-2009, 07:36 PM   #5
Blakebird
r-u-n-n-o-f-t
Blakebird's Avatar
Oddometer: 16,660
I disagree. I've had all the big XR's from 400 up, including 650R.
The 650L is in a very mild state of tune compared to the 400R and 600R, or my '82 500R ...not that any of them are what you'd call radical. Cam timing, compression....the L is a relative softie.
My high compression 628 runs between 200-225f oil temps unless it's a smokin' hot day and I'm pushing it....then maybe 250f.
Yeah, and oil cooler would be nice, but it's not cooking the oil at all.
The 400R took me to Copper Canyon and back - and it's working when you're keeping any pace on pavement. I don't think the oil cooler can offset how much harder the motor is working in any given situation compared to it's bigger brothers.
(I've never changed a 4T plug on the trail)
IBA #11735 . 1968-present
Blakebird is offline   Reply With Quote
Times are GMT -7.   It's 03:08 AM.
