Old 06-30-2009, 08:19 PM   #1
Gypsyfrog OP
Xventure n00b
Gypsyfrog's Avatar
Oddometer: 64
Question 2001 F650GS Dakar stalls/cuts out
Went riding this weekend. Took a small fall/drop (fell on a hill turn - RT side) but up in seconds. Numerous runs and stops following and bike ran fine home with no problems. Was changing out my footpegs this afternoon and took it out to test and the bike stalled about 10 times. Couldn't keep it at idle w/o gas. It has only been sitting for a day.
Cleaned out air filter and air box. Spark plug is unfouled.
Thoughts?
"Gypsyfrog"
Carlsbad, Ca
01 F650GS Dakar
85 Baja Westfalia
http://nomadxventures.spaces.live.com/default.aspx
Gypsyfrog screwed with this post 06-30-2009 at 10:25 PM
Gypsyfrog is offline   Reply With Quote
Old 07-01-2009, 02:47 AM   #2
JDLuke
Ravening for delight
JDLuke's Avatar
Oddometer: 8,644
Not unprecedented, not by a long shot.
There's a really good chance that your bike will act normally again the next time you go to use it. If so, you're good to go, there was a temporary glitch. If not, there's a good chance that your computer is now confused and needs to be reset. You should also check that your battery is strong and properly filled. Fortunately, you can kill both birds with one stone by disconnecting the battery to service it.
When these bikes begin to stall like this, the first solution is to turn it off for a couple of minutes. That almost always takes care of things. Trying to shut down and restart immediately will generally give results like you had, where you need to keep just a bit of throttle on to keep the bike running.
Various people report different hypotheses as to why this happens, my favorite is unintentional jiggling of the throttle before/during the start sequence. Others suggest that it's because one did not wait for the temp light to go out before starting, which is considered by many to be the 'proper' sequence, although there is official denial that this is required.
Why did I drink all of the ingredients for vomit?
"Used to be Man vs. Nature.. then Man vs. Space.. then Man vs. the Moon. Now it's Man vs. Food" - Dalar
"you cannot reason a person out of something they were not reasoned into." - Jonathan Swift
JDLuke is offline   Reply With Quote
Old 07-01-2009, 06:17 AM   #3
Gypsyfrog OP
Xventure n00b
Gypsyfrog's Avatar
Oddometer: 64
Winner! Thanks JD. I guess the bike read your post before I did....
Interesting about the temp light...its not like its diesel w/glow plugs, but maybe it just needs to line up all its electons before its ready to play.
Thanks again.
Off to find a chain tensioner.
"Gypsyfrog"
Carlsbad, Ca
01 F650GS Dakar
85 Baja Westfalia
Old 07-01-2009, 06:34 AM   #4
DAKEZ
DAKEZ's Avatar
Oddometer: 19,747
I see you figured things out. Nice bike by the way. I took the checkered flag stuff off mine.
“Watch out for everything bigger than you, they have the "right of weight"
Bib
DAKEZ is offline   Reply With Quote
Old 07-01-2009, 06:47 AM   #5
Gypsyfrog OP
Xventure n00b
Gypsyfrog's Avatar
Oddometer: 64
Thanks mate. I like the white/black as well. Yours is what I was looking for when i was shopping. I do like just the flat black though and easy to touch up....for now. I drool when I see NB's or Farlkeface's bikes. Trying to get mine and my girls ready for WestFest 09 and still have money to buy drinks!
"Gypsyfrog"
Carlsbad, Ca
01 F650GS Dakar
85 Baja Westfalia
Old 07-01-2009, 12:27 PM   #6
Gravel Seeker
Thomas
Gravel Seeker's Avatar
Location: Dreary old Norway, dreaming of adventures past
Oddometer: 4,030
How was the weather from day 1 to day 2 ?
If, say it was wet and cold on day 1 the bike has adjusted itself to that. If day 2 was dry and hot it will not adjust to the new settings before riding a while. The mechanic at my local BMW dealer told me it usually takes 20-30kms before the it's adjusted itself.
'01 F650 Dakar - modified as best I can
2005: Australia - 8 months/ 26.000 km (anti clockwise circle)
2009: Norway - 2 weeks/ 6000 km (Lindesnes to North cape)
Gravel Seekers.com
Hey !
It's the African ant eater ritual !
Gravel Seeker is offline   Reply With Quote
Old 07-01-2009, 04:06 PM   #7
Gypsyfrog OP
Xventure n00b
Gypsyfrog's Avatar
Oddometer: 64
Southern California here GS....weather never changes. 60-70 and dry. Was worried a bit, but so far, so good.
"Gypsyfrog"
Carlsbad, Ca
01 F650GS Dakar
85 Baja Westfalia
Old 07-01-2009, 04:11 PM   #8
jdaniele
jdaniele's Avatar
Oddometer: 949
Next time give this a try. Turn key on wait for temp lamp to go out, twist throttle wide open and let go three times, turn off ignition.Wait 15 seconds turn on ignition wait for temp lamp to go out start bike give no throttle let idle till cooling fan cycles. This should reset the tps. never give throttle or strart bike before temp lamp goes out.
It works for me.
JD (K2ADV)
"These pretzels are makin me thirsty"
I can't seem to remember why I don't drink anymore.
jdaniele is offline   Reply With Quote
Old 07-03-2009, 07:39 AM   #9
Gypsyfrog OP
Xventure n00b
Gypsyfrog's Avatar
Oddometer: 64
[quote=jdaniele]Next time give this a try. Turn key on wait for temp lamp to go out, twist throttle wide open and let go three times, turn off ignition.Wait 15 seconds turn on ignition wait for temp lamp to go out start bike give no throttle let idle till cooling fan cycles. This should reset the tps. never give throttle or strart bike before temp lamp goes out.
It works for me.
Thanks. BTW, how are those TRAXX boxes working out for you? Taken any falls w/them?
"Gypsyfrog"
Carlsbad, Ca
01 F650GS Dakar
85 Baja Westfalia
Old 07-03-2009, 08:30 AM   #10
jdaniele
jdaniele's Avatar
Oddometer: 949
I like the cases so far so good. Fortunatly the bike has stayed upright so no answer on durability in that sense.
JD (K2ADV)
Old 07-03-2009, 10:59 AM   #11
Gravel Seeker
Thomas
Oddometer: 4,030
yeah........did I mention I fucken hate winter ?!!!
Gravel Seekers.com
Hey !
Old 07-14-2009, 11:17 AM   #12
JaxObsessed
Rhonda be strong.
JaxObsessed's Avatar
Location: From Alabama to Newfoundland it's all Appalachian
Oddometer: 15,141
check this thread
http://www.advrider.com/forums/showthread.php?t=453740
I figure Earthromer has the right idea.
Best of luck.
ClownBoss: We aren't going any where. We are here with you, Rhonda, Dan and Bethany 110%.
JaxObsessed is offline   Reply With Quote
Old 07-28-2009, 07:12 PM   #13
Gypsyfrog OP
Xventure n00b
Gypsyfrog's Avatar
Oddometer: 64
Bike never repeated once I waited for engine/temp lights to go off...go figure!
Thanks all for the help!
"Gypsyfrog"
Carlsbad, Ca
01 F650GS Dakar
85 Baja Westfalia
Times are GMT -7.   It's 12:45 PM.
