01-23-2010, 03:56 AM
#1486 | |
Thomas
Location: Dreary old Norway, dreaming of adventures past
Oddometer: 3,390
'01 F650 Dakar - modified as best I can 2005: Australia - 8 months/ 26.000 km (anti clockwise circle) 2009: Norway - 2 weeks/ 6000 km (Lindesnes to North cape) Gravel Seekers.com Hey ! It's the African ant eater ritual ! |
01-23-2010, 04:03 AM
#1487 | |
Thomas
Oddometer: 3,390
Anyone ever considered putting an 800 Rotax snowmobile engine in our frame ? I don't even know if it'll fit ![]() .
01-23-2010, 04:17 AM
#1488 |
Thomas
Oddometer: 3,390
My Touratech IMO needs a new battery. It has needed one for quite some time actually and was pretty much useless this past season. Reason why I hven't just replaced the battery is because it burried in the bottom of the unit underneth the printcard and everthing's solered in place. To top it off they've (from what I hear) used a specially made battery (Thanks for being customer oriented Touratech......)
Since I've used the IMO for many years, like its features (it has afterall 13 pages with different info on it) and have the remote control for it installed I've opted to go for the battery replacement. The whole IMO unit has to be shipped to Germany to have the battery replaced and the total cost is about the same as a Trailtech Vapor. Anywho, last night I moved about 70 pallets of wood in our warehouse to get my bike out from where it's being stored for the winter. I thought perhaps some of you would be interested to see what the front of the bike looks like when stripped down so I took some pics with my phone (crappy quality, sorry) ![]() ![]() ![]() ![]() ![]()
01-23-2010, 08:39 AM
#1489 | |
Walking the plank
Oddometer: 1,152
"but why is all the rum gone?" ![]() 2008 YAMAHA FJR |
01-23-2010, 08:51 AM
#1490 | |
Thomas
Oddometer: 3,390
I've never had a leak from the oil filter o-ring, sump plug crush washer or the oiltank crush washer. I did change the parts in the beginning, but haven't the last few years. Will probably change them next time though as they are getting a bit worn, but I don't see the point in changing them every time (unless they're damaged ofcourse)..... if I can get the damn sump plug off...... tis a bit round you see....
01-23-2010, 09:00 AM
#1491 |
Unsafe at any speed
Oddometer: 963
I always use a mityvac fluid evacuator so I don't have to pull the plastic, or the drain plug...
_________________________ http://bswartz.net 2006 BMW R1200GS 2010 KTM 690 ENDURO R 1969 BSA STARFIRE |
01-23-2010, 09:15 AM
#1492 | |
Walking the plank
Oddometer: 1,152
01-23-2010, 09:36 AM
#1493 | |
Oddometer: 450
Does that thing show you clearly how much you sucked out?
01-23-2010, 10:14 AM
#1494 |
Unsafe at any speed
Oddometer: 963
It does not have volume marks on it, like a "graduated cylinder" if that is what you mean...
You hook an air hose to it, and it uses a venturi to create a strong vacuum, it makes short work of bleeding brakes, changing oil, antifreeze, ETC...
01-23-2010, 01:11 PM
#1495 | |
Walking the plank
Oddometer: 1,152
I don't know if that would have drained out had I been pulling the drain plug each time or not but I only used the pump every other time to make sure I was doing the best I could to get a complete oil change - as best as possible. I replaced the engine a few years later and pulled the oil pan to see if there was any buildup again and only a small spot of grit this time around. Perhaps the suction just won't pull the dirt as easy as the oil and it can be left behind. Not saying it isn't a great method but just and observation from my previous experience.
01-23-2010, 01:29 PM
#1496 |
Unsafe at any speed
Oddometer: 963
Not sure what you used that was similar.....
This thing will suck sludge, and metal particles.... I use it daily in my repair shop. It has an assortment of tubes... Including small tubes that will fit down the dipstick tube, and pull the oil from a V8.. I have used it to get chunks of rust that are on the bottom of old gas tanks.. You start the engine first so all the crap is in suspension... Then work the tube around the bottom like vacuuming a swimming pool (this is doable on the F650 but not on a V8 where you are sliding down a dipstick tube.), and the oil tank will be drier then using the drain plug.
01-23-2010, 01:37 PM
#1497 | |
Walking the plank
Oddometer: 1,152
01-23-2010, 01:52 PM
#1498 |
Unsafe at any speed
Oddometer: 963
I have 150-170 psi at the shop... When bleeding a brake system with the thing I have to continually pour brake fluid as it pulls the fluid through the master cylinder about as fast as you pour... Takes about 10 seconds to bleed even the hardest to bleed motorcycle systems. You can empty an automatic transmission in about 2 minutes... no mess when you drop the pan to change automatic transmission filters on a car...
01-23-2010, 04:32 PM
#1499 |
Stuck in Pindadesh
Oddometer: 2,045
I got one of these at Sears for $40. Makes short work of it. Here I'm dumping the used fluid into a tub but you connect a graduated container to the outlet.
Jim 06 F650GS I wanna ride |
01-23-2010, 05:30 PM
#1500 |
Oddometer: 2,282
You can make one of those yourself, but using a jar. Drill out a hole the size of your vacuum cleaner nozzle and a hole next to it for the bleed tube. I have one with a one way valve. Sucks it all out for ya.
