01-26-2010, 04:56 PM
#1516 | |
Oddometer: 543
01-26-2010, 05:41 PM
#1517 | |
Oddometer: 371
01-26-2010, 07:17 PM
#1518 | |
KIWIINUSA
Dang it work !! Thanks Mate.
88 R100GS 75 Norton Commando Roadster 98 DR450 07 Sherco 450 called BLING. 07 Sherco 510 called Holy Shit . |
01-27-2010, 08:14 PM
#1519 | |
If the noob fits....
Oddometer: 8
01-27-2010, 08:19 PM
#1520 | |
Oddometer: 40
01-27-2010, 08:36 PM
#1521 | |
KIWIINUSA
All i did was to disconnect the battery then plug in my GPS to the accessory port to drain any charge , reconnected the battery and everything reset to perfect running order.
01-27-2010, 09:23 PM
#1522 | |
Oddometer: 8
01-28-2010, 05:35 AM
#1523 | |
Oddometer: 450
01-28-2010, 07:20 AM
#1524 |
Oddometer: 3,205
Anyone have a good idea of aftermarket windshield that fits a 2005 and newer 4 bolt that is more upright like the 3 bolt shields the older Dakar's had?
I got the factory shield but on full left lock the brake master cyclinder hits the shield. Any one trim the factory shield and get good results? John
www.throttlemeister.net |
01-28-2010, 07:40 AM
#1525 | |
Ravening for delight
Oddometer: 8,645
Why did I drink all of the ingredients for vomit? "Used to be Man vs. Nature.. then Man vs. Space.. then Man vs. the Moon. Now it's Man vs. Food" - Dalar "you cannot reason a person out of something they were not reasoned into." - Jonathan Swift |
01-28-2010, 08:02 AM
#1526 | |
Oddometer: 3,205
I might just have to get the saw out
01-28-2010, 09:34 AM
#1527 |
Wildest place I've been
Oddometer: 151
[quote=Throttlemeister]I would perfer to have a more upright shield like I've seen on the earlier Dakars that would be totally out of the way but have not found any of the 4 bolt style yet. /quote]
Wind pressure at highway speeds is an issue with 2005-'07 Dakars. After you solve the clearance problem (I like JDLuke's idea), if you want more upright for your windscreen consider adding a Laminar Lip to your OEM screen. You can install it so it only adds two or three inches to the top of the OEM screen, it deflects wind up and over you a lot better, plus it's removeable for off-road days, so you get Best of both. I like mine a lot.
Butch to gambler: "What would you think of maybe asking us to stick around? You don't have to mean it or anything." |
01-28-2010, 12:25 PM
#1528 |
Ancient FighterPilot
Oddometer: 68
more upright windscreen
I got longer bolts to replace the upper two, then added thin rubber washers below and much thicker rubber under the upper wind screen holes. I got the idea from f650.com and it has worked very well for me.
01-28-2010, 12:38 PM
#1529 |
Oddometer: 3,205
I don't mind where the wind hits me now with the factory screen. This bike compared to what I normally ride has very little/no wind protection at all anyhow. Rotating the bars in the clamp didn't do enough to solve the clearence issues but helped some.
I'll probably just notch it out a little to clear the master cylinder or find the elusive small upright shield if it even exists. Only hits at extreme left turn anyway. Thanks for the replies guys
01-28-2010, 07:10 PM
#1530 | |
Domain Ranger
Oddometer: 3,312
.Typically, I'll put in 2 quarts, go for a ride, and my level is just below dead center of the glass...still in range and I don't have to open another quart. But 2.1 after an oil/filter change gets it right at perfect
