05-18-2010, 06:18 AM
#2296 |
Oddometer: 313
Hi all,
I have a number of flexible oil return lines available for the F650GS and Dakar. These will make removing the clutch cover a doddle when you come to do the waterpump replacement. As I write 5 have been sold so 5 more left Price is £50 posted recorded delivery in the UK. Can post anywhere if you cover the extra costs of shipping which should not be too great as the pipe is light and can be sent as small packet. PM me if you want one. George ![]() ![]()
05-18-2010, 08:21 AM
#2297 |
Rally Driver
Oddometer: 681
Can anyone direct me towards a plug and play tunr signal flasher that is compatible with LED turn signals. I have heard rumors of a car flasher that works but can't find a part number. Thanks.
Matt Smith www.fireantracing.com '02 F650GS Dakar (why do I continue to ride a 400lb bike like an enduro bike?) ![]() Proud to be RIFF RAFF 2011
05-18-2010, 09:09 AM
#2298 | |
TWECO
Oddometer: 939
1976 R60/6, 2009 530 EXC, 2008 250 XC, 2004 950 ADV if the ocean were whiskey and I were a duck - I'd swim to the bottom and never come up |
05-18-2010, 09:19 AM
#2299 | |
KOTW is a myth!
Location: Hey, I can see my colon from here...............
Oddometer: 6,396
As a final point, the thing that people call an "airbox" is actually labeled as a "sound" box on BMW tech drawings. This box is so unimportant to the bike's performance and gas mileage that I no longer have any part of the stock air system on my bike. I have replaced it with a much smaller unit that still maintains the K&N stainless race filter that has allowed me to replace the stock BMW faux tank cowling with a much smaller one that has allowed me to put a Desert rally style seat on my bike. In this photo you can see just how narrow my body work is now and the nice seat that I have been able to mount. Notice that other than the intake area, my body panels do not protrude outside of the frame. This body work is a full 6" narrower and 3.5" lower than the stock parts.
Riding And Camping Event: 2010 www.kingsofthewestrally.com Club KotW: THE REMIX 2011 http://www.advrider.com/forums/showthread.php?t=629979 CLOWNS OF THE WEST: http://www.advrider.com/forums/showthread.php?t=629965 KotW Regional Thread: http://www.advrider.com/forums/showt...35024&page=136 KotW Ride Report thread: http://www.advrider.com/forums/showthread.php?t=626346 notmybikemodelname screwed with this post 05-18-2010 at 09:49 AM |
05-18-2010, 11:27 AM
#2300 | |
Thomas
Location: Dreary old Norway, dreaming of adventures past
Oddometer: 3,390
'01 F650 Dakar - modified as best I can 2005: Australia - 8 months/ 26.000 km (anti clockwise circle) 2009: Norway - 2 weeks/ 6000 km (Lindesnes to North cape) Gravel Seekers.com Hey ! It's the African ant eater ritual ! |
05-18-2010, 11:30 AM
#2301 | |
Thomas
Oddometer: 3,390
Has it been leaking from the weep hole ?
05-18-2010, 11:39 AM
#2302 | |
Thomas
Oddometer: 3,390
I was very tempted to to put a cone airfilter directly on top of the throttlebody, but decided against it Rob, - Have you made/ moved your oil tank ? - What's that handbag hanging down toward the radiator ? Is there another one on the other side ? Even more fueltanks ?
05-18-2010, 12:11 PM
#2303 |
Physycotic gecko
Oddometer: 1,313
Gsxr exhaust
Seeing as the scorpion exhaust has again decided to eat the baffle material i've had to put the stock exhaust on
Btw thats the second time in 6 months, i'm getting sick of sending the damn thing back to scorpion for a repack.Decided against putting the scorpion back on as it's going to keep fucking up, then i stumbled upon the dr650 thread, where most people seem to be sticking a stock 01 /02 gsxr end can onto the bike, this sounds like an ideal solution to me, Anyone tried it on the dakar or am i going to be first ![]() An added bonus is that it'll never need repacking.
"Mad Science" means never stopping to ask "what's the worst thing that could happen? ![]() Smugmug photo site discount coupon X0gojbokG3nBM
rc mad screwed with this post 05-18-2010 at 12:33 PM |
05-18-2010, 01:34 PM
#2304 |
Oddometer: 2,282
Are these aftermarket pipes with thinner stainless steel? Because why not just cut the OEM exhaust at both ends and get a perforated pipe welded on the end cap.
05-18-2010, 02:57 PM
#2305 |
Oddometer: 2,282
On the topic of exhausts. Who's thought about going with aluminium. Apparently the may not last as long. Dunno why or if that's the case. Thought that ali is fine in high temp applications.
The bloke that does my finish welding made his own exhaust, so it can't be hard or expensive to do. |
05-18-2010, 03:00 PM
#2306 |
Physycotic gecko
Oddometer: 1,313
Nope, these would be stock k1 / gsxr exhausts, full titanium with an ally skin, means it'll weigh next to bugger all.
And because no one wants a stock exhaust they can be had for cheap, less than £30.00 delivered from ebay. That's if the dr lot don't get there first ![]() I could easily chop up the stock gs exhaust but i'd rather not as you never know when it may be needed. Hopefully the fi on the dakar is smart enough to accomidate the change, it should be as it ran fine with the scorpion. Also being doing my homework, inlet pipe diameter of the gsxr can is 58mm, o/d of the scorpion link pipe is 52mm. Means it'll work All i have to make is a flange to suit the 52mm pipe and the mounting holes on the exhaust, mock it alll up then get it welded.Theres a gasket that sits between the exhaust and the mount flange, so the diameter of the pipe doesn't matter too much. Ally is quite susceptible to vibration tmotten, perhaps that's why they wouldn't last long on a single
05-18-2010, 07:05 PM
#2307 |
Oddometer: 313
Oil / water and thanks!
I think we fixed Doug's bike. "we" I mean y'all... In any event... thanks.
Water pump seal seems to have been the issue. |
05-20-2010, 02:55 AM
#2308 |
Oddometer: 74
Bash plate finished
Just finished making up a bash plate. Obviously based on the TT plate, $20 for the alloy, half a dozen cereal packets as templates but pretty happy with the thing.
Gas Gas 280 Factory Racing |
05-20-2010, 03:41 AM
#2309 |
Oddometer: 2,282
Nice job. How thick is that?
05-20-2010, 05:10 AM
#2310 |
Oddometer: 74
4mm thick
