Old 06-21-2010, 10:38 AM   #2596
notmybikemodelname
KOTW is a myth!
notmybikemodelname's Avatar
Location: I'm in jail Dad, and I like it here.............
Oddometer: 7,276
Originally Posted by Gravel Seeker
Strictly esthetically speaking you need a low fender painted that same grey
You think? I was thinking that as well. But for now, I'm done working on it and just want to ride it.
notmybikemodelname is offline   Reply With Quote
Old 06-21-2010, 10:42 AM   #2597
BMacW650
BMacW650's Avatar
Oddometer: 751
Did you change the linkage to raise the rear?? I noticed you still have the stock shock.
BMacW650 is offline   Reply With Quote
Old 06-21-2010, 10:57 AM   #2598
Gravel Seeker
Thomas
Gravel Seeker's Avatar
Location: Dreary old Norway, dreaming of adventures past
Oddometer: 4,027
Yeah, I thought it looked sharper in those pics you posted last week without the front fender so a low one is the correct route, me tinks. And the fork protectors must be the same grey ofcourse.
Kudos though, nice piece of work
I handed my cylinder head over to Oslo cylinder service today to see if they can make it level without removing more than 10/100s mm.... the place where the exhaust escapes to the coolant is in the center front and the opening is actually 1 cm wide (as evident by the black soot)..... it will be ready tomorrow so I don't have to wait long to see if the cheap fix was possible. Ordered a new head gasket (sucks to have to replace it again after just 450km...) and I got the usual response (Norways largest BMW dealer):
- We don't have that in stock
Me: So you'll have it tomorrow ?!
- If they have it in stock in Sweden we'll have it in three days
Me: hmmm...
- But if we have to get it from Germany it takes 5 days
Me: That's just great.....call me.
'01 F650 Dakar - modified as best I can
2005: Australia - 8 months/ 26.000 km (anti clockwise circle)
2009: Norway - 2 weeks/ 6000 km (Lindesnes to North cape)
Gravel Seekers.com
Hey !
It's the African ant eater ritual !
Gravel Seeker is offline   Reply With Quote
Old 06-21-2010, 11:08 AM   #2599
Gravel Seeker
Thomas
Oddometer: 4,027
Originally Posted by rob feature
I noticed a little bit of a gain with the TFI box. More in throttle response than anything. Maybe one more HP. Maybe. But it's at the expense of MPG. My mileage dropped from mid 60s to low 30s.
Worth it? Absolutely not. Then again, lofty MPG is one of the reasons I love my Dakar so much.
Run cleaner? No. First of all, you've removed the catalytic converter, so you're tossing more into the air. Secondly, you're cutting MPG pretty much in half and burning twice the fuel.
Fook mi.
Think I'll just go on a diet instead
If anyone knows of a beer based diet please let me know
Gravel Seekers.com
Hey !
Old 06-21-2010, 02:13 PM   #2600
jonkem
Got let out early
Oddometer: 172
alloy gear shift lever?
Does anyone know if any folding Alloy gear shift levers from other bikes fit on a Dakar? Hopefully a bit longer than the stock item as well
jonkem is offline   Reply With Quote
Old 06-21-2010, 02:23 PM   #2601
poppawheelie
poppawheelie's Avatar
Oddometer: 590
Signal Minder
I'm assuming this is the right thread for a 2009 G650GS question. Has anyone ever installed a Signal Minder? Where, exactly, do you tap into the wiring?
If there's a post about this already, sorry, I didn't find it.
How 'bout a loud beeper? Anyone ever add one? And where to tap the wires? Where is the turn signal box on these 650GS's? I don't know wiring outside of Jap bikes.
"To me the trail is calling! The old trail - the trail that is always new." Matthew Alexander Henson
"It's not the destination. It's the journey." Me
poppawheelie is offline   Reply With Quote
Old 06-21-2010, 02:59 PM   #2602
notmybikemodelname
KOTW is a myth!
Oddometer: 7,276
I'm bored!
So, after riding the mod'd Dakar all day yesterday, I've come to one conclusion after shedding 55-60 lbs.................
I think it can be lighter and smarter.
So, I will be ditching my whole rear sub frame, stock gas tank, "new" seat and "new" tail gas tank for a monocoque construction Husaberg-inspired gas tank/sub-frame combo.
The tank/subframe should weigh less than the stock tank alone, hold 8 gallons of fuel and be stronger than the current lay out. It will have a dual wall construction and be fillable from both sides and have a dual cell lay out that will allow me to close off one side should it get ruptured, thereby saving 50% of the remaining fuel.
It will look something like this in profile and use a stock WR 450 rear fender.
Would anyone like to see a build thread for this small little project?
Old 06-21-2010, 03:08 PM   #2603
BMacW650
BMacW650's Avatar
Oddometer: 751
I have it on mine. I didn't buy it for the 'signal minder' feature. (I don't use my turn signals ) I got it for the hazard, the run/turn/brake light integration. It's the second best mod I've done on my bike.
Not hard to do at all, all the wires (left, right turn signal, brake, running[tail light]) are under the seat. The flasher is in front of the battery.
Old 06-21-2010, 03:28 PM   #2604
tmotten
Lefthand ride Dutchy
tmotten's Avatar
Oddometer: 2,488
Yep, I would.
When are you starting the production lines?
tmotten is offline   Reply With Quote
Old 06-21-2010, 04:05 PM   #2605
poppawheelie
Oddometer: 590
Signal Minders
Anyone install one in a Dakar or G650GS? Where would it wire into? Where is the turn signal "black box?"
Old 06-21-2010, 04:52 PM   #2606
SonHomme
Team F5,⌘R FYCYFF
SonHomme's Avatar
Oddometer: 558
+1 on a thread dedicated to that for shizel
SonHomme is offline   Reply With Quote
Old 06-21-2010, 05:33 PM   #2607
kaia
team F5 ⌘R
kaia's Avatar
Oddometer: 2,574
selling the old plastics?
Originally Posted by redbastard
Off with the Captain America plastics on with a set from a 2006 Dakar.
i'd be interested in buying the old Captain America plastics off you if you're selling...
bike: 2010 KTM 990R | photos: SmugMug | SmugMug save $5: PeYEyWo3aVaYk
kaia is offline   Reply With Quote
Old 06-21-2010, 06:02 PM   #2608
etmoto
etmoto's Avatar
Oddometer: 480
Hammerhead should have ranges of different offset to fit you.
etmoto is offline   Reply With Quote
Old 06-21-2010, 06:13 PM   #2609
herrhelmet
A Serious Man
herrhelmet's Avatar
Oddometer: 2,364
Originally Posted by MYBLUETT
Let me know what I can do to help. I have an oil drain for you.
"Your bike is too heavy" www.motolithium.com TWITTER
herrhelmet is offline   Reply With Quote
Old 06-21-2010, 06:31 PM   #2610
redbastard
redbastard's Avatar
Oddometer: 1,128
PM'd ya
Sent ya a PM
redbastard is offline   Reply With Quote
Times are GMT -7.   It's 11:31 PM.
