Old 04-21-2009, 11:11 AM   #301
Gravel Seeker
Thomas
Gravel Seeker's Avatar
Location: Dreary old Norway, dreaming of adventures past
Oddometer: 4,055
Originally Posted by dang
My personal list,
Pizza
Carrot Cake
Tim's Jalapeno Chips
Coconut Popsicles
Hoody's Peanuts
'01 F650 Dakar - modified as best I can
2005: Australia - 8 months/ 26.000 km (anti clockwise circle)
2009: Norway - 2 weeks/ 6000 km (Lindesnes to North cape)
Gravel Seekers.com
Hey !
It's the African ant eater ritual !
Gravel Seeker is offline   Reply With Quote
Old 04-21-2009, 11:18 AM   #302
notmybikemodelname
KOTW is a myth!
notmybikemodelname's Avatar
Location: I'm in jail Dad, and I like it here.............
Oddometer: 7,274
Strip List
Originally Posted by RealitySheriff
Hola all.
I have a stock 05 and I'm looking to drop about 50lbs. Who out there can give me a strip-list?
I have an "06 Dakar.....kind of.
Last weighed, it was about 338lbs dry.
Here's what I've done:
Yamaha YZ 450 front suspension -7lbs
Replaced stock exhaust with Supertrapp directly to header (no Adventure Pipe connector) -15lbs
Removed ABS system (It's shit anyways) -12lbs
Moved battery into ABS box to lower CG.
Removed Fairing, light assembly, and metal support bracket. Replaced with 1.5lb carbon fiber setup with dual 50w HID's. -12lbs
Removed rear cowling/luggage rack setup and metal sub structure. -6lbs
Cut off rear pegs at the frame. -2lbs
Removed all plastic except to faux tank pieces. -4lbs
All total removed = 58lbs +/-
Now I'm working on all new plastic/carbon/kevlar body panels. The new rear cowling will take up the rear seat area and hold an additional 1.8g's of fuel.
This is what it will look like when complete.
I have moved my oil reservoir inside the frame and fabbed up a new air intake that utilizes dual K&N high-flow filters. Doing both of these mods has allowed me to fab a new faux tank piece that is 5" lower and 6" narrower than the stock one. Thus, allowing a more nimble feel and better centering and forward movement of your weight when riding.
This is the battery mod that has been done showing now open area for ???.
Here's what it recently looked like.
Here's the new faux tank tooling being done.
I ride my bike mainly in the dirt, only hitting slab to get there. I just rode the high desert for two days, 768 miles, and only 110 of that is slab. I can keep up with most anyone on a KTM 690/950/990/950se, XR650, Husky 610, etc.
Originally Posted by john_aero
well i know designed for much lighter bike but they are still designed much stronger and stiffer that the dakar bike from just apperances alone.
maybe the wp off a ktm would do the trick also but hard to come by.
The Yamaha YZ forks are 46 and 48mm, depending on the year. The TT/WP set up is only 43mm. The YZ forks and triples are more than strong enough for a Dakar. The only thing that is needed is to change the springs form the stock .46's to at least .52 depending on your weight. I currently run the .52's and weigh 180lbs. Almost too stiff for me. I also run the stock YZ 450 brake system and have absolutely no need for anything else. In the dirt, you mainly use the rear anyways.
notmybikemodelname screwed with this post 04-21-2009 at 11:27 AM
notmybikemodelname is offline   Reply With Quote
Old 04-21-2009, 11:19 AM   #303
Gravel Seeker
Thomas
Oddometer: 4,055
Oh yeah, that one is important. before getting it I ran with a zip tie surreptitiously(sp?) placed so that when it fell off I'd still have it with me. All three of the bits we've talked about don't add up to more than a couple of ounces and are worth a great deal of headache prevention. As for the cost what is your time worth? The one that holds the two sides together is easy to fabricate. The license plate one so-so. The lock bit is worth a couple hours for me.
I've solved all of those issues without buying anything from TT*
*Not at all true. I've bought lots of stuff from there, including the license plate piece and the rear mud guard thing, but it would've totally messed up my point above to say I by stuff from TT
Gravel Seekers.com
Hey !
Old 04-21-2009, 11:27 AM   #304
Gravel Seeker
Thomas
Oddometer: 4,055
Originally Posted by Brute
Quotte " I emailed him a link to adv rider and the Yamaha front end thread. I was surprised he took the time to read the whole thing. Said they were designed for a bike half the weight. Would need to fit the stiffest spring available and even if the the set physically fit the bike it would need to be run at the extreme limit all the time. He pretty much adviced against it.
This crossed my mind also , but I figured the YZ forks are built for supercross style jumps & although the Dakar is a lot heavier you still won`t be doing supercross style jumps with the YZ forks fitted .
True.
It obviously works for some of you. Getting a used set from eBay over here would be an absolute fortune aswelll and I couldn't find any used here (after a quick search). It's in the books for me now anyway, so I just hope it works out. He normally charges $1400 for this build, but'll charge me a bit less since it's a "prototype" project.
Gravel Seekers.com
Hey !
Old 04-21-2009, 11:52 AM   #305
john_aero
john_aero's Avatar
Oddometer: 1,174
deadly so all i need is amx bike complete front end,
or does the dakar front wheel, axel and speedo drive.
john_aero is offline   Reply With Quote
Old 04-21-2009, 11:54 AM   #306
notmybikemodelname
KOTW is a myth!
Oddometer: 7,274
Originally Posted by Gravel Seeker
True.
A YZ 450 weighs 250lbs dry. I know many guys who weigh well over 250lbs that ride these bikes well beyond their limits. With that said, a Dakar weighs 389lbs dry in it's stock form. The difference is 139lbs. Most Dakar riders ride gravel roads ans some bumps, hill climbs, sand etc. Engineers don't design m/c parts to fail if you take them slightly beyond their limits. So, YZ forks on a Dakar is more than most riders will ever use. Besides, you'll never be jumprng your bike 20 feet vertical and 100 feet in distance.
Believe me, I ride my bike well beyond it's designed limits and the last thing I'm worried about is my YZ forks failing.
With that said, if you want a set of YZ forks, buy them. Shipping to Europe is only about $150 the slow way.
I did my whole set up for under $350 including: Excel rim, braker caliper, new longer brake line, Racetech springs, and all new seals.
And for those naysayers that doubt the simplicity of this mod. Once I had all of my components, the whole change out only took 1.5 hours. And they do bolt right up with a 1/4 shim under the triple clamp.
Get the whole thing. What Speedo? I use a GPS for speed. My bike has no instrumentation.
Old 04-21-2009, 12:01 PM   #307
JDLuke
Ravening for delight
JDLuke's Avatar
Oddometer: 8,644
There are two ways to go, probably the easiest and cheapest would be the full front end. The weakness of this approach is the front brake system, which is far beefier on the heavier 650s.
Adapting the BMW wheel to the Yamaha forks takes a bit of ingenuity, though. A group of us did a purchase of the parts for it, at a cost of a few hundred bucks to each of us. The trick is to adapt the larger hole in the YZ forks to the smaller hole through the BMW hub.
Why did I drink all of the ingredients for vomit?
"Used to be Man vs. Nature.. then Man vs. Space.. then Man vs. the Moon. Now it's Man vs. Food" - Dalar
"you cannot reason a person out of something they were not reasoned into." - Jonathan Swift
JDLuke is offline   Reply With Quote
Old 04-21-2009, 12:12 PM   #308
notmybikemodelname
KOTW is a myth!
Oddometer: 7,274
The YZ brake system is more than adequate. No weakness at all!
However, those parts that Jim made are sweeeeeeeeeeeeeeeeeeeeeeeeeeeet!
Old 04-21-2009, 12:19 PM   #309
JDLuke
JDLuke's Avatar
Oddometer: 8,644
Cheerfully withdrawn, then. I haven't made a research project or anything of it, just went by looks and the idea that brakes made for a 250 pound bike designed for dirt would logically be lower spec than brakes made for a 400 pound street legal machine.
No argument there. Beautiful work.
Old 04-21-2009, 12:24 PM   #310
notmybikemodelname
KOTW is a myth!
Oddometer: 7,274
Probably valid for a 400lb bike that rides mostly street where the front brake is used 80-90% of the time. I ride almost all dirt and my bike has been on a serious diet. Now, if only I could lose about 20lbs
Old 04-21-2009, 12:31 PM   #311
JDLuke
JDLuke's Avatar
Oddometer: 8,644
Ah, you see I may spend several hours riding highways to get to some dirt, and it could be weeks between dirt roads. Stupid overdeveloped suburbs. I think we have both probably made good choices in direction for the forks.
Old 04-21-2009, 01:01 PM   #312
john_aero
john_aero's Avatar
Oddometer: 1,174
thoes are sweet parts, well i would be very tempted get the barksfrom usa and shipped over here.
as got speedo i would still like keep the dash as handy for when doing my test.
willride bike stock when buy it and get all the parts ready and then do whole re build
are thoes brake mounts and shafts still around? even the drawings be fine as i could get them made in house at work
Old 04-21-2009, 01:30 PM   #313
JDLuke
JDLuke's Avatar
Oddometer: 8,644
They're even better in person, but the guy to contact would be JDRadman, who is responsible for the design of these pieces, and also contracted out the machine work. He was really the driving force, and it was probably a bit wrong of me not to mention his name at the start of this.
My understanding is that he contracted for five sets, all of which already had buyers. I think he said he'd consider a second run of parts if there was sufficient interest, find the thread 'Yamaha Forks on a BMW F650GS' for more.
Old 04-21-2009, 01:35 PM   #314
dwayne
Silly Adventurer
dwayne's Avatar
Oddometer: 3,607
JDLuke, where did you get the parts from?
Do you have a pic of them installed.
Rum Runners Yukon, NWT & Alaska
Roads and Ruins Scotland
Kinbasket Lake Golden B.C.
A "Day" of Dirt Biking Rockies East Slopes
High and Dry Colorado and Utah
"When your only tool is a hammer, every problem looks like a nail"
dwayne screwed with this post 04-21-2009 at 01:44 PM
dwayne is offline   Reply With Quote
Old 04-21-2009, 01:37 PM   #315
JDLuke
JDLuke's Avatar
Oddometer: 8,644
Dwayne,
See the post immediately before yours, where I went into a bit more detail. It's all JDRadman's fault!
Times are GMT -7.   It's 03:46 PM.
