Old 04-21-2009, 01:41 PM   #316
RXV_Poor
RXV_Poor's Avatar
Oddometer: 447
In Theory
You'd think a YZ brake upgrade or big brake kit work if you felt the front brakes needed help?
Traditionally MX brakes are some of the most powerful out there. I would also think that you can also upgrade the master cylinder for more power if you want it. I hear that the CRF450R has a very good front master cylinder.
02 Aprilia Mille
06 KTM 525XC
06 KTM 950 ADV S
07 KTM 525EXC
07 Aprilia RXV 550
AMA, BLC, D36, IMBA, STM
Disclaimer:
I'm impulsive, hard headed and sometimes really stupid. Please do not take anything I say or do as a "correct thing" or a "fix" as it could be harmful to your wallet or person.
RXV_Poor is offline   Reply With Quote
Old 04-21-2009, 01:46 PM   #317
Moribach
Oddometer: 60
Originally Posted by notmybikemodelname
Moved battery into ABS box to lower CG.
So what the hell is in that spot on a non-abs bike to begin with? That seems like a hell of a hole for nothing if you didnt start with ABS.
2007 F650GS Dakar
Moribach is offline   Reply With Quote
Old 04-21-2009, 01:47 PM   #318
dang
Oddometer: 450
Isn't it the preload canister on the Dakar?
dang is offline   Reply With Quote
Old 04-21-2009, 02:05 PM   #319
dwayne
Silly Adventurer
dwayne's Avatar
Oddometer: 2,775
yes, but it's pretty easy to move it to where the ABS models canister is mounted
I did the battery relocate to, a couple of years ago. works well!
http://www.advrider.com/forums/showthread.php?t=206084
Rum Runners Yukon, NWT & Alaska
Roads and Ruins Scotland
Kinbasket Lake Golden B.C.
A "Day" of Dirt Biking Rockies East Slopes
High and Dry Colorado and Utah
"When your only tool is a hammer, every problem looks like a nail"
dwayne screwed with this post 04-21-2009 at 02:22 PM
dwayne is offline   Reply With Quote
Old 04-21-2009, 02:06 PM   #320
dwayne
Silly Adventurer
dwayne's Avatar
Oddometer: 2,775
Originally Posted by JDLuke
Dwayne,
See the post immediately before yours, where I went into a bit more detail. It's all JDRadman's fault!
timing thing!
for some reason I can't visualize them installed?
Old 04-21-2009, 02:21 PM   #321
notmybikemodelname
KOTW is a myth!
notmybikemodelname's Avatar
Location: I'm in jail Dad, and I like it here.............
Oddometer: 6,469
The Cappucino maker.........what else?
notmybikemodelname is offline   Reply With Quote
Old 04-21-2009, 02:22 PM   #322
JDLuke
Ravening for delight
JDLuke's Avatar
Oddometer: 8,645
Originally Posted by dwayne
timing thing!
The axle will go through one fork leg, the spacer (I think) and the hub, then through the other fork leg. Then the 'nut' portion will be screwed on over the axle and into the hole in that second fork leg. The picture with the bits assembled really is how it will sit. I guess there are nuts to bear down on the axle in the fork itself.
I'll be honest: I jumped on the parts when they were available, and simultaneously ran into a few extra expenses, so I haven't purchased my other suspension bits yet. I'm also going to need a rear shock because I'm essentially taking my GS up to Dakar + height. I've got a bit of work and money to put in before I have anything else to show.
Why did I drink all of the ingredients for vomit?
"Used to be Man vs. Nature.. then Man vs. Space.. then Man vs. the Moon. Now it's Man vs. Food" - Dalar
"you cannot reason a person out of something they were not reasoned into." - Jonathan Swift
JDLuke is offline   Reply With Quote
Old 04-21-2009, 02:26 PM   #323
Gravel Seeker
Thomas
Gravel Seeker's Avatar
Location: Dreary old Norway, dreaming of adventures past
Oddometer: 3,432
Originally Posted by john_aero
deadly so all i need is amx bike complete front end,
or does the dakar front wheel, axel and speedo drive.
Speedo goes to the rear wheel stock doesn't it ?
I've been running an IMO since 2003 so I can't remember.
'01 F650 Dakar - modified as best I can
2005: Australia - 8 months/ 26.000 km (anti clockwise circle)
2009: Norway - 2 weeks/ 6000 km (Lindesnes to North cape)
Gravel Seekers.com
Hey !
It's the African ant eater ritual !
Gravel Seeker is offline   Reply With Quote
Old 04-21-2009, 02:27 PM   #324
JDLuke
JDLuke's Avatar
Oddometer: 8,645
Think so. there's certainly nothing beyond the ABS sensor and brake line running to my front wheel.
Old 04-21-2009, 02:29 PM   #325
tmotten
tmotten's Avatar
Oddometer: 2,284
I've solved all of those issues without buying anything from TT*
*Not at all true. I've bought lots of stuff from there, including the license plate piece and the rear mud guard thing, but it would've totally messed up my point above to say I by stuff from TT
How do you remove the seat?
tmotten is offline   Reply With Quote
Old 04-21-2009, 02:36 PM   #326
Gravel Seeker
Thomas
Oddometer: 3,432
That's the first try you see in the picture there.
You can see the OEM pully sticking out over the license plate. I just picked it apart and used wire to extend the pully back.
I've since remade it to where it is underneath the mudguard on a fixed bolt. Works GRRRRRRRRRRRREAT eventhough you might get some mud and gravel on the one finger you use to operate it. I'll take some pics tomorrow when it's not rapidly approaching midnight.
Gravel Seekers.com
Hey !
Old 04-21-2009, 04:07 PM   #327
Quasi
Just an Adventurer
Quasi's Avatar
Oddometer: 9
My 2004 Dakar TT39
Quasi is offline   Reply With Quote
Old 04-21-2009, 06:20 PM   #328
atFault
Logical Positivist
atFault's Avatar
Oddometer: 93
Originally Posted by Quasi
My 2004 Dakar TT39
I was thinking that this was something to really consider doing to increase distance and if you didn't want to use it you could just fill your standard under-seat tank while keeping the weight lower when all that fuel was not necessary ... that was until I saw the price. $2307.40 is completely overboard even for TT. Too bad this kit is only for those who absolutely need it and not even close to being affordable for someone who could benefit from it.
That being said, your bike with the TT39 looks amazing and I'm insanely jealous.
Of course I'm at fault, at least that's what I'm always told.
atFault is offline   Reply With Quote
Old 04-21-2009, 06:37 PM   #329
fyr
iRoast Coffee
fyr's Avatar
Oddometer: 1,216
Hey
When are we gonna see your wheels 'round here? (would you come 'round for some COFFEE?)
"Don't threaten me with a dead fish"
07 Bonnie T100
Gonzo- 08 Ural G/U, 77 R100S, 01 Bonnie, 2x KLR's, Wee, Ninja's, CBR's, yadda yadda...
fyr is offline   Reply With Quote
Old 04-21-2009, 06:47 PM   #330
hetman
Oddometer: 116
I bought my Dakar with an 18" Excel already on the back, but with the stock sprockets. It seems like a common mod to drop a tooth in the front.. for me to get the same result, would I have to drop two or is the different negligible?
hetman is offline   Reply With Quote
Times are GMT -7.   It's 07:19 AM.
