Old 08-02-2011, 04:23 PM   #6001
WU7X
The Old Fart
WU7X's Avatar
Oddometer: 2,030
Call Sasquatch
I had a set of Progressive springs and Hyperpro emulators installed in my OEM Dakar forks. Totally different, totally better front end now. Also had Sasquatch rebuild the OEM rear shock to his stage II level and installed it and a new spring in the rear. Still haven't totally played that out yet for best ride. But will be working on that once I get the new chain and oil pressure sensor installed. Waiting for the new sensor now...looks like it's a week out.
To clarify something though, I'm probably older and 10-20 lbs lighter than you. Also to be honest, most of my miles are ridden getting to and back from the dirt and gravel. I'm also pretty slow. Still think the changes I made worked out perfectly for me.
"Seika" - 2013 DL650 + DMC M72D Sidecar
"Gracie" - 1983 R100RT 60th Anniversary Edition
"Dusty" 2011 Adventurized 4Runner
Adventure is worthwhile." ~ Aristotle
Airhead #14449
WU7X screwed with this post 08-02-2011 at 05:25 PM
WU7X is offline   Reply With Quote
Old 08-02-2011, 05:49 PM   #6002
kubiak
Oddometer: 4,829
Originally Posted by tmotten View Post
Hmm. Black IS slimming
yes it is, sure made my 12 gallon tank on the 1150 look smaller!
kubiak is online now   Reply With Quote
Old 08-03-2011, 01:34 AM   #6003
Gravel Seeker
Thomas
Gravel Seeker's Avatar
Location: Dreary old Norway, dreaming of adventures past
Oddometer: 4,004
Originally Posted by MYBLUETT View Post
Stickers are available...
Sweet. But acc to www.jlevistreetwerks.com they don't have them in 55mm (just went out and measured my roundel), just 78, 79 and 82mm which are way to big.
My thoughts exactly. Me like. But you're a professional painter ? Everything I've painted over the years have turned to crap after a few years.
'01 F650 Dakar - modified as best I can
2005: Australia - 8 months/ 26.000 km (anti clockwise circle)
2009: Norway - 2 weeks/ 6000 km (Lindesnes to North cape)
Gravel Seekers.com
Hey !
It's the African ant eater ritual !
Gravel Seeker is offline   Reply With Quote
Old 08-03-2011, 03:41 PM   #6004
Lone Wolf 48
Oddometer: 14
Question G650GS Start
Hello
Hope that this is the right place for this post.
I have a G650GS with date of fabrication Sept 2009. Several times when I try to start it, wait until all indicators are steady, press starter and nothing happens. Put bike in first and rotate the engine a fraction by moving the bike, back to neutral and "hey Presto" it starts. Bike will be OK for weeks then it happens again. Has anyone met this problem?
Lone Wolf 48 is offline   Reply With Quote
Old 08-03-2011, 05:16 PM   #6005
kubiak
Oddometer: 4,829
i just bought a 02 dakar and the clutch seemed to be weak like when i try to pop a wheelie it just slid into gear. the po used 15-50 synthentic oil so i put in 10-40 regular mc oil and its like a new clutch again! it hits nice and firm when i shift and let the clutch out fast. the dealer recomended regular oil so im sticking with it from now on.
Old 08-03-2011, 08:44 PM   #6006
Don Coyote
Don Coyote's Avatar
Oddometer: 1,311
Originally Posted by Lone Wolf 48 View Post
Hello
BMW stopped making the Dakar before they renamed the "F"s to "G"s and I believe moved production facilities entirely, so even though the basic design is the same, I'd guess these are less likely to share production quirks. I don't know if there are any other dedicated threads around here, but f650.com is likely to give a broader sampling of models...
'06 F650GS Dakar
Those who believe you should always error on the side of caution usually become comfortable making errors and before too long know of little else.
Don Coyote is offline   Reply With Quote
Old 08-04-2011, 05:08 AM   #6007
Gravel Seeker
Thomas
Oddometer: 4,004
Hello
Check the standard culprits;
  • Kill switch on right handle bar
  • Kill switch on clutch lever mount
  • Kill switch on side stand
Putting my money on the side stand kill switch. It is possible to bypass the switch all together (took me about 10 minutes all together) http://faq.f650.com/GSFAQs/Electrica...tch%20Problems
Gravel Seekers.com
Hey !
Old 08-04-2011, 06:38 AM   #6008
Lone Wolf 48
Oddometer: 14
I will check those points, but I do not understand why moving the engine by rocking the bike in first will affect the kill switches, maybe coincidence, but thanks for all suggestions, motorcycle electrics are not what they used to be when I started motorcycling.
Old 08-04-2011, 07:07 AM   #6009
Gravel Seeker
Thomas
Oddometer: 4,004
Quite possibly the clutch switch too..... my [second, hehe] guess is it's not the actual rocking, but the changing gears out and back into neutral triggering the clutch switch
You can only start the bike in neutral with the sidestand down. It will die as soon as you chuck it in gear, even if the clutch lever is pulled in.
If the sidestand is up you can start it in gear with or without the clutch pulled in (will jump forward of course if clutch is not pulled in)
Hope that made sense
Gravel Seekers.com
Hey !
Old 08-04-2011, 10:02 AM   #6010
kubiak
Oddometer: 4,829
going through all of this thread, at 140 so far and great stuff on here!
Old 08-04-2011, 07:25 PM   #6011
MikeS
For sure let's do it
MikeS's Avatar
Oddometer: 811
Fork oil capacity F650GS
ChainGang FAQ's is down, and I don't have confidence with what I'm finding through a search: Namely 2001 F650GS: I changed fork seals today and I need to fill the forks. I have a recollection from ChainGang that fork oil capacity is 610cc. I found one spec. for this bike at 560cc. Right now I filled them to 560cc. Does anyone have reliable information what the capacity is? Everything is standard with original equipment GS forks/springs and not lowered.
R1150RT, F650GS thumper, KL250
BMW: "Beer, Motorcycles, Women"
MikeS is offline   Reply With Quote
Old 08-04-2011, 07:31 PM   #6012
mrprez
KJ4WMZ
Oddometer: 1,265
According to Haynes:
Regular service:
GS
Regular suspension: 600ml
Lowered suspension: 610ml
Dakar: 550ml
Overhaul:
GS
Regular suspension: 610ml
Lowered suspension: 620ml
Dakar: 560ml
Sent via morse code
mrprez is offline   Reply With Quote
Old 08-04-2011, 08:31 PM   #6013
Kainic
Almost there
Kainic's Avatar
Oddometer: 385
Regular service:
GS
Dakar: 550ml
Overhaul:
GS
Dakar: 560ml
Any idea what the airchamber height should be?
Kainic is offline   Reply With Quote
Old 08-05-2011, 02:04 AM   #6014
Gravel Seeker
Thomas
Oddometer: 4,004
If you had everything out:
GS: 610cc (for each leg)
Dakar: 560cc
Just oil change:
GS: 600cc
Dakar: 550cc
And since we're on the topic;
If you have Wirth springs from Touratech on a Dakar it's 500cc in each leg
Gravel Seekers.com
Hey !
Old 08-05-2011, 02:04 AM   #6015
Gravel Seeker
Thomas
Oddometer: 4,004
Post or page ?
Gravel Seekers.com
Hey !
Times are GMT -7.   It's 10:32 AM.
