Old 08-11-2011, 01:32 PM   #6091
tmotten
Lefthand ride Dutchy
tmotten's Avatar
Oddometer: 2,470
I was told my by automotive electrician mate and electrical engineers at work NOT to put the grease anywhere near the terminals because you limit the contact connection. If you use it, put it in the back of the connector to seal the air out of it. YMMV
tmotten is offline   Reply With Quote
Old 08-11-2011, 01:40 PM   #6092
pyrate
Walking the plank
pyrate's Avatar
Oddometer: 1,177
Correct. You don't put it on the terminals and then connect them. But rather get your terminals very clean, connect them and then add the grease on the outside of everything. That keeps all the crap out of it.
"but why is all the rum gone?"
pyrate is offline   Reply With Quote
Old 08-11-2011, 07:16 PM   #6093
yatman
yatman's Avatar
Oddometer: 246
Question Neg switching or Pos switching?
Am requesting reliable info for my '07 Dakar...would I order a Negative switching or Positive switching relay?
http://www.wolstentech.com/products/...elay/tdr-s.php
..am hoping this will increase the life of my H4 hi/lo bi-xenon HID & ballast...thank you...electrical no-mind
Yatman...
yatman is offline   Reply With Quote
Old 08-11-2011, 07:29 PM   #6094
mrprez
KJ4WMZ
Oddometer: 1,265
Yatman...
Based on that diagram you'd want the Negative Switching Relay.
Sent via morse code
mrprez is offline   Reply With Quote
Old 08-11-2011, 09:48 PM   #6095
kubiak
Oddometer: 4,829
yay finally finished reading all 407 pages in this section!
Old 08-11-2011, 09:55 PM   #6096
mrprez
KJ4WMZ
Oddometer: 1,265
OK, so are you ready for your test?
Sent via morse code
Old 08-12-2011, 09:03 AM   #6097
kubiak
Oddometer: 4,829
yea maybe lol!
Old 08-12-2011, 09:13 AM   #6098
Gravel Seeker
Thomas
Gravel Seeker's Avatar
Location: Dreary old Norway, dreaming of adventures past
Oddometer: 4,004
Thanks for the replies guys. I had a large reply typed up earlier, but the site decided to crash on me as I posted (am I the only one experiencing a lot of lag and lost time outs on this site after the latest upgrade ?)
I'm guessing my battery terminal grease is pretty much the same kind of grease your all using. It doesn't conduct electricity and prevents corrosion and oxidation.
I had everything cleaned up and greased the back of the terminals as instructed. Put everything back together and nada. After some messing about I managed to isolate the problem to pulling and pushing the wires in and out of the switch housing; making and breaking the contact to the ignition. Since the plug and socket are now clean and greased the problem must be inside the switch itself where the little white plastic thing turns with the key and makes contact to the different pins/ wires. Problem though is that the switch itself seems to be cast in plastic and I'm not sure if it's possible to open it up. Anyone done it ? If so how ?
I'll have a go at it tomorrow so you have about 15 hours to blind me with your genius
'01 F650 Dakar - modified as best I can
2005: Australia - 8 months/ 26.000 km (anti clockwise circle)
2009: Norway - 2 weeks/ 6000 km (Lindesnes to North cape)
Gravel Seekers.com
Hey !
It's the African ant eater ritual !
Gravel Seeker is offline   Reply With Quote
Old 08-12-2011, 06:23 PM   #6099
kubiak
Oddometer: 4,829
painted my dakar white last week and it looked too much like a local police bike so i repainted today flat and gloss black.
Old 08-12-2011, 06:24 PM   #6100
kubiak
Oddometer: 4,829
pic of the other side, i went flat clear over the parts then regular clear over the bottom part of the front side covers.
Old 08-12-2011, 06:30 PM   #6101
pyrate
Walking the plank
pyrate's Avatar
Oddometer: 1,177
Pics? I've never had mine apart but it might be similar to other switch someone has used. Tick Tock....
Old 08-12-2011, 09:11 PM   #6102
Jronwood
87 XT600
Oddometer: 22
Man does that BLACK look good.
Jronwood
Jronwood is offline   Reply With Quote
Old 08-12-2011, 09:18 PM   #6103
DingDangKid
El Lechero
DingDangKid's Avatar
Oddometer: 2,607
How did you paint it? Just rattle can? I'm looking to do my 650gs to get rid of the ugly metallic blue color.
2006 Tdub
2006 Wee
DingDangKid is online now   Reply With Quote
Old 08-13-2011, 12:54 AM   #6104
Gravel Seeker
Thomas
Oddometer: 4,004
Any particular reason for going with two shades of black ?
Any pro tips on how to remove old (5 years) rattle can paint from plastic panels
I've thought about paint remover, but I'm afraid that'll eat the plastic. I've also considered light sandblasting. Sandpaper is out of the question
Gravel Seekers.com
Hey !
Old 08-13-2011, 01:25 AM   #6105
Gravel Seeker
Thomas
Oddometer: 4,004
I was going to wait to post any pics untill I was done with it, but looking through the pics I've already taken, I'm thinking it actually is possible to open it up
So this is the first thing I see.... fuck me, not looking good at all
Pull it apart (and break one of the tabs in the process....of course...)
What's the last pin for ? Our bikes only use 4 out of 5 pins in the ignition
Got it cleaned up alright
And stuffed as much grease as I could in there
And looking through the pics I noticed what looks like a second release tab. Thinking maybe I can pull the switch itself out from the other end....will check that out later and report back.
Gravel Seekers.com
Hey !
Times are GMT -7.   It's 02:47 PM.
