Old 09-10-2011, 08:33 PM   #6316
Kainic
Almost there
Kainic's Avatar
Oddometer: 380
Warped Rotor
Looking to replace my warped rotor on my 06 Dakar and I don't want to go OEM. Any other better options?
Kainic is offline   Reply With Quote
Old 09-10-2011, 09:09 PM   #6317
euromedic
Peter...n00b
Oddometer: 145
Been very happy with the Galfer wave rotors
Peter
euromedic is offline   Reply With Quote
Old 09-10-2011, 09:18 PM   #6318
euromedic
Peter...n00b
Oddometer: 145
Fly-N-Cycle Dominator twin headlights inside the cowling, and Blazer International driving lights from O'Reilly Auto - $200 including wiring/switches/bracket materials
Going to fit some Plexiglas over the headlight opening to strengthen the cowling and protect the headlights.
Peter
euromedic screwed with this post 09-10-2011 at 09:33 PM
Old 09-11-2011, 03:32 AM   #6319
Gravel Seeker
Thomas
Gravel Seeker's Avatar
Location: Dreary old Norway, dreaming of adventures past
Oddometer: 3,979
Originally Posted by Don Coyote View Post
Well, they say 4 or 5 lower, so that is probably the same as the 91PON (AKI), or premium unleaded, that is common in the US.
My Dakar has a factory sticker on the filler cap that says minimum 87 AKI. Every source I've ever read says that you shouldn't gain anything from using higher octanes (unless maybe altitude or ambient temp are factors?). Thes makes me wonder, is BMW doing something different to 650s sold in the Americas than they do those sold in the rest of the world? I imagine German 650s are capable of benefiting from the higher octane fuels that are standard there. Is it just a matter of settings in the computer? If so, is it all handled automagically through the anti-knock sensor or something?
Guessing there is since the US bikes has the cannister. Must be additional things realted to that.
'01 F650 Dakar - modified as best I can
2005: Australia - 8 months/ 26.000 km (anti clockwise circle)
2009: Norway - 2 weeks/ 6000 km (Lindesnes to North cape)
Gravel Seekers.com
Hey !
It's the African ant eater ritual !
Gravel Seeker is offline   Reply With Quote
Old 09-11-2011, 03:33 AM   #6320
Gravel Seeker
Thomas
Oddometer: 3,979
Originally Posted by herrhelmet View Post
Here's a bracket I hacked together to use my iPhone4 as a speedometer. The Speedo has gps, completely configurable and real accurate. 99 plus the metal, velcro and cord.
I was using an old Garmin c340 as my instruments and it finally died.
It's alive !
Is that water, dust and mud proof ? Or legal for that matter
Gravel Seekers.com
Hey !
Old 09-11-2011, 03:28 PM   #6321
kaia
team F5 ⌘R
kaia's Avatar
Oddometer: 2,556
that looks awesome! could you possibly post some detail shots of the install? looks to be a nice and cheap alternative to the overpriced TT dual headlight install.
bike: 2010 KTM 990R | photos: SmugMug | SmugMug save $5: PeYEyWo3aVaYk
kaia is offline   Reply With Quote
Old 09-11-2011, 04:28 PM   #6322
kubiak
Oddometer: 4,810
yea the headlight setup looks great!
Old 09-12-2011, 07:00 AM   #6323
Linusp3
Linusp3's Avatar
Oddometer: 181
What App are you using for speedometer? Looks really nice!
Linusp3 is offline   Reply With Quote
Old 09-12-2011, 12:24 PM   #6324
herrhelmet
A Serious Man
herrhelmet's Avatar
Oddometer: 2,361
Sweet.
"Your bike is too heavy" www.motolithium.com TWITTER
herrhelmet is offline   Reply With Quote
Old 09-12-2011, 12:25 PM   #6325
herrhelmet
A Serious Man
herrhelmet's Avatar
Oddometer: 2,361
It's just called "Speedometer" the full version is 99
Old 09-12-2011, 02:05 PM   #6326
kubiak
Oddometer: 4,810
made a case saver for the dakar today. i used some flat metal and bent it around then welded two small pipes on the ends for the bolts to go through.
Old 09-12-2011, 02:06 PM   #6327
kubiak
Oddometer: 4,810
another angle
Old 09-12-2011, 03:39 PM   #6328
kubiak
Oddometer: 4,810
i got a question, i got a 15 tooth countershaft sprocket to lower the dakar gearing but now looking for a bigger rear sprocket. what are you guys using on the rears?
Old 09-12-2011, 04:30 PM   #6329
euromedic
Peter...n00b
Oddometer: 145
A detail image of the setup:
A bit prototypical, but its solid so far...
Peter
Old 09-12-2011, 10:27 PM   #6330
Renaissanceman
DON'T PANIC!
Renaissanceman's Avatar
Oddometer: 186
I tried a 15/49 combo for a little while but found it to be too low for my habits - mostly high speed commuting. I've run a 15/47 and I'm currently running a 16/49 setup.
Not much diff between the 15/47 and the 16/49 IMHO. Interesting article over at f650dotcom -
http://faq.f650.com/FAQs/SprocketsOt...20The%20Theory
I'll probably go back to the 15/47 based after I wear out this set.
Renaissanceman is offline   Reply With Quote
Times are GMT -7.   It's 09:50 PM.
