Old 12-20-2011, 01:48 PM   #7066
tmotten
tmotten's Avatar
Oddometer: 2,282
Interesting cover. Any details?
I only changed the bottom fitting. The oil tank is unchanged. No issues with pressure. Only becomes an issue when it's blocked, but the last thing you should worry about than is the oil hose. I simply reused the old banjo and had an elbow and 1/2" barb silver soldered on to it. Any hydraulics shop should be able to do it. Bread and butter work for them. In hindsight I reckon it's overkill though. As I said, you can get the OEM tube flared where you cut it, like it is on the oil tank, and with a hose clamp should be ample to hold the tube on. It's not massive pressure so flaring it might even be overkill. I routed it forward because that give maximum space getting the cover off and more importantly on which is the hardest.
I wouldn't go with a stainless tube to be honest. Most are rated for fuel (not the same) and you can't inspect the state of the rubber which can get hard and than brittle and the rest should be obvious. It rubs the paint of the case as well where it touches. Notice how I had to clamp it onto the water pump barb to keep it off the exhaust.
tmotten is offline   Reply With Quote
Old 12-20-2011, 05:37 PM   #7067
mattomoto
2 wheels rule
mattomoto's Avatar
Oddometer: 859
Me? Which cover?
I like the looks of your ss line better though. I just got some high pressure oil line from the local Napa auto store. Green in color but whatever. Works. I did not flare the steel line after I cut it but marked it with a Sharpie and kept an eye on it. Has not moved in 5000+ miles.
Matto
mattomoto is offline   Reply With Quote
Old 12-20-2011, 07:07 PM   #7068
tmotten
tmotten's Avatar
Oddometer: 2,282
Yeah, didn't look right. Was a bit rushed this morning and thought you had those removable clutch covers.
That steel tubing sucks I reckon. Good day in the dust or mud and it won't look like that, and everything else it black anyway.
Old 12-20-2011, 07:18 PM   #7069
mattomoto
2 wheels rule
mattomoto's Avatar
Oddometer: 859
Ha, thought maybe you meant my "customized" scratches on the cover
Matto
Old 12-21-2011, 08:38 AM   #7070
littlebull
tiny mighty mo
littlebull's Avatar
Oddometer: 307
Tires
One more question...
I am currently running Anakees on my '07, but want to change them to D606s this spring. The fork bridge makes things look a little tight. Do I need to modify anything to run the knobbies? It looks like there may be spacers on the bridge. Any advice before I do the change up?
Any advice is appreciated.
Kim
Ever notice that "what the hell" is always the right decision?
_________________________________________
09' 450EXC
07' F650GS Dakar
littlebull is offline   Reply With Quote
Old 12-21-2011, 09:34 AM   #7071
kubiak
Oddometer: 4,115
Kim
my 02 dakar had dunlop d606s on it with no problems with the fork brace. it was pretty close but still had a little clearance.
Old 12-21-2011, 01:07 PM   #7072
littlebull
tiny mighty mo
littlebull's Avatar
Oddometer: 307
Thanks, Kubiak. Unless I hear otherwise, the knobbies are a go. I've used these on my other bikes and am looking forward to getting them on the Dakar. It likes the dirt best!
09' 450EXC
07' F650GS Dakar
Old 12-21-2011, 05:11 PM   #7073
kubiak
Oddometer: 4,115
yea mine had a set of 606s when i bought it, i now have the yz inverted forks. at the most if it was so close you could add a few washers under the brace i would think.mine had the stock spacers and i took them out and the knobbies still fit. good luck!
Old 12-24-2011, 09:00 PM   #7074
Kainic
Almost there
Kainic's Avatar
Oddometer: 305
Originally Posted by twinrider View Post
Cobbled together in about 20 minutes using a saw, hammer, vice and drill. Besides being tucked in, another nice point is that it turns with the wheel, unlike the stock headlight.
Does your lightbar vibrate when the bike is running? Any chance you listing the dimensions?
Kainic is offline   Reply With Quote
Old 12-24-2011, 10:00 PM   #7075
twinrider
pass the catnip
twinrider's Avatar
Oddometer: 7,567
Originally Posted by Kainic View Post
The bracket looks excellent.
Looks like 4 inch aluminum stock? What brand of lights are you running?
Sorry I missed your earlier post. I bought the lights in the vendor forum here and they turned out to be garbage, bought six and all broke, some within days, others lasting longer but eventually dead within months. Now I'm using similar looking ones bought directly from the OEM maker that are built to higher specs (more robust drivers and leds) and they're holding up much better. Cheaper as well. Check them out here, they're having a Christmas sale. http://24x7diy.com/specials.php
Don't notice any vibrations, will post up some measurements later.
twinrider screwed with this post 12-24-2011 at 11:51 PM
twinrider is offline   Reply With Quote
Old 12-25-2011, 02:40 AM   #7076
Bikenstitches
Bikenstitches's Avatar
Oddometer: 345
Thanks for the tip tw; I've been looking for a reasonably priced set and this looks like the ticket.
Tom
05 F650 Dakar
04 WR250F
75 Montesa 247
65 Norton 650ss
Bikenstitches is offline   Reply With Quote
Old 12-25-2011, 03:39 AM   #7077
guavadude
de-composer
guavadude's Avatar
Oddometer: 317
The 24x7 lights look good. What model do you recommend? Any additional tips...relay, switch etc?
guavadude is offline   Reply With Quote
Old 12-25-2011, 06:27 AM   #7078
twinrider
pass the catnip
twinrider's Avatar
Oddometer: 7,567
For the Dakar I recommend the 4 high power Cree XPG R5 leds. They're bright but only draw 40 watts for the pair so they leave you with enough juice leftover to simultaneously power heated gear and grips.
http://24x7diy.com/product_info.php/products_id/194
But if you don't care about conserving juice and don't mind spending more, these 3000 lumen 4 high power Cree XML T6 leds are the ultimate in brightness with a total 60 watt draw for the pair.
http://24x7diy.com/product_info.php/products_id/94
For wiring I used a Piaa 74040 harness that includes a relay and a waterproof illuminated switch, but just about any harness will work.
Old 12-25-2011, 06:33 AM   #7079
twinrider
pass the catnip
twinrider's Avatar
Oddometer: 7,567
Always happy to help a fellow CTer, lots of good memories growing up in Farmington.
Old 12-27-2011, 07:57 AM   #7080
rmarkr
Squatter
rmarkr's Avatar
Oddometer: 349
Pelican Cases
Lost one of my stock cases - this seems to work. Size is about midway between the expanded and collapsed OEM box. This is the Pelican 'storm' case. Its a bit lighter and cheaper than the regular case.
I laid up a fiberglass panel for the cutout. Mounts to the stock hangers.
Happy Holidays!
rmarkr is offline   Reply With Quote
Times are GMT -7.   It's 10:56 AM.
