Old 02-28-2012, 02:35 PM   #7546
kubiak
Oddometer: 4,845
Originally Posted by Parx400 View Post
with the 48mm forks mine cant go out side of the forks. At full lock to the left it pushed the cable and pulls the TB open just a hair. I cant seem to fix it.
yea i actually tried to redo mine today and i think im going to leave it under the bar between the bar clamps. the throttle is smooth and snaps back nice the way it is.
Old 02-28-2012, 05:40 PM   #7547
Dan Alexander
Ride Far - Ride Fast
Dan Alexander's Avatar
Oddometer: 7,716
The previous owner of my 2007 Dakar had the suspension, front and back rebuilt by Sasquatch but the rear spring is still too soft to get proper sag.
The guy was told that the Hyperco spring that was used was the stiffest available. I emailed Sasquatch but haven't had a resonse to my question as to what spring was used
I found this chart for Hyperco springs but I don't know which one to order as I'm not sure of the shock body size or spring length.
I'm 240 without gear.
Can anyone point me in the right direction?
http://performanceshock.com/index/ma...ort=20a&page=2
Beemers Past and Present: 74 R90S, 77 R100RS, 85 K100RS, 2x 87 K100RS, 96 R1100GS (getting hacked), 99 R1100S, 2002 R1150GS, 2005 F650 Dakar, 81 GL500/Velorex
Plus the occasional Triumph, BSA, Yamaha, Honda, Suzuki and KTM but who's counting
Dan Alexander is offline   Reply With Quote
Old 02-28-2012, 09:28 PM   #7548
Notnewchevy
Oddometer: 69
Question crash bars, engine and plastic protection
There are a few options for protection. Can anyone tell me what is the best, ito. I like simple and clean. I've looked at the bmw bars but darn they are heavy. Thanks
Notnewchevy is offline   Reply With Quote
Old 02-28-2012, 09:49 PM   #7549
alskee750
alskee750's Avatar
Oddometer: 518
TT fairing..
Anyone have this http://www.touratech-usa.com/Store/P...w-F650GS-01-04 if so can you tell me if the lights are better and how is the wind protection?
Also is there anyone on this list that does bolt on fairing that are taller and one can hook up a gps, etc?
Thanks..
Alex
alskee750 is offline   Reply With Quote
Old 02-29-2012, 12:13 AM   #7550
twinrider
pass the catnip
twinrider's Avatar
Oddometer: 9,500
Alex
I had Touratech's similar headlight on my 1100GS and boy did it suck. The light output was mediocre and after I upgraded to bulbs that were the same wattage but brighter the headlight reflectors melted because they were made of cheap chromed plastic instead of glass.
2014 350 EXC-F
2011 XT1200Z
2009 FLHR
2006 Djebel 250XC
twinrider screwed with this post 02-29-2012 at 04:08 PM
twinrider is offline   Reply With Quote
Old 02-29-2012, 01:22 AM   #7551
RDT953
RDT953's Avatar
Oddometer: 288
I'm considering this
Thanks..
Alex
http://www.britanniacomposites.com/
RDT953 is offline   Reply With Quote
Old 02-29-2012, 05:31 AM   #7552
redbastard
redbastard's Avatar
Oddometer: 1,131
Brittanic composits / TT lights
Just thought I'd put the pictures up of the Britania composits fairing and the Touratech projector been headlight.
redbastard is offline   Reply With Quote
Old 02-29-2012, 05:58 AM   #7553
GSBS
FunHog
GSBS's Avatar
Oddometer: 3,972
That looks good!
GSBS is offline   Reply With Quote
Old 02-29-2012, 11:45 AM   #7554
LoJack
LoJack's Avatar
Oddometer: 1,618
The fairing is ok for buffeting, but if you are over 6' tall it might not offer any protection at all. I like the lights a lot, but the rubber boots on the back sides are starting to crack a little. Haven't looked into replacements yet. I might just coat them with some rtv.
Thanks..
Alex
LoJack is offline   Reply With Quote
Old 02-29-2012, 07:10 PM   #7555
Pootrol
Oddometer: 102
Rear Brake master rebuild
Hi guys,
Just been scaling the web (chain gang, here, etc) for some sort of guide for replacing the seals on the brake master cylinder.. i was going to get someone to do it, but the local dealer wants $170ph labour fee.. i've got the parts. have the tools.. i have it apart but not quite sure about how to do it..
Pootrol is offline   Reply With Quote
Old 02-29-2012, 09:51 PM   #7556
Skelt
Skelt's Avatar
Oddometer: 175
The rebuild kit for my Dakar was only $11.00 from the dealer. Only 2 O rings and a seal, took about 15 min.
"Artificial Intelligence is no match for natural stupidity"
2007 R1200GS
1995 R1100GS
2001 F650 GS/Dakar
Skelt is offline   Reply With Quote
Old 03-01-2012, 05:18 AM   #7557
FinlandThumper
Has Cake/Eats it Too
FinlandThumper's Avatar
Oddometer: 8,331
That is really beautiful setup from Britania. It seems that you have a dual spark model, but do you know by any chance if the mounts work also on the single spark models? If not or you don't know, I'll just contact them myself but was curious.
FinlandThumper is offline   Reply With Quote
Old 03-01-2012, 05:23 AM   #7558
divimon2000
divimon2000's Avatar
Oddometer: 628
I just put the TT faring guards on last night (SS). Nice looking. I will admit of the last 3 TT items I installed, NONE fit right out of the box. QC is going down hill. This one just had buggered bolts, other ones (engine guard had to re drill holes, etc)
divimon2000 is offline   Reply With Quote
Old 03-01-2012, 05:23 AM   #7559
FinlandThumper
Oddometer: 8,331
I have the stock BMW one. It is heavy, you're right, and it only protects the engine. It's okay...it came on mine and since I don't ride off road or care about weight I won't change it.
A friend runs the TT ones and likes them, but notes that the fairing crash bar is bolted only at the front. I have seen photos showing that if the bike drops hard enough the bar will bend enough that your fairing might get damaged anyway. He is satisfied with the lower engine bar.
Wunderlich makes one which is not so pretty, but bolts securely and is wide enough that it will prevent damage also to the fairing if it falls. Problem from my perspective is that it isn't so cool looking...kind of looks like crash bars for a Harley.
Finally, Holan makes a nice-looking bar that looks like the TT setup but has a back mount which makes it more rigid. You might want to check them out. I don't know anyone who uses their product.
Hope that helps.
Old 03-01-2012, 05:30 AM   #7560
divimon2000
Oddometer: 628
Kubiak, See the little connector thing on the handlebar for the throttle cable. My GS does not have that, I just cable tied it down lower. Just an fyi.
Times are GMT -7.   It's 02:21 AM.
