Old 03-12-2012, 02:03 PM   #7621
Gravel Seeker
Thomas
Gravel Seeker's Avatar
Location: Dreary old Norway, dreaming of adventures past
Oddometer: 3,982
Originally Posted by Parx400 View Post
This one has a yellowish fuel light. What resistor did you have to use? Is it the same one people used for the turn signals? Cause I have a few of those.
Not sure about which one I used for the oil/ charge LED, but might've been 100ohm 3W since I've scribbled that down here.
I have LED turn signals and don't have a resistor on those, but I've replaced the relay many years ago because I went with 21W bulbs in the original turn signals instead of the OEM 10W. When I went to LEDs they just worked so smiles all around.
'01 F650 Dakar - modified as best I can
2005: Australia - 8 months/ 26.000 km (anti clockwise circle)
2009: Norway - 2 weeks/ 6000 km (Lindesnes to North cape)
Gravel Seekers.com
Hey !
It's the African ant eater ritual !
Gravel Seeker is offline   Reply With Quote
Old 03-12-2012, 04:11 PM   #7622
tmotten
Lefthand ride Dutchy
tmotten's Avatar
Oddometer: 2,465
S0 I am installing one of these on a rallye style dash I'm making.
http://www.touratech-usa.com/Store/P...ED-Dash-Lights
My turn signals are already LED plus I have an LED flasher, I will not need a resistor for that. How about the rest of the lights?
Also I plan to run a Vapor with this. Were you guys able to use the BMW Tach wires with it?
I was hoping to make my own one with a DIY carbon box and some LED bezels and 12V LED's in various colours from ebay. Those LED's have a resistor built in to work with 12v. Are you guys saying additional resistors are required as with the fuel light (I think it was a fuel light. Been somewhat removed from this build for a while)?
How did you guys hook this into the OEM wiring? Cut the existing connector to the dash off and solder them straight to the wiring, or has someone found the male part of the OEM connector?
tmotten is offline   Reply With Quote
Old 03-12-2012, 04:47 PM   #7623
Parx400
Oddometer: 1,743
I'm going to cut the oem connector off and solder all the wires to it. That way I can un plug it.
Parx400 is offline   Reply With Quote
Old 03-12-2012, 10:00 PM   #7624
redbastard
redbastard's Avatar
Oddometer: 1,125
a wet woods ride
http://www.youtube.com/watch?v=025Xc...&feature=share
a wet woods ride on my modified Dakar. I was getting held up by a DRZ400 but what can you do.
redbastard is offline   Reply With Quote
Old 03-13-2012, 10:11 AM   #7625
FinlandThumper
Has Cake/Eats it Too
FinlandThumper's Avatar
Oddometer: 7,520
Last weekend I put the bike together for spring. I meant to lube the wheel bearings, which though they are sealed can be opened carefully. For three of the five total bearings (sprocket carrier has one also) this was no challenge.
The bearings for the Dakar and gs models are 17x40x12 bearings. Each bearing has a seal which can be removed wi a small flat blade screwdriver. Simply work the flat blade on the inside edge, where a small rubber part is located and very gentle pressure brings it up without damaging the seal. Grease was clean but a bit dry side (like all BMW bearings it seems), so I repacked the three. But in front of two, there was a second seal. The fiche:
http://www.maxbmwmotorcycles.com/fic...6&rnd=03252011
Referring to the parts fiche, I think this is the part 10, or shaft seal as25x40x7. At least, that is what I remember it saying and the wheel is back on the bike for now; this is luckily only a maintenance detail. I had a feeling that I was pushing too hard...so I decided to play it safe and ask how to do this.
Anyone have some insight on how I remove this shaft seal?
FinlandThumper is offline   Reply With Quote
Old 03-13-2012, 12:25 PM   #7626
Gravel Seeker
Thomas
Oddometer: 3,982
The TT LED bar came with a sugarcube type male and female plug with 12 holes
They also sell the plugs seperate: male and female - these are from the swedish webshop, but I'm sure you'll fint them in the english one too.
Gravel Seekers.com
Hey !
Old 03-13-2012, 12:44 PM   #7627
zakopiec
Oddometer: 4
I'm installing a tripmeter on my 01 dakar (no ABS) - can I use the wire to the dash (speed signal) - what are its properties? I dont want to mount another sensor on the front wheel.
zakopiec is offline   Reply With Quote
Old 03-13-2012, 03:51 PM   #7628
tmotten
tmotten's Avatar
Oddometer: 2,465
No worries. Sucks how companies cut deals with Tyco to prevent connector designs and arrangements be sold on the wider market.
Looks like TT assumes you to cut the OEM connector as well. What's that other plug?
tmotten screwed with this post 03-13-2012 at 08:02 PM
Old 03-13-2012, 07:44 PM   #7629
Road Rash
Infamous
Road Rash's Avatar
Oddometer: 18,678
I'm about ready to pull the trigger on this Remus exhaust, does anyone here have one with Jessie's, I think it will be fine, and I know I can modify if need be...............but would rather not.
"A man can never have too many motorcycles, like any good craftsman you need the proper tool for the job at hand. A man needs more tools than a hammer, the same goes for bikes." ~Mr. Cob~
My Ride Through Roatan
Road Rash is offline   Reply With Quote
Old 03-14-2012, 12:49 AM   #7630
ferals5
865+652
ferals5's Avatar
Oddometer: 1,127
The wheel bearings are SKF 6203 and the sprocket bearings are 6204 both cost around $5 ea here in Oz, very common bearing your local bearing or engineering shop should have them on the shelf. Seals are both 30x40x7 about $2 here. Seals just pop out with a bit of encouragement
oh and there are only two wheel bearings and two carrier bearings not sure how you get a fifth one in there
ferals5 screwed with this post 03-14-2012 at 12:54 AM Reason: fifth bearing ?
ferals5 is offline   Reply With Quote
Old 03-14-2012, 03:49 AM   #7631
Benjah
Oddometer: 142
I agree but when I think about gain/cost ratio this high fender thing is sort of a must, I think...
Or may be I was too much fed up with the mud.
Most definitely good value for money. It works and looks better than stock. It's even better after you do the fork swap as a nice new Yamaha front guard bolts right on - no need for brackets or drilling extra holes.
Benjah is offline   Reply With Quote
Old 03-14-2012, 06:04 AM   #7632
Ed Teach
Ed Teach's Avatar
Oddometer: 175
Originally Posted by duroturk View Post
Mounted and tested. Result is awesome. May be the best mod for Dakar!
What model of Acerbis is that fender? Is universal or specific for a bike?
Ed Teach is offline   Reply With Quote
Old 03-14-2012, 11:59 AM   #7633
Gravel Seeker
Thomas
Oddometer: 3,982
The other plug connects to the printcard on the IMO. It's where it receives the signal to flash the gear change warning light I think. You need the IMO50 rallye for this function and I mine is the 100R300.
Gravel Seekers.com
Hey !
Old 03-14-2012, 01:42 PM   #7634
FinlandThumper
Oddometer: 7,520
Yeah, sorry I somehow counted to six wrong and got five. I was including the front wheel (two bearings up there) but then forgot the sprocket carrier has two bearings.
So you are saying the shaft seals outside the bearings (two seals, one on front opposite the disc, one on rear) can be popped off with more effort? Larger tool maybe, like a tire iron? (the seal I mean is not the seal on the bearing itself, but rather a seal in front of the bearing)
Thanks for the part numbers in any case!
Old 03-15-2012, 01:52 AM   #7635
ferals5
865+652
ferals5's Avatar
Oddometer: 1,127
Two seals on the rear.
Rear wheel hub seal is outside the bearing on the left side just lever it out gently with a screwdriver( the seal surface bush just pulls out), the sprocket carrier seal is on the right side outside the bearing and also runs on a bush ( #3 in the fiche) which needs to come out as well. This seal surface bush sits over the axle bush #8 and is a little harder to pull but should come out easy enough. Bearing replacement is not hard but they are knocked out in order from the outside to inside exiting at the cush drive, inner bearings first, then circlip, then outer bearings.
cheers
Mark
Times are GMT -7.   It's 12:03 AM.
