Old 03-15-2012, 08:54 AM   #7636
isgila
isgila's Avatar
Oddometer: 109
Pissed Handlebar control switches
Good day inmates,
my switches are cracking and hate the oem integrated type switches...
in need of some advice pls
- there are info on thumpertalk that you can use a kill switch as a starter switch, is this possible?
- can I solder the oem kill switch togather to eliminate once and for all since I always use my ignition switch
- can the oem throttle cable be use with domino or other throttle that does not integrate with others
- is there a generic headlight/turn/horn switch I can use other than oem
Thank you for your inputs.
isgila is offline   Reply With Quote
Old 03-15-2012, 09:25 AM   #7637
Parx400
Oddometer: 1,745
Go to hyway dirt bikes. You can get a starter/ on/off billet switch and then change the throttle to an mx style one.
Parx400 is online now   Reply With Quote
Old 03-15-2012, 09:26 AM   #7638
Parx400
Oddometer: 1,745
TT Skid plate
What type of aluminium is the TT skid plate made of? I need to get some aluminium to make brackets out of but I don't know what type to ask for.
Old 03-15-2012, 11:38 AM   #7639
Gravel Seeker
Thomas
Gravel Seeker's Avatar
Location: Dreary old Norway, dreaming of adventures past
Oddometer: 3,985
Not sure, but it's soft enough that mine has a huge dent in the rear and I haven't even noticed hitting anything
'01 F650 Dakar - modified as best I can
2005: Australia - 8 months/ 26.000 km (anti clockwise circle)
2009: Norway - 2 weeks/ 6000 km (Lindesnes to North cape)
Gravel Seekers.com
Hey !
It's the African ant eater ritual !
Gravel Seeker is offline   Reply With Quote
Old 03-15-2012, 05:11 PM   #7640
mr. matteeanne
Bender can pass him
mr. matteeanne's Avatar
Oddometer: 14,342
Can someone tell me the proper way to check the oil on an 04
What flavor oil is preferred? Dino or Synth?
Don't be surprised.
mr. matteeanne is offline   Reply With Quote
Old 03-15-2012, 06:21 PM   #7641
kubiak
Oddometer: 4,829
on my 02 dakar i make sure the bike is all the way warmed up like after a ride then dont turn the motor off but hold the bike upright and let idle for a few minutes then look at the sight glass. i leave mine right in the middle of the sight glass. if you dont have the bike all the way warmed up it will read low then if you fill to the right level then it will be over filled when warmed all the way up.
kubiak is online now   Reply With Quote
Old 03-15-2012, 06:23 PM   #7642
kubiak
Oddometer: 4,829
i forgot to mention i use dino 10-40 all year round too. my bike had synthetic when i bought it and the clutch would slip in high gear on the throttle hard. now with dino the clutch works great with no slipping at all.
Old 03-15-2012, 07:07 PM   #7643
mr. matteeanne
Bender can pass him
Oddometer: 14,342
I read that I need to remove the oil tank to drain it? Is this true? Any links to an oil change? It simply cannot be as tough as I have read?
Don't be surprised.
Old 03-15-2012, 07:14 PM   #7644
tomatoe333
tomatoe333's Avatar
Oddometer: 2,292
Not true, just put the bike on the sidestand and take the drain screw out of the oil tank. It'll all drain out.
See http://f651.com/faq/GSFAQs/GS_Oil_Change_FAQ.htm (why did it move from f650.com ??) for the full procedure.
"Keep the standard settings will be useful to learn more about the bike. One should reach a sufficient technical level, when then humbly questioning calibration of your motorcycles."
tomatoe333 is offline   Reply With Quote
Old 03-15-2012, 07:25 PM   #7645
mr. matteeanne
Bender can pass him
Oddometer: 14,342
Where to get parts? I saw a "kit" was available? Filter, o-ring etc, whats a good source from USA?
Don't be surprised.
Old 03-15-2012, 10:31 PM   #7646
Don Coyote
Don Coyote's Avatar
Oddometer: 1,287
maxbmwmotorcycles.com part #11117658311 currently $16.75
It comes with an extra crush washer that fits the OEM forks, so save it and you can do the forks after every 2 oil changes. Annealing the crush washers seems to work fine, tho.
'06 F650GS Dakar
Those who believe you should always error on the side of caution usually become comfortable making errors and before too long know of little else.
Don Coyote is offline   Reply With Quote
Old 03-15-2012, 10:42 PM   #7647
Don Coyote
Don Coyote's Avatar
Oddometer: 1,287
The Chain Gang is going through some server and ownership changes right now.
Just drained the oil a couple of hours ago. I undid the oil tank (one bolt and 2 clips) and it seemed there was quite a bit that still came out as i twisted the tank in various directions. I think my waterpump seals have been letting coolant into the engine, so i wanted to be sure to get as much out as i could...
'06 F650GS Dakar
Old 03-15-2012, 11:23 PM   #7648
Don Coyote
Don Coyote's Avatar
Oddometer: 1,287
Does anyone know if the BMW warning against using API SJ compliant oils has been completely dismissed as marketing BS? The best i could find shopping today was a brand that listed SG/SH/SJ which BMW apparently said was Ok even though it is still SJ compliant, then i got home and noticed i had filled up last fall with regular SJ oil...
'06 F650GS Dakar
Old 03-15-2012, 11:39 PM   #7649
alfabc
Oddometer: 212
I use a vacuum pump to suck the oil out of the top tank. Use a flexible hose, make sure to get into all the nooks and crannies. Viola, not mess! I actually think you get more gunk out of the top tank that way. Just make sure the oil is up to temp before vacuuming out. That way, it flows better and will have all the nasty bits suspended in the oil when you pump it out. Then, just drain the bottom as per regular, replace the filter, and add new oil.
Bill
2001 BMW F650GS
alfabc is offline   Reply With Quote
Old 03-17-2012, 05:30 PM   #7650
Parx400
Oddometer: 1,745
Anyone have a non Dakar kick stand laying around I could buy?
Times are GMT -7.   It's 05:38 PM.
