03-20-2012, 12:06 AM
#7666 | |
Has Cake/Eats it Too
Oddometer: 4,246
03-20-2012, 12:13 AM
#7667 |
Oddometer: 104
Handlebar switches
Thank you Parx400 for the info on highway dirtbike. Any other info about an mx throttle to use?
Do i need a custom cable to use? Any one have fitted a mx throttle. Part no and company name pls. Thanks |
03-20-2012, 12:59 AM
#7668 |
beginner
Oddometer: 32
Hi,
i got some hella headlights (could not resist the temptation they were pretty cheap comparing to 'serious' 100$+ lights) and now i am looking for the wiring scheme as these lights are just light with brackets. Do they go directly to the battery at one wire and to switch at another wire? How this pair of lights should be connected (parallel or one-after-another in the electrical chain)? TIA
Kasoo
03-20-2012, 06:24 AM
#7669 | |
Oddometer: 2,083
Especially, no luck when I broke one off in rural Ontario, and went to 4 different dealers to try to find one.
"Give big space to the festive dog that makes sport in roadway. Avoid entanglement of dog with wheel spokes." |
03-20-2012, 07:31 AM
#7670 | |
Oddometer: 4,235
03-20-2012, 07:33 AM
#7671 |
Oddometer: 4,235
i was thinking since the brake is brembo maybe it might be easier but i havent gone to the dealer to check yet. and the clutch i might end up using a aftermarket lever assy. at the worse case i can polish the stockers i guess!
03-20-2012, 07:39 AM
#7672 |
Oddometer: 2,083
I'd be looking at a Domino throttle. I'm not sure of a part number, but they make a "fast turn" and a "slow turn" version (1/8 and 1/4 turn). They seem to be the de facto standard on European dirt bikes at least. You want the 2-stroke version, which is a single pull cable, rather than the 4-stroke push-pull version.
03-20-2012, 08:41 AM
#7673 | |
Oddometer: 1,066
http://www.ohsmotorsports.com/p-3645...rt-226385.aspx |
03-20-2012, 10:00 AM
#7674 |
So I'm very close on pulling the trigger on a new Sertao and thought I would ask you fine gentleman your thoughts on the 650. From my research its a Dakar only without the name,
Is there anything that I should be warned about or any must have upgrades? Thanks Ken
I am a leaf on the wind, watch me.....ride (I know, it makes no sense) ![]() 2007 YZ 250F SOLD ![]() 1998 KTM 620 Adventure 2004 KTM 200 EXC |
03-20-2012, 10:31 AM
#7675 |
Oddometer: 2
Rear Fork Decal for Chain
What a pleasure to see the F650GS Dakars!!
I just repainted my '05 Dakar frame components and now require the unavailable schematic decal on the right side of the rear fork to show the chain adjustment. Can anyone please snap a high quality shot of this area up close and post it so that I can digitize it for a replacement? Tried the dealer and it's not available but a local sign shop says it can be done. TIGMaster |
03-20-2012, 10:37 AM
#7676 |
Oddometer: 914
Most of us here like em, which is why we are here. There are farkles galore, but as is, the stock suspension is ok. Lot's of mods for that one simple or not so simple. Just changing the oil weight, I hear, helps with the forks. Or you can put on a YZ front end, and I believe there is a kit that lets you keep your ABS from someone here. Put on some knobbies and they are pretty good in the dirt, though no real dirtbike without some serious mods.
Personally, I did a 10k mile trip two-up a few years back. Had that thing loaded down The only thing was going through rear tires and breaking an excel rim. The rest of it performed great, but I ride it solo now.Did they solve the water pump problem with the Sertao? Or at least make it easier to replace? Lojack |
03-20-2012, 11:11 AM
#7677 |
Oddometer: 2,083
I think they at least re-routed the troublesome oil line, so it's easier to get the side cover off.
03-20-2012, 01:17 PM
#7678 | |
I am a leaf on the wind, watch me.....ride (I know, it makes no sense) ![]() 2007 YZ 250F SOLD ![]() 1998 KTM 620 Adventure 2004 KTM 200 EXC mtbdemon screwed with this post 03-20-2012 at 02:21 PM |
03-21-2012, 12:00 AM
#7679 | |
Thomas
Location: Dreary old Norway, dreaming of adventures past
Oddometer: 3,430
If you can't get a deal on a pre owned Dakar
'01 F650 Dakar - modified as best I can 2005: Australia - 8 months/ 26.000 km (anti clockwise circle) 2009: Norway - 2 weeks/ 6000 km (Lindesnes to North cape) Gravel Seekers.com Hey ! It's the African ant eater ritual ! |
03-21-2012, 12:04 AM
#7680 | |
Thomas
Oddometer: 3,430
Pipe can be modified/ re routed when you do the first waterpump replacement and problem solved.
