Old 05-30-2012, 01:32 AM   #8326
Sparqq
Oddometer: 67
@Kubiak
Did you moved the oxygen sensor that is mounted in the air snorkel?
Sparqq is offline   Reply With Quote
Old 05-30-2012, 08:08 AM   #8327
kubiak
Oddometer: 4,829
Originally Posted by KG6BWS View Post
Thinking of doing the same. Dont want the TT stand cuz I want to put on a centerstand. Does it hang down below the frame rails any more compared to stock location??
it may hang down a extra half inch or so because of the angle of the base welded on. not bad though.
kubiak is online now   Reply With Quote
Old 05-30-2012, 08:10 AM   #8328
kubiak
Oddometer: 4,829
Originally Posted by tmotten View Post
Is that the stock footpeg bracket all cut back?
I was thinking along the same lines with the stand, but I decided to remove the bottom frame all together in the near future. So got a YZ trail tech stand and footpeg bracket and weld that onto the OEM bracket.
its the stock foot peg bracket but i drilled lightning holes in it. knocked off about a quarter lbs.
Old 05-30-2012, 08:13 AM   #8329
kubiak
Oddometer: 4,829
Originally Posted by Sparqq View Post
@Kubiak
no i jst moved the big oxygen sensor connector that is zip tyed to the bottom frame rail along with the kickstand safety switch. im trying to clean up all the clutter on the bike as i drop weight too.
Old 05-30-2012, 08:14 AM   #8330
kubiak
Oddometer: 4,829
Originally Posted by Aquatic View Post
Looks great Kubiak, wish I had your TIME.....
poor kubiak has no money!
Old 05-30-2012, 08:20 AM   #8331
Don Coyote
Don Coyote's Avatar
Oddometer: 1,276
Time to liquidate. You just might find someone around here interested in buying that horribly mutilated 650GS...
'06 F650GS Dakar
Those who believe you should always error on the side of caution usually become comfortable making errors and before too long know of little else.
Don Coyote is offline   Reply With Quote
Old 05-30-2012, 08:39 AM   #8332
Don Coyote
Don Coyote's Avatar
Oddometer: 1,276
Has anyone removed their swingarm while following the FAQ at f650.com? I'd like to know if there are any tools/parts/steps needed that aren't mentioned there, since it looks like it was written for the funduro. Is the single spark shop manual as good/better for a reference?
'06 F650GS Dakar
Old 05-30-2012, 09:05 AM   #8333
Aquatic
Aquatic's Avatar
Oddometer: 1,587
I took mine off without any manual or f650.com.
It is relatively easy if you have a set of sockets and some spanners.
There is only 1 bolt that is a bit iffy. On the way out it interferes with the chain roller bracket(on a Dakar). But definately not impossible to get out.
It's the one on the right in the picture
Aquatic is offline   Reply With Quote
Old 05-30-2012, 09:20 AM   #8334
kubiak
Oddometer: 4,829
yea i was wondering if i did ever sell the gs if its too chopped up for everyone, i plan on keeping it for a long time unless someones got a x challenge for trade!
Old 05-30-2012, 10:06 AM   #8335
Don Coyote
Don Coyote's Avatar
Oddometer: 1,276
I'll be doing the work in the street and this is my only motor transportation, so i need to know i have everything to get the job done in a few quick sessions. My socket set is minimal, only up to 18mm, looks like 2 22mm ones are needed?
I assume you're using the Queen's english for 'spanners', meaning regular (but metric) wrenches in Ameriglish?
'06 F650GS Dakar
Old 05-30-2012, 11:07 AM   #8336
LoJack
LoJack's Avatar
Oddometer: 1,571
DC, I should have some sockets you can borrow. Let me know. You can also use my driveway if you like.
LoJack is offline   Reply With Quote
Old 05-30-2012, 04:25 PM   #8337
Aquatic
Aquatic's Avatar
Oddometer: 1,587
Jeez, tough gig you got there. If you can wait another day, I will get you all the sizes tonight
Spot on olde chap, jolly good and all that!
Old 05-30-2012, 05:38 PM   #8338
isgila
isgila's Avatar
Oddometer: 109
Aftermarket throttle
Originally Posted by Parx400 View Post
I must say the Magura 312 throttle maybe one of the best mods I did to this bike. Take out all that slop and have a quick action throttle is great on this bike.
+1 on quick action throttle..
Its take out the slack in the response, cures my pop corn machine, no more high idling issues and wheelies easier..
Mine is a domino though...
isgila is offline   Reply With Quote
Old 05-30-2012, 06:16 PM   #8339
tomatoe333
tomatoe333's Avatar
Oddometer: 2,292
I think I used both as a reference when I did mine last year.
I don't remember it being very complicated. Basically remove the rear wheel, get the brake and chain guards off and out of the way, remove the suspension linkage, remove the bigass bolt through the pivot (took some hitting with a drift and a hammer). Assembly was the reverse of disassembly, with plenty of moly grease crammed into the bearings, and some anti-sieze smeared on the bigass bolt.
I removed the shock at the same time and sent it out to rebuilt, and getting the subframe and gas tank out of the way was a MUCH bigger bitch.
"Keep the standard settings will be useful to learn more about the bike. One should reach a sufficient technical level, when then humbly questioning calibration of your motorcycles."
tomatoe333 is offline   Reply With Quote
Old 05-30-2012, 07:06 PM   #8340
tmotten
Lefthand ride Dutchy
tmotten's Avatar
Oddometer: 2,465
You will need 2x 20mm sockets but I think that's in the FAQ. I also needed a 16mm crow foot spanner but that was for the linkage. Are you removing that as well?
tmotten is offline   Reply With Quote
Times are GMT -7.   It's 06:08 PM.
