Old 06-03-2012, 08:45 AM   #8371
yurihay
Oddometer: 17
Originally Posted by motogazonaktm View Post
Hi all
I am looking for a wiring diagram for the f650 twin spark.
Looking at a bike for a friend and cannot locate the wiring diagrams , it's driving me mad.
The bike has no blinkers or hazards.
Any help would be appreciated.
G
I'll email you a wiring diagram.
yurihay is offline   Reply With Quote
Old 06-03-2012, 09:02 AM   #8372
yurihay
Oddometer: 17
Sorry motogazonaktm,
Just realized that I've been using a single diagram on my 2007 Dakar. If this still helps, let me know and I'll email you the diagram, as I don't know if I can attach the diagram here.
Old 06-03-2012, 03:14 PM   #8373
Sparqq
Oddometer: 64
I usually buy my DID chain together with sprockets as a set on louis.de for around 100 Euros. This DID chain is in one loop.
Sparqq is offline   Reply With Quote
Old 06-03-2012, 03:36 PM   #8374
Bikenstitches
Bikenstitches's Avatar
Oddometer: 345
Originally Posted by twinrider View Post
I've seen a clip-style let go on an RMX250 traveling on the highway. I'll stick with rivet masterlinks...
I haven't thrown a master link. A key installation detail, after it's assembled, is to push the pins back in towards the chain, forcing the plate to lock against the clip. Wipe with some alcohol and dab a spot of silicone rubber over the pins and clip.
Tom
05 F650 Dakar
04 WR250F
75 Montesa 247
65 Norton 650ss
Bikenstitches is offline   Reply With Quote
Old 06-03-2012, 07:00 PM   #8375
Notnewchevy
Oddometer: 25
Overheating gs
So I am working on an 03 gs and the darn thing keeps blowing all its antifreeze out the overflow, overheating and the idiot light is coming on. . We have cleaned out the whole system including the thermostat, replaced the rad cap (i was hoping the spring got weak and was prematurely blowing off pressure). The waterpump is not leaking and the fan is coming on no problem. We have refilled the system burped out the air and had the local shop do it also all to no avail. Any ideas? Could the water pump be bad and not leak? Is there any way to check water pump flow? Any help will be greatly appreciated. We just got to get this thing fixed.
Notnewchevy is offline   Reply With Quote
Old 06-03-2012, 07:26 PM   #8376
Don Coyote
Don Coyote's Avatar
Oddometer: 820
Seem to remember reading about symptoms like this over at f650.com when the plastic gears on the water pump get munched. (No problem asking here, but you can draw on a wider base of experience for general issues there...)
'06 F650GS Dakar
"I never saw no miracle of science That didn't go from a blessing to a curse
I never saw no military solution That didn't always end up as something worse"
Don Coyote is offline   Reply With Quote
Old 06-04-2012, 08:06 AM   #8377
OceanMtnSea
Pretty Dogged
OceanMtnSea's Avatar
Oddometer: 442
Sounds like the plastic gears on the waterpump might be the issue. Pull the waterpump housing off and try to turn the impeller. If it rotates (with the the engine off) the gears are munched........solution change out the the waterpump and plastic gear.
2007 BMW Dakar & 2009 Ducati Multistrada entering the middle of the in-land sea called Saskatchewan Canada
http://s737.photobucket.com/home/OceanMtnSea
OceanMtnSea is offline   Reply With Quote
Old 06-04-2012, 08:16 AM   #8378
BeachGuy
Alabama & Costa Rica
BeachGuy's Avatar
Oddometer: 370
If you think you might have a cooling problem, then check out Trottlemiester little to do with his cooling woes in South America. See the link below. You’ll enjoy this.
http://www.advrider.com/forums/showp...postcount=1151
Fix the problem NOW.
BeachGuy
2010 Ride Report: Orange Beach, AL to Jaco Beach, Costa Rica
2011 Ride Report: Costa Rica to Panama back to Costa Rica
One of the beautiful things about riding solo is the quality of the social experience.
BeachGuy is offline   Reply With Quote
Old 06-04-2012, 09:31 AM   #8379
AeroMoto
Oddometer: 81
I've lost the master link clip from my chain. Does anyone have a suggestion on where to get a replacement? I just went to the local hardware store and I've had those clips fall off too.
AeroMoto is offline   Reply With Quote
Old 06-04-2012, 11:48 AM   #8380
isgila
Oddometer: 101
Head down to any bike shops and they will have lots of spares from used chains..
If he's selling it to you, he's ripping you off
isgila is offline   Reply With Quote
Old 06-04-2012, 04:48 PM   #8381
Parx400
Oddometer: 1,053
Any body parting a bike out soon? I'm looking for front panels.
Parx400 is offline   Reply With Quote
Old 06-04-2012, 05:21 PM   #8382
ShadyRascal
Master of None
ShadyRascal's Avatar
Oddometer: 5,050
I might be if I can't get a title issue resolved.
Originally Posted by Javarilla
Evolution, or, natural selection, has nothing to do with better.
It merely weeds out what is no longer suitable for the given context.
Originally Posted by Dragoon
I would rather be on my motorcycle thinking about God than in church thinking about my motorcycle.
ShadyRascal is offline   Reply With Quote
Old 06-04-2012, 05:29 PM   #8383
kubiak
Oddometer: 4,118
hey parx400 i have a right side front panel i might sell or trade out for parts.
Old 06-05-2012, 05:39 AM   #8384
Dirt Rover
Dirt Rover's Avatar
Oddometer: 29
Originally Posted by Gravel Seeker View Post
Need the 24mm if you wanna remove the CS sprocket
Mine is a 30mm that is on the counter-shaft. Do I have something funky going on?
F650GS Dakar
Ninja 650R
KTM 300 EXC
...foolish consistency is the hobgoblin of the mind. (Ralph Waldo Emerson)
Dirt Rover is offline   Reply With Quote
Old 06-05-2012, 08:55 AM   #8385
tomatoe333
tomatoe333's Avatar
Oddometer: 2,072
I'm looking for the front engine mount/shell piece that goes between the frame and subframe. Anyone got one?
"Give big space to the festive dog that makes sport in roadway. Avoid entanglement of dog with wheel spokes."
tomatoe333 is offline   Reply With Quote
Times are GMT -7.   It's 08:14 PM.
