Old 06-21-2012, 04:01 PM   #8506
Sparqq
Oddometer: 67
Originally Posted by Benjah View Post
www.motorworks.co.uk sell it.
http://www.motorworks.co.uk/vlive/Sh...BA_15_65_KA_70
I regularly buy stuff from them even though I'm in New Zealand. Great company.
Sorry but I don't see the part on there website, the bush on that page is a different one.
Sparqq is offline   Reply With Quote
Old 06-21-2012, 04:21 PM   #8507
Aquatic
Aquatic's Avatar
Oddometer: 1,571
Originally Posted by Sparqq View Post
I have a little problem with the BMW part supplies. I need a part that they don't supply any more, number 2 on the picture (33537650103):
The dimensions are;
length 23mm
outer diameter 18mm
inner diameter 10mm
Had the exact same problem
order part number - 33 53 7 650 099
Item 3 below. It is 2mm longer. It is hardened but can be turned in a lathe. Just removed 2mm from the length. Perfect
Aquatic is online now   Reply With Quote
Old 06-21-2012, 07:44 PM   #8508
JB_Pgh
Ewan wannabe
JB_Pgh's Avatar
Oddometer: 12
Just put my 03 Dakar up for sale in the flea market. Not commuting 100 miles a day anymore so it's just getting dusty.
JB_Pgh is offline   Reply With Quote
Old 06-21-2012, 09:40 PM   #8509
Nib
NIb
Nib's Avatar
Oddometer: 28
Snorkel job
Hack job on snorkel, sponge with toothpicks on inside and out.
Nib
NOVA Tag-O-Rama
Nib is offline   Reply With Quote
Old 06-21-2012, 11:46 PM   #8510
Sparqq
Oddometer: 67
@Aquatic
Thanks, I will order that part and change the length on a lathe.
Old 06-22-2012, 06:21 AM   #8511
divimon2000
divimon2000's Avatar
Oddometer: 614
uh.
divimon2000 is offline   Reply With Quote
Old 06-22-2012, 09:41 PM   #8512
kubiak
Oddometer: 4,810
finished a new front wheel build for the dakar. 2.15x18 rim on a yz hub with a 4.60x18 front tire. going to test it on the trails soon.
Old 06-22-2012, 09:43 PM   #8513
kubiak
Oddometer: 4,810
the tire barely fits between the yz forks, had to trim the fork gaurds a little.
Old 06-23-2012, 05:24 AM   #8514
Gravel Seeker
Thomas
Gravel Seeker's Avatar
Location: Dreary old Norway, dreaming of adventures past
Oddometer: 3,979
Originally Posted by BMacW650 View Post
FYI, I got these bad boys with built-in resistors. Also the fuel lamp wire does have to get through the ECU so maybe that was problem. Regardless, run a positive through an led and directly hook it up to the white plug under the seat works like a charm.
Your link won't load.
Dunno what's wrong, but all I did was cut off the bulb and hook up the LEDs. Didn't touch any wires south of the dash, so they are still running through whatever the German enginner decided they should run through.
Still planning on rebuilding the dash again I will try to inspect all wires more closely then, since I have had a few shorts over the years and battery acid has eaten away at all the protective wire-sheaths on the RHS of the bike
'01 F650 Dakar - modified as best I can
2005: Australia - 8 months/ 26.000 km (anti clockwise circle)
2009: Norway - 2 weeks/ 6000 km (Lindesnes to North cape)
Gravel Seekers.com
Hey !
It's the African ant eater ritual !
Gravel Seeker is offline   Reply With Quote
Old 06-23-2012, 05:33 AM   #8515
Gravel Seeker
Thomas
Oddometer: 3,979
Originally Posted by tmotten View Post
Tell that to my mrs that up until recently had a perfectly good bike
So far it's only been mine that I've worked on, but it won't stay like that. The abs is the other issue. I tried deactivating it to measure the voltage in the warning light circuit through both plugs, but there was nothing. Mrs wasn't amused.
Is Soloyosh still around? Old postings suggest he solved it but I havent heard anything recently.
Bah.... still have an ODO right ?!
In Oz I used 350km "safe range" on a tank. Knew I had a bit to go on still, but we had some bad gas a few places up north and down the west coast so milage dropped (the other carb'd bikes had to drain water from their carbs daily). Back here where the fuel is fuel and not water I consistantly get 25km/ ltr so 435,5km from 17,3 ltrs, but I usually try to get it refuelled at around 380kms (this is commuting on highway with T63 knobbies at 103 km/h or 88km/h average to and fro work every).
Btw, both my TT IMO copmuter and my Garmin Zumo660 has fuel odometres so that helps
Gravel Seekers.com
Hey !
Old 06-23-2012, 06:10 AM   #8516
Gravel Seeker
Thomas
Oddometer: 3,979
Originally Posted by Koponen View Post
Hi guys. I am brand new (and proud) -01 Dakar owner. Also first post at this forum.
I have question about progressive fork springs. Planning to buy, but dont know which ones. HyperPros or Wirth from Touratech, or something else?
Tell me something about these springs, and help me choose.
My new love
I ran the Wirth ones for many years and was very happy with them. They had no problem coping with 26.000 very hard kilometres with a heavy camping gear laden bike and a careless rider around Australia on anything from slick asfalt to extreme offroad.
Gravel Seekers.com
Hey !
Old 06-23-2012, 06:20 AM   #8517
Gravel Seeker
Thomas
Oddometer: 3,979
1. Not sure if I asked before, but what's the make and model (and link to it) of that new headlight of yours ?
2. I don't get putting on a smaller front wheel and throwing it offroad... shouldn't make it better on the trails than the 21" was
Gravel Seekers.com
Hey !
Old 06-23-2012, 10:54 AM   #8518
kubiak
Oddometer: 4,810
hi, the headlight is a polisport halo with the h4 halogen bulb. i got it off ebay. on the front wheel i rode supermoto for over 10 years and love the 17s but i still go offroad too so i thought i would try a smaller front knobby for both on and offroad i like the 19 inch idea but i wanted to run a 18 since there are more combos and cheaper prices than the 19. i ran a 17 front with dualsport tires and liked it too so now the 18s are getting a try. i have a rear wheel build im waiting for parts to arrive soon but dont want to say what it is till i get it built. its why i went with the 18 inch front too.
Old 06-23-2012, 08:53 PM   #8519
Mr.Dabalina
Mr.Dabalina's Avatar
Oddometer: 188
Just got a stock '05 Dakar with 10k miles on it. What are the first five things you would do to it? Tires are newer Tourance metzlers.
Mr.Dabalina is offline   Reply With Quote
Old 06-23-2012, 09:37 PM   #8520
Don Coyote
Don Coyote's Avatar
Oddometer: 1,255
  1. Fill it with gas.
  2. Ride it.
  3. Crash it.
  4. Look it over and fix anything important that is broken.
  5. Ride it more.
(Hopefully refilling it with gas would be make #3, but i tend to be a realist...;-)
'06 F650GS Dakar
Those who believe you should always error on the side of caution usually become comfortable making errors and before too long know of little else.
Don Coyote is offline   Reply With Quote
Times are GMT -7.   It's 05:07 AM.
