07-07-2012, 02:19 AM
#8626 |
Xventurous
Oddometer: 298
Ok, call me wacky...but I like the dual exhaust look of the Dakar/Sertao and feel it balances out the bike regardless of the excess weight of the false can/cat. My question is this:
Can a acutal fully functional dual exhaust be added to the Dakar/Sertao single that will help in HP, possibly save a bit of weight and still meet US restrictions? We don't ever have to actually smog our bikes do we i haven't yet). Im asking because Ive been looking at the Tenere 660 setup for quite a while as they were forced for the same reason I think to go dual.... Examples I've seen but have no real knowledge area; http://www.pureperformancecycles.com...-Tenere-XT660Z http://www.twowheelsblog.com/post/34...aha-tenere-660 Any thoughts. And pls forgive my ignorance and love for ascetics. |
07-07-2012, 02:28 AM
#8627 |
Oddometer: 64
A remus for F650GS twinspark will fit;
remus slip on |
07-07-2012, 03:59 AM
#8628 | |
50cc&652cc thumpers
Oddometer: 238
Nothing some carbon or glass fibre couldnt fix though :P |
07-07-2012, 04:21 AM
#8629 | |
FunHog
Oddometer: 3,454
Not that likely...
DISCLAIMER - My personal view: I could have never been comfortable on it again without the YZ or similar forks conversion. The thought of that weak casting would have been in the back of my mind each time I pushed it into a turn. FWIW, the fork conversion was really not difficult to do nor expensive (after selling off most of the BMW stuff I removed). I did have to do a bit of grinding, drilling and tapping (for the steering stops) but overall it was a bolt-on changeover. I paid $350 shipped for a complete YZ250F front end, including wheel and brake disc, caliper and really the only other tasks were making a mount for the ignition switch, brake lines (I removed the ABS) and the steering stop mods. The bike rides and handles much better now both on and off road.
My book's website (Now Available) 2003 BMW F650 Dakar (Back from the Brink) 2003 Victory V92C + Velorex sidecar chassis + Harley sidecar body (Canine Chariot) ![]() 2010 WR250R (Twiggy)
07-07-2012, 07:44 AM
#8630 | |
Oddometer: 724
07-07-2012, 08:25 AM
#8631 | |
KOTW is a myth!
Location: Hey, I can see my colon from here...............
Oddometer: 6,395
Riding And Camping Event: 2010 www.kingsofthewestrally.com Club KotW: THE REMIX 2011 http://www.advrider.com/forums/showthread.php?t=629979 CLOWNS OF THE WEST: http://www.advrider.com/forums/showthread.php?t=629965 KotW Regional Thread: http://www.advrider.com/forums/showt...35024&page=136 KotW Ride Report thread: http://www.advrider.com/forums/showthread.php?t=626346 notmybikemodelname screwed with this post 07-07-2012 at 09:16 AM |
07-07-2012, 08:59 AM
#8632 |
Oddometer: 2,071
If you're willing to do some fabrication, you can make an adapter for the stock steering lock/ignition switch. I'll see if I can find a picture of the one that I made out of 1/4" aluminum stock.
"Give big space to the festive dog that makes sport in roadway. Avoid entanglement of dog with wheel spokes." |
07-07-2012, 10:45 AM
#8633 | |
Oddometer: 724
On another note, since my search-fu sucks...anyone know of stronger conventional forks that I could use with the OEM clamps?? OEM are 41 mm correct?? I seem to remember reading somewhere about using xr400 forks as replacements but cant exactly remember. Im not a real hard rider, and finances prohibit a fork conversion for the near future, but eventually Id like to replace them with something stronger. |
07-08-2012, 02:10 AM
#8634 |
Oddometer: 2,282
Are these bikes meant to turn themselves off when the oil light comes on?
I've tried replacing the oil sensor but it still won't start. Reset the BMS just to see if that would do anything. Was all I could do roadside with no tools. Is definitely got over two litres of oil in it. Only just put it in and there are no leaks at the filter cover. I've read the FAQ which suggested that the pressure could be lost there. It hasn't been used in just under two years which is why I changed the oil (and coolant). It ran fine for over an hour. I've got a diagnostic tool but it won't connect with the bike. I remember something like that in the past but can't remember how I solved it. Working on that one. I park all my bikes with a ctek charger. Interesting detail is that the fan isnt turning freely anymore. Anyone got ideas? It's like it's kicking me in the arse for leaving it in the corner while I'm rebuilding its brother and taking the Suzy when I do go out. Little does it know it's very close to being swapped for a husky. tmotten screwed with this post 07-08-2012 at 02:18 AM |
07-08-2012, 02:53 AM
#8635 |
Thomas
Location: Dreary old Norway, dreaming of adventures past
Oddometer: 3,390
I'd add a chain guide (from any MX shop) just incase the chain gets toasted. I'll add one to my own bike before the (a) next long trip. Last time there were no real signs before it suddenly gave out and kept derailing (would've stayed on with a simple plastic chainguide fitted to the LHS swing arm
'01 F650 Dakar - modified as best I can 2005: Australia - 8 months/ 26.000 km (anti clockwise circle) 2009: Norway - 2 weeks/ 6000 km (Lindesnes to North cape) Gravel Seekers.com Hey ! It's the African ant eater ritual ! |
07-08-2012, 03:06 AM
#8636 | |
Thomas
Oddometer: 3,390
Mine have survived everyting I've thrown at them, which is quite a bit, and never missed a beat. You be the judge.
07-08-2012, 06:04 AM
#8637 | |
Oddometer: 125
Taco - Are these troubles on the bike that you changed all the body work and dash on? Have a look at the handlebar kill switch - when it is in the OFF position, the diagnostic plug isn't powered (I assume that you are using a GS911?). Other than that - all the normal things - poor earth or dirty contact - remove all the battery terminals and give them a clean with sand paper? Clean all the fuse holders, Load relief relay terminals, etc…… I have a vague memory that I had to put a micro relay on the oil light when I wired in my LED indicator lights. Even when the bike was running and everything normal, there was a very slight glow from the Oil LED – the oil light is earth switched but travels through the computer on its way, so I think somewhere in that box of tricks there is enough of an earth, to light the LED but not an incandescent globe. – Am away for work at the moment - get home in a few days – can confirm and provide a diagram if you are interested. Damian EDIT Just saw the comment about the fan not working - looking at the crcuit diagram form F650,com - the Fan comes form Fuse 3, that is powered via the computer. Has the fuse blown/ correct size? If is hasn't, and the fan has seized, it will draw high amperage through the computer (this is assuming that the re-drawn diagram is correct, there are a few faults on them!). Damian_74 screwed with this post 07-08-2012 at 07:30 AM |
07-08-2012, 09:07 AM
#8638 | |
FunHog
Oddometer: 3,454
My lockset mount would have allowed for the steering lock, but I never used it so I didn't enlarge the holes. Hope that all makes sense. If not, it will when you get it apart.
07-08-2012, 09:54 AM
#8639 | |
pass the catnip
Oddometer: 7,562
07-08-2012, 03:06 PM
#8640 |
Oddometer: 1,038
Fun in the Olympic forest
A couple of pics from yesterdays ride.
The whips, mine in silver, wifes in blue ![]() My GPS pointed us down a road that was closed. I said I could make it past the tank trap. I didn't say I could make it back ![]() ![]() OK, bike is upright agian. This picture does not due justice to how steap this was, not to mention how soft the dirt was. And no my feet aren't even close to touching the ground. ![]() Had to do a little boony bashing to make my way out, this way ![]() This "road" became more and more over grown, we pressed on. Eventually after the road was almost gone, we found a wide spot to turn around. We may revisit this one. ![]() Tall, red haired and dressed in Klim, that's how I like 'em
