Old 09-03-2012, 02:44 PM   #9076
TobyG
be happy :)
TobyG's Avatar
Oddometer: 575
Originally Posted by isgila View Post
[...]loosen my front sprocket nutz[...]
You did WHAT?
You should seriously look into getting some decent Loctite...and remember the torque to be used for this nut, don't forget the tab washer either.
"a scoot (that wouldn't go more than 28mph if you dropped it out of an airplane)" ~duck
"If loud pipes saved lives, then ambulances would run straight pipes instead of lights and sirens." ~Phlemdog
This is why I always wear gloves. How you gonna wipe your butt with hands covered in bandages? ~MrBob
TobyG is offline   Reply With Quote
Old 09-03-2012, 03:17 PM   #9077
jdaniele
jdaniele's Avatar
Oddometer: 949
Originally Posted by KG6BWS View Post
Not really. All it would take is a hand drill. Find a castle nut that fits, torque it to spec, then drill the hole to line up wth one of the notches in the nut. As long as its drilled straight itll work.
A drill press would be better but a hand drill would be perfectly adequate.
A little off topic but you might be interested in this set up
[QUOTE]
JD (K2ADV)
"These pretzels are makin me thirsty"
I can't seem to remember why I don't drink anymore.
jdaniele is offline   Reply With Quote
Old 09-03-2012, 05:05 PM   #9078
808Tugpilot
808Tugpilot's Avatar
Oddometer: 321
does anyone use the BMW single seat? If so - what are your thoughts... pros.... cons.....
808Tugpilot is offline   Reply With Quote
Old 09-03-2012, 05:15 PM   #9079
kubiak
Oddometer: 4,829
Originally Posted by tomatoe333 View Post
It might not hit anything, but there is a chance that the chain could jump on the front sprocket if it weren't there. Always good to keep things in line.
yea i guess i should leave the roller on there. bmw designed it on there for a reason lol!
kubiak is online now   Reply With Quote
Old 09-03-2012, 05:22 PM   #9080
KG6BWS
KG6BWS's Avatar
Oddometer: 895
[QUOTE=jdaniele;19511005]A little off topic but you might be interested in this set up
Nice!! What rig is that above the guages?? Where is the body stashed at?? Ive got a VX6R that Ive been thinking of mounting up, with a mobile antennae somewhere on the bike.
"But I swear, a woman's breast is the hardest rock that the Almighty ever made on this earth, and I can find no sign on it." Bear Claw Chris Lapp
Justin
01 F650GS Dakar
KG6BWS is offline   Reply With Quote
Old 09-03-2012, 07:11 PM   #9081
jdaniele
jdaniele's Avatar
Oddometer: 949
[QUOTE=KG6BWS;19511798]
FTM-10SR yaesu 2m-440 the guts fits in the rear storage compartment and its a home made antenna bracket with an nmo mount. The rig and the guts are 100% waterproof. I have the sena sr-10 hub and a ptt on the left grip all audio and tx through helmet on bluetooh.
The vx-8gr was just on a ram mount I was playing with aprs one day.
The antenna is a diamond NR770HBNMO they require no ground plane and work well on the bike.
K2ADV LOOK ME UP ON QRZ
JD (K2ADV)
Old 09-03-2012, 07:56 PM   #9082
KG6BWS
KG6BWS's Avatar
Oddometer: 895
[QUOTE=jdaniele;19512704]
Hows the audio using the bluetooth in the helmet?? Would make my commute nicer be able to talk on the local repeater.
Justin
01 F650GS Dakar
Old 09-03-2012, 09:07 PM   #9083
jdaniele
jdaniele's Avatar
Oddometer: 949
[QUOTE=KG6BWS;19513075]
The sena BT set up works great good reports back on tx. for a vx-7r you might have to make an adapter but it should work on your bike. I have vx-8dr with BT it works but vox is NG on a motorcycle.
I dont want to upset this thread with ham stuff pm me if you have any questions or download echolink I am usually on the limarc repeater W2VL 146.850
73 JD
JD (K2ADV)
Old 09-03-2012, 11:19 PM   #9084
GSBS
FunHog
GSBS's Avatar
Oddometer: 3,970
Had one until my accident two years ago...
Pros... storage compartment was great space for all the roadside emergency stuff - compressor, tire tools, tubes, spare levers, cables, etc. - and the four tie-down points were handy for tying things on top.
Cons... the stock seat was kind of short and uncomfortable to me. I eventually had Rick Mayer saddles make me another one at great expense (over $400) and it was great. Unfortunately, just a couple of weeks after was when I got rear-ended by the SUV.
Following the accident which tore up the compartment part of the seat, I sold the Rick Mayer portion to another inmate when I thought the bike was gonna be totaled. I ended up keeping the bike in the settlement and when I put it back together I found a Corbin saddle at a good price and it's now on the bike.
Picture with Rick Mayer saddle on solo seat:
Earlier photo with stock saddle on solo seat:
Same bike today with 2012 renovations (YZ front end, Excel rims, Corbin, ABS removed, etc., etc.) It's now got almost 80K miles and still going strong:
GSBS is offline   Reply With Quote
Old 09-04-2012, 01:24 AM   #9085
twinrider
pass the catnip
twinrider's Avatar
Oddometer: 9,470
That Rick Mayer seat looks iron butt good...
2014 350 EXC-F
2011 XT1200Z
2009 FLHR
2006 Djebel 250XC
twinrider is offline   Reply With Quote
Old 09-04-2012, 02:11 AM   #9086
Barnman
Barnman's Avatar
Oddometer: 209
I have one and agree with GSBS comments above. I also recovered the seat and posted some info earlier in this thread
http://advrider.com/forums/showpost....postcount=6173
Barnman is offline   Reply With Quote
Old 09-04-2012, 03:10 AM   #9087
Barnman
Barnman's Avatar
Oddometer: 209
Originally Posted by TobyG View Post
It doesn't unbolt.
Simple as that.
You could always just fab a toolbox yourself and attach it to your (selfmade ) skid plate.
I think you may be thinking of a different one Toby, The TT ones does have a detachable toolbox. I now have one in front of me and it the toolbox is bolted to the skidplate. Can be used with or without toolbox
Old 09-04-2012, 03:11 AM   #9088
Barnman
Barnman's Avatar
Oddometer: 209
Originally Posted by Parx400 View Post
Where did you get that diagram?
I have a pdf of the wiring diagram (very similar to a BMW workshop one) if you want me to send you a copy
Old 09-04-2012, 03:34 AM   #9089
GSBS
FunHog
GSBS's Avatar
Oddometer: 3,970
Don't it though? I never had the opportunity to do a long ride with it, but a 200-miler felt like just around the block.
Bottom line is I wouldn't buy another solo because despite it's plusses, the cost of the unit (now around $350 shipped new from MaxBMW) and the redeux of the seat by Mayer (over $400) is just too high to be practical for me.
Besides, the Corbin I got for $125 is probably 90-95% as comfy on trips.
I do miss that storage though!
Old 09-04-2012, 05:28 AM   #9090
twinrider
pass the catnip
twinrider's Avatar
Oddometer: 9,470
How's the Corbin compared to the stock Dakar seat (which the single seat's front portion seems to be)? I installed the Seat Concepts foam and cover on a spare seat pan I had but found the SC foam to be too firm on longer trips so now back to the softer stock Dakar seat.
2014 350 EXC-F
2011 XT1200Z
2009 FLHR
2006 Djebel 250XC
Times are GMT -7.   It's 04:26 PM.
