09-08-2012, 12:32 AM
#9136 | |
Thomas
Location: Dreary old Norway, dreaming of adventures past
Oddometer: 3,390
The stock "skid plate" is only good for one thing - collect forest debris and trap it on the hot exhaust so you have a nice fire going in front of your left boot while riding.... Happy so far with my Touratech skidplate which utilizes the peg mounts instead and has enough room not to collect tinders as your go. Without having measured I would think it would fit like a charm with the SW Motech guards too.
'01 F650 Dakar - modified as best I can 2005: Australia - 8 months/ 26.000 km (anti clockwise circle) 2009: Norway - 2 weeks/ 6000 km (Lindesnes to North cape) Gravel Seekers.com Hey ! It's the African ant eater ritual ! |
09-08-2012, 12:40 AM
#9137 | |
Thomas
Oddometer: 3,390
Never use loc tite and never had those types of problems. Had all the frame bolts work loose and shear so installed lock washers. Been fine since. Rear wheel axel nut I just tighten by feel 'till it's.....well, tight. Just make sure it's aligned first.... also installed nyloc nuts to the chain tensioner bolts so the lids don't move anymore. CS sprocket I also just tighten by feel and use the bendy washer thingy ofcourse (chain on, rear wheel on adn foot on brake makes tightening/ loosening the CS nut a lot easier)
09-08-2012, 12:42 AM
#9138 | |
Thomas
Oddometer: 3,390
Actually had mine light up last week as the bike had been parked in the rain over night and I was riding in rain so current was creaping across all the wires in the contact. At least know the LED is working
09-08-2012, 11:00 AM
#9139 |
Xventurous
Oddometer: 298
Tossing on a Dakar front end and rear shock on my GF's GS w/ABS. (my old front end/rear without ABS). Couple of questions for those who have Dakar'd a GS...
Her ABS Sensor cable (do I need to buy a Dakar length)? ABS Sensor ring? Her 19" front, transferable to the 21? Brakeline (front) I already assume I need a Dakar length (any other issues)? Only keeping ABS (for the time being) as I don't have the patience/time to fully remove it. Removing her standard center stand and replacing side stand w/a Dakar length. Do NOT intend at this time to put on lower chain roller but already have a rear chain guide (TT). Issues, other than the chain on the centerstand (removed)? All this so my brother has a bike to ride w/me for a couple of trips. nomad5326 screwed with this post 09-08-2012 at 12:03 PM |
09-08-2012, 11:40 AM
#9140 |
Oddometer: 2,070
If the frame has the boss for it, get a generic Moose chain roller and put that on. Only a few bucks, and it can't hurt.
"Give big space to the festive dog that makes sport in roadway. Avoid entanglement of dog with wheel spokes." |
09-08-2012, 11:48 AM
#9141 |
Xventurous
Oddometer: 298
Thanks Tomatoe, looking into that piece.
09-08-2012, 11:49 AM
#9142 |
Oddometer: 7
rear end
I noticed your post and thought we might be able to share what we've been working on. Some asshole rear-ended me in Los Angeles-then in that LA kind of way, took off! I have some minor damage to the rear end which I'm tweaking on my back deck. It looks like you may have taken off your rear exhaust? What did you have to do to separate them?
09-08-2012, 11:55 AM
#9143 | |
50cc&652cc thumpers
Oddometer: 238
Soudns just fine to me...mine usually ranges from 95°C to 110°C at this speed, depending on how warm/cold it is outside. 225 °F is 105°C by the way. |
09-08-2012, 08:38 PM
#9144 | |
Oddometer: 132
The Dakar side stand could be a bit longer so I did the hockey puck mod: literally bolt on a hockey puck to the bottom of the side stand. |
09-09-2012, 09:44 PM
#9145 |
Got2MotoGraphics
Oddometer: 442
Anybody want to split an order on these Anti-scuffing little plastic trim bits?
Number 9 + grommets. Finally lost one today. $68! + freight from Bob's and all others.Think that's just for 2? Must be made from German gold I have the '01 but probably all the same part #, and need the bottom short one. Blue preferably but any color would work. If not I'll just make a sticker Yeah , Maybe a long shot but a common problem I've read.
Got2MotoGraphics.Com |
09-10-2012, 05:31 AM
#9146 | |
Xventurous
Oddometer: 298
Lower OEM GS front brake line was def too short and maybe the ABS sensor cable too tight (I have one off a Dakar as well). Getting into redoing the rear today. Still fumbling w/getting the rear exhaust apart so I can free up the pivot. But she's got a rebuilt Dakar Shock waiting to drop in. Almost there though. Front done.
nomad5326 screwed with this post 12-26-2012 at 08:47 PM |
09-10-2012, 09:28 AM
#9147 | |
Oddometer: 132
Dakar Shock w. ABS & Reservoir
![]() As for the rear shock: you have ABS on the bike and an external reservoir on the shock, right? I needed to unbolt the ABS box in order to get the reservoir to squeeze between the frame, the engine and the ABS box. ![]() I used a tie down between the bars and the tail to get enough space to work on the parts. ![]() While you're at it, you should also grease the swingarm bushing/bearing. Hope this helps! |
09-10-2012, 11:32 AM
#9148 |
Xventurous
Oddometer: 298
It does, thanks. How did u get the exhaust to separate? Maybe mine is just stuck. Did you have to bleed the abs ?
09-10-2012, 11:36 AM
#9149 | |
Oddometer: 2,070
It took some finagling, but you should be able to get the remote reservoir and preload adjuster around the ABS plumbing. You do have to remove the knob of the preload adjuster (philips screw in the center). Be prepared to catch a ball bearing and a spring as you pull off the knob.
09-10-2012, 12:35 PM
#9150 | |
Oddometer: 132
The Great Persuader
![]() ABS: I bled it twice. The first time after attaching the lines, the second time after activating the ABS system (slow speed full hand grab on the brake). Good point there, forgot about that! |
