Old 09-14-2012, 05:25 PM   #9166
michael1968
michael1968's Avatar
Oddometer: 885
Originally Posted by LoJack View Post
I put an LED tail light on my bike this spring and it blows. Any ideas what a decent one would be?
That sucks, I put a cheap ass one on and it's pretty good, guess I got lucky.
michael1968 is offline   Reply With Quote
Old 09-14-2012, 07:23 PM   #9167
twinrider
pass the catnip
twinrider's Avatar
Oddometer: 9,495
I bought one on ebay Germany that is identical to the Touratech branded tail light but less than half the price. Works great.
2014 350 EXC-F
2011 XT1200Z
2009 FLHR
2006 Djebel 250XC
twinrider is online now   Reply With Quote
Old 09-15-2012, 04:52 AM   #9168
Barnman
Barnman's Avatar
Oddometer: 222
Anybody know what the plug details are for the side stand switch? (The plug/socket where the switch joins the loom)
I want to buy a new plug and wire it so that the side stand switch is linked out, then swap this for the side stand switch. Then I can remove the side stand switch. I don't want to butcher the original, in case I want to revert back to standard at a later date.
thanks
Barnman is offline   Reply With Quote
Old 09-15-2012, 08:06 AM   #9169
1911fan
Master of the Obvious
1911fan's Avatar
Oddometer: 3,279
Just jumper it, easier, cheaper, easily reversible. Try here:
http://faq.f650.com/GSFAQs/Electrica....htm#Sidestand
and here:
http://faq.f650.com/FAQs/SidestandKillSwitchFAQ.htm
1911fan
Read The Patriot Post -- It's Right. It's Free.
http://patriotpost.us/subscribe/
Sometimes the light to see your way forward is provided by the bridge burning behind you.
1911fan is offline   Reply With Quote
Old 09-16-2012, 04:54 PM   #9170
KG6BWS
KG6BWS's Avatar
Oddometer: 895
Hey guys. Has anyone else had a leak near the top left radiator mount?? Ive got coolant around and below it, only thing I can think of is that the radiator is cracking around that mount.
Radiator and overflow tank are both still full, and the overtemp light has never come on, Im just a little concerned about it. Im going to go get some stop leak and dump it in, try that first. i really hope I dont need a new radiator.
If any of you had a similar issue, what was your fix??
Ive got the HUBB Cambria meeting/my yearly vacation coming up in a few weeks, shitting myself because thisll throw a major wrench in the works.
Anyone have/know of a good used radiator for sale?? My bikes an 01 Dakar.
ANy help is appreciated. Thanks.
"But I swear, a woman's breast is the hardest rock that the Almighty ever made on this earth, and I can find no sign on it." Bear Claw Chris Lapp
Justin
01 F650GS Dakar
KG6BWS is offline   Reply With Quote
Old 09-16-2012, 06:52 PM   #9171
Parx400
Oddometer: 2,028
Mine had the fan shroud rub a hole in the back of the radiator. That's around the same area. Pull it off and check.
Parx400 is offline   Reply With Quote
Old 09-16-2012, 07:03 PM   #9172
KG6BWS
KG6BWS's Avatar
Oddometer: 895
This leak is on the other side, at the mount above the fill neck.
I put some of that stop leak stuff in it, and it SEEMS to have stopped it. Im thinking that the crack is probably under the mounting tab itself, where its welded to the rad core.
Tomorrow mornings commute will tell the tale.
Justin
01 F650GS Dakar
Old 09-17-2012, 06:20 AM   #9173
GSBS
FunHog
GSBS's Avatar
Oddometer: 3,972
Ahhhh! Fresh Rubber!
Yesterday I mounted up a new Heideneau K60 Scout on the rear of the Dakar. This is the second one (both 140/80-18) in a row for me on the 18" Excel rear wheel I had laced up by Woody's Wheel Works in February. The first one went just over 6,200 miles and still had about 2 mm of the original 11 mm or tread in the center. I probably could've gotten another few hundred out of it on the street, but it was toast for anything off pavement. I was surprised a little that the mileage was as good as it was considering I've run it at 20-24 psi for its entire life.
New meat:
The front K60 was mounted at the same time as the first rear (~6K ago) and still looks practically new. I run about 18 psi in it:
As long as they're available I think this will be my tire of choice for the Dakar. They are surprisingly good off-road and fantastic on pavement.
GSBS is offline   Reply With Quote
Old 09-17-2012, 06:42 AM   #9174
WayneC1
Oddometer: 2,732
Take care with the front pressures, at least when used with BMW rims, managed to spin the tyre on the rim without rim locks & pulled a valve. They dont fit as tightly to the rim as Conti's do & need higher pressures
WayneC1 is offline   Reply With Quote
Old 09-17-2012, 07:01 AM   #9175
kubiak
Oddometer: 4,845
dang those are some long lasting tires!
Old 09-17-2012, 07:42 AM   #9176
twinrider
pass the catnip
twinrider's Avatar
Oddometer: 9,495
Piaa 530 LED driving lights
Just installed a set of Piaa 530 led driving lights I picked up on Amazon for about $200. Draw just 6 watts each, but put out very bright light. The led bulbs shine rearward toward the multireflector and the result is a precisely aimed beam that doesn't dazzle oncoming traffic like most led lights. Also have a 2-year warranty.
http://www.piaa.com/automotive-lamps/led-530.html
2014 350 EXC-F
2011 XT1200Z
2009 FLHR
2006 Djebel 250XC
Old 09-17-2012, 07:56 AM   #9177
Barnman
Barnman's Avatar
Oddometer: 222
and here:
1911fan
Thanks. I had read the 650 FAQ's but mine is a different plug which doesn't take the links as easily and also has three wires.
I have found this great piece of wisdom that shows the same plug and set up I have which is common to its big brother the 1150
http://advwisdom.hogranch.com/Wisdom/SSIBD.pdf
Old 09-17-2012, 08:15 AM   #9178
WayneC1
Oddometer: 2,732
Yes that info on the F650 site is for the F650, the 650GS is different & has the 3 pin connector. The circuit details are on a diagram I put online
http://www.f650gs.crossroadz.com.au/.../StartCctG.pdf
The 1200GS circuit and wiring colors are a little different to the 650GS
Old 09-17-2012, 09:27 AM   #9179
Barnman
Barnman's Avatar
Oddometer: 222
Great diagram Wayne - thanks
Old 09-17-2012, 09:47 AM   #9180
Mr.Dabalina
Mr.Dabalina's Avatar
Oddometer: 188
@twinrider. Looks good. What bulb do you have in the main headlight? Also, did you wire your driving lights into an existing switch or did you add one?
Mr.Dabalina is offline   Reply With Quote
Times are GMT -7.   It's 04:31 PM.
