09-18-2012, 07:39 AM
#9196 |
Oddometer: 127
That is very sad reading, and thoughts go to the rider and his family.
One of the things I like about the Dakar is its multi use, not the best at anything but can do most things. So when doing something like the rally training course you can be aggressive and fast in a safe, controlled environment accepting that all motor sport carries its own risks, but when out touring I wouldn't dream of riding like that. In fact, I think this quote from somewhere sums it up nicely "If you're riding fast, you aren't seeing much. If you aren't seeing much, you're riding too fast." Part of the reason I did the training, was to increase my own comfort window, so that I can enjoy the ride more, not so that I drive at the limit for the ride, if that makes sense anyhow, just some of my thoughts |
09-18-2012, 08:34 AM
#9197 | |
Oddometer: 132
09-18-2012, 02:08 PM
#9198 |
Oddometer: 99
Sad. That is a very sobering post. As someone else has stated, experience doesn't make you safe. It makes you wiser, which in turn makes it more safe, but motor sports will always have risk. I want to be a better rider. I just think if you keep it in first you will limit your potential ability.
09-18-2012, 02:13 PM
#9199 | |
50cc&652cc thumpers
Oddometer: 238
This. And remember, start slow and always push yourself a little more until you reach the point where you do not feel comfortable anymore. If you do reach this point just stop, thats exactly as fast as you should go. Sure these bikes CAN go damn fast, but as Barnman said "its the rider and not the bike that's the limiting factor". |
09-18-2012, 02:23 PM
#9200 |
Oddometer: 99
09-21-2012, 05:39 PM
#9201 |
A Serious Man
Oddometer: 2,350
Baja Designs La Paz Single 8"
Broke my entire headlight assembly off and always wanted to do this, so chopped away. Have the Touratech /WP suspension upgrade, and the steering lock /ignition key had to move. What to do?
So I made it a power socket and move the key assembly to right above where the battery sits.... and of course all the other mods. Voltage meter, stabilizer, etc. Velcro shelf is for iphone... Enjoy. I've tried all the LEDs etc. and finally I have a light that puts out. It's blinding as is and I will next add the HID. ![]() ![]() ![]() ![]() ![]()
09-21-2012, 06:45 PM
#9202 |
Oddometer: 4,142
healight and the whole bike looks great!
09-22-2012, 08:51 AM
#9203 |
A Serious Man
Oddometer: 2,350
Appreciate that. I took some inspiration from your bike build. I like your front fender a lot better.... mine is a crap off the shelf one from cycle gear.... but of course will be swapped out eventually.
09-22-2012, 09:05 AM
#9204 |
Oddometer: 4,142
yea i love my 950sm fender, i used one on my xr650l and now on the dakar. i wish they werent so expensive though!
09-22-2012, 11:07 AM
#9205 |
Oddometer: 724
Oil in air box
Whats considered a "normal" amount of oil in the airbox?? Its got....maybe....an ounce...
Im not real good at estimating fluid amounts. Oil level goes down slowly, I change oil every 3k and Ive only had to add oil 1 time between changes. Part of that though I attribute to the leaking valve cover Ive got. I do, however, have a little black soot/carbon around the end of the tailpipe. Doesnt throw out any noticeable smoke when the engines running though. Edit - Was just looking at F650.com and found some references to getting oil in the airbox in a tipover. I wiped out couple weekends ago out playing in the desert. Never occured to me that oil would run into the airbox like that. GOing to clean the oil out and keep an eye on it. Might have been the whole problem.
All that is gold does not glitter, Not all those who wander are lost J.R.R. Tolkien 01 F650GS Dakar 04 KLR 650 (Need to sell) KG6BWS screwed with this post 09-22-2012 at 11:13 AM |
09-22-2012, 12:34 PM
#9206 |
Oddometer: 1,950
What the Dakar should have been.
Funny thing is that BMW could have done that for peanuts.
Whales were everywhere. On the beach, on the hillsides. One crossed the road in front of us… it was a big beluga! |
09-24-2012, 10:29 AM
#9207 |
Xventurous
Oddometer: 298
Question: My Dakar "seems/feels" to be running hot on the right side (never noticed it like I have lately). Temp light works, has not kicked in. Fan works. Fluids are good (oil/coolant). It just seems hot. Am I imagining something??
09-24-2012, 12:31 PM
#9208 | |
Desubicado
Oddometer: 86
Talked to my mechanic and he suggested I might have a pocket of air in the cooling system and recommended I purge the system using a piece of clear tubing and the vent nipple on the upper right side of the engine (http://faq.f650.com/GSFAQs/Photos/Ai...nTubeClose.jpg). Went to do that today only to discover the previous owner replaced the vent nipple with a bolt, so now I need to make the trip to the dealer to purchase the $10 part. Martín
Todo es posible nada es seguro |
09-24-2012, 12:36 PM
#9209 |
Xventurous
Oddometer: 298
Thx Martin, will take a look at that.
09-25-2012, 06:46 AM
#9210 | |
Oddometer: 24
If the bolt seals, just crack it open till iquid comes out then tighten closed. No need for the fancy bleed screw in my estimation. |
