Old 10-20-2012, 09:22 AM   #9391
acejones
acejones's Avatar
Oddometer: 5,135
Originally Posted by Gravel Seeker View Post
I've only seen the regular GS.
Far as I know they were used in Holland and Italy at least.
I've often wanted to try to order the pieces just to see if the dealer would be able to sell them without any restrictions
They have been used in numerous countries including the U.S.
I got tired of being here, so now I'm there
acejones is offline   Reply With Quote
Old 10-20-2012, 01:28 PM   #9392
Baams
n00bs FTW
Oddometer: 35
Question Part number
Hey guys
My dealer and i have been looking for this part number but cant find it. Can you guys help?
It's a little socket, where the screw for adjusting ones light, is attached to. Right in each side of the headlight.
thanks
Baams is offline   Reply With Quote
Old 10-20-2012, 03:33 PM   #9393
nomad5326
Xventurous
nomad5326's Avatar
Oddometer: 300
Originally Posted by bkwags View Post
I have a 2005 Dakar and was looking for some advice on which mount to use and why for my Garmin 530HCx GPS?
As always you advice is appreciated!!!
Im running my Rino w/this Ram mount.
nomad5326 is offline   Reply With Quote
Old 10-20-2012, 08:59 PM   #9394
Capt. REDBEARD
TWECO
Capt. REDBEARD's Avatar
Oddometer: 1,126
Originally Posted by Baams View Post
Hey guys
thanks
find a new dealer............
part number: 63 12 1 369 833
max bmw parts fiche has it:
http://www.maxbmwmotorcycles.com/fic...6&rnd=08102012
panel #63 - lighting
diagram: 63_0606
#nine - part number: 63 12 1 369 833
1976 R60/6, 2009 530 EXC, 2008 250 XC, 2004 950 ADV
if the ocean were whiskey and I were a duck - I'd swim to the bottom and never come up
Capt. REDBEARD is online now   Reply With Quote
Old 10-20-2012, 11:36 PM   #9395
Baams
n00bs FTW
Oddometer: 35
diagram: 63_0606
ARGHhhh If you knew how many times we have agreed on that not being the part :P well now i know, thanks a lot
And no way i'm getting a new dealer... this one is 500m from where i live :P as long as i have you guys to help with part numbers it shouldn't be a prob :P
Old 10-21-2012, 12:20 AM   #9396
WayneC1
Oddometer: 2,434
Perhaps the dealer could learn to read his fiche & as per dealers I have dealt with, order in the parts when in doubt, or talk to his BMW Rep I mean these are low cost parts so he did not have large $ at risk
It is crazy when we can read the fiche better than the dealer, there really is no excuse
WayneC1 is offline   Reply With Quote
Old 10-21-2012, 12:50 AM   #9397
Don Coyote
Don Coyote's Avatar
Oddometer: 1,255
Judging from some Danish folks i knew a couple of years ago, throwing money at every problem and accumulating unneeded stuff aren't in their national character as much as they are in the English speaking colonies...
'06 F650GS Dakar
Those who believe you should always error on the side of caution usually become comfortable making errors and before too long know of little else.
Don Coyote is offline   Reply With Quote
Old 10-21-2012, 10:13 AM   #9398
Baams
n00bs FTW
Oddometer: 35
True :P
but the dealer actually did order a part home that we thought was it, no charge off course. After that i went to this forum :P
They were willing to keep going but it was to painful to watch
Old 10-21-2012, 07:16 PM   #9399
WayneC1
Oddometer: 2,434
Yes watching some in dealers navigate the fiche can be painful at times, years ago we had a top notch spares manager who knew his way around the old mechanical fiche & could match up parts between models he was a marvel
Later when I first purchased the Dakar a spares person ordered in a pile of parts including centre stand only to find they were for the GS not Dakar and had to do a return to sort it out
Old 10-22-2012, 08:31 PM   #9400
bkwags
bkwags's Avatar
Oddometer: 79
2005 Dakar Front Brake Lever
Where's the best aftermarket place to order a set of levers for my Dakar. Broke the brake lever on an off road ride last week and want to get a new one and a spare of each.
Does anyone have a spare brake lever they want to sell ASAP as I have another ride this weekend. I really don't want to have to drive to the dealer 70 miles away. Since they are not open any evenings and would need to take 1/2 of vacation to get there.
Also, who makes a sturdy Bark Buster that won't allow my levers to break during a slow drop. The OEM version are not very robust.
Thanks in advance for your advice!
bkwags is offline   Reply With Quote
Old 10-22-2012, 08:38 PM   #9401
LoJack
LoJack's Avatar
Oddometer: 1,544
I broke two clutch levers when I had the Toura-Tech hand guards that came on the bike. I have some Acerbis now, and though they don't block the wind as nicely, they are very robust!
Will you be at the Bucky? I'll be there.
LoJack is offline   Reply With Quote
Old 10-22-2012, 08:50 PM   #9402
Pootrol
Oddometer: 102
Stalling :(
Hi, I have a 2004 twinspark Dakar.
I have searched long and hard for months trying to find an answer all over the web. The chain gang doesnt have an answer.
Basically I have narrowed it down to the inductive sensor?
The symptoms.
- it stalls on idle
- when sitting at the lights in fluctuates between 1100-1500 rpm
- when doing a lazy gear down it will cut out
- it doesn't always happen, but usually about 75% of the time
- it usually stalls after about 5 seconds after the first start then runs fine or it begins the symptoms above
I tried in plugging the lambda sensor and running it.. No help.
If these problems occur and I hold the revs at 1550/1600 it runs fine, it performs fine riding it as well.
Some more checks I have conducted is holding the clutch in whilst rolling with the unusual revving and then stopping, result is that it seems to go back to normal revving.
So from all my research it sounds to me as the inductive sensor as this is what governs the idle rpm? Please some one shed light on this!!!
Sincerely Dominic.
Pootrol is offline   Reply With Quote
Old 10-22-2012, 08:56 PM   #9403
byron555
Lame Duck Adventurer
byron555's Avatar
Oddometer: 1,124
The Bucky
Wish I could go to the bucky.... Damn Freak Fest! I have to go into work early. Hope it's a good ride!
Another inmate stole my Avatar...
WR250R... 15 cubic inches of raw power.
WRr re-build
http://www.advrider.com/forums/showthread.php?t=997633
byron555 is offline   Reply With Quote
Old 10-22-2012, 09:08 PM   #9404
WayneC1
Oddometer: 2,434
Pootrol, before looking at a component failure read the info in the link below, it has been discussed here and at f650 before and has solved problems for a number of people here and elsewhere
http://www.bikeboy.org/f650start.html
Old 10-23-2012, 01:58 AM   #9405
Diggar
Follow your heart
Diggar's Avatar
Oddometer: 115
[QUOTE=Pootrol;19878062]Hi, I have a 2004 twinspark Dakar.
You are Darwin,right?just check your mior electrics the wet season maybe?
Diggar is offline   Reply With Quote
Times are GMT -7.   It's 06:21 AM.
