12-05-2012, 03:56 PM
#9601 |
Oddometer: 229
Blinker/indicator light question
I took off the old instrument console and installed a Trailtech Vapor w/ indicator lights. The old blinker Indicator light had a blue w/ black tracer wire (right blinker) and a blue w/red tracer wire (left blinker) connected to the bulb and worked fine. I hooked up the new indicator light the same way. The blinkers are working, the indicator light only operates w/ the left side blinkers and not w/ the right side blinkers (blinkers work). The neutral light, low fuel light and the low oil pressure light are all working.
Any thoughts? (I did have to do a little jumpering to get the fuel light to work, Maybe for the right blinker as well?) Thanks for any input. JP
12-05-2012, 04:01 PM
#9602 | |
Oddometer: 564
Remember I'm in Canada so we pay more for the bearings than you do ![]() Go to f650.com and buy the steering head tool from an inmate who makes them it is very well made. |
12-05-2012, 04:51 PM
#9603 | |
Stromsurfer
Oddometer: 489
Bearings
Thanks guys for your help. MC
“ The function of man is to live, not to exist. I shall not waste my days trying to prolong them. I shall use my time.” Jack London |
12-05-2012, 05:24 PM
#9604 | |
Oddometer: 4,127
12-05-2012, 10:47 PM
#9605 |
de-composer
Oddometer: 322
What hand guards are you liking?
I have the stock BMW but am looking at the barkbusters VPS. I have heated grips and stock bars so I'm wondering if the weights changing with the VPS increase the vibes. Also wondering about the 20mm risers. |
12-06-2012, 12:46 AM
#9606 |
pass the catnip
Oddometer: 7,580
Some people like the risers, I tried them (with the stock guards) and took them off after one ride.
12-06-2012, 01:57 AM
#9607 |
Oddometer: 99
I think that with the Barkbusters or the TT hand guards, you have to put risers, because of the dashboard/screen getting in the way.
12-06-2012, 01:59 AM
#9608 |
Oddometer: 785
Yes there is some misunderstanding of the use of risers, in many cases they can cramp the arms and reduce ability to control the machine
On mine people see the risers and mention they should fit some, They miss the fact the risers are there to adjust for the lower rise in the bars and that the total height is actually 1/2" lower than stock to suit my height let alone that the pegs are 1/2" higher to give better leverage and comfort |
12-06-2012, 05:24 AM
#9609 |
dharma bum
Oddometer: 259
I have 20mm risers, and Fastway foot pegs installed in the 1/2" lower than stock position. Makes both standing and sitting a lot more comfortable for me.
I just ordered Barkbusters, so I will have a set of risers available if anyone is interested. Send me a PM.
Enjoy today, tomorrow is not guaranteed. |
12-06-2012, 06:54 AM
#9610 | |
Oddometer: 2,074
I swapped my bars out for Renthal Jimmy Button bend, and the VPS handguards still fit, though without the weights. I put Ricor Vibranators in at the same time.
"Give big space to the festive dog that makes sport in roadway. Avoid entanglement of dog with wheel spokes." |
12-06-2012, 10:08 AM
#9611 | |
de-composer
Oddometer: 322
I'm 5'7" so the stock ergonomics fit me great. I need a little more wind protection than stock guards and beefier is better. Just not sure how much a 20mm riser changes things and once I try I couldn't return the guards. Think I'll try to find someone in the D/FW area with some BB guards mounted or just pull the trigger. |
12-06-2012, 02:19 PM
#9612 | |
Oddometer: 564
Installing the Storm plastics required a little bit of plastic trimming with a box cutter to clear my clutch lever. |
12-06-2012, 03:46 PM
#9613 | |
pass the catnip
Oddometer: 7,580
If I wasn't in Japan I'd be happy to mail you my risers to try. But if you only want more wind protection you could always just add the Touratech wind spoilers to your stock handguards.http://www.touratech-usa.com/Store/3...ar-G650GS-pair |
12-06-2012, 10:34 PM
#9614 |
de-composer
Oddometer: 322
thanks twinrider, that's what I was needing to hear. I'll go with the TT spoilers for now and if I bend my stock bars then I'll go with the Renthal bars, vibranators and BB guards.
thanks! btw, I put on a pair of the new SW Motech footpegs and really like them. The rubber comes off with one bolt and the spike pattern isn't so spikey that my boots stick in them. Wider, beefier than the stock and there are two positions...one stock and one slightly lower without the need for new shifter or rear brake pedal. I didn't even have to adjust them. |
12-07-2012, 08:37 AM
#9615 |
Thomas
Location: Dreary old Norway, dreaming of adventures past
Oddometer: 3,392
You don't have to bend them. If you loosen the screws you can just rotate them back to desired position and then tighten the screws
'01 F650 Dakar - modified as best I can 2005: Australia - 8 months/ 26.000 km (anti clockwise circle) 2009: Norway - 2 weeks/ 6000 km (Lindesnes to North cape) Gravel Seekers.com Hey ! It's the African ant eater ritual ! |
