Old 02-12-2013, 05:07 PM   #9946
kubiak
Oddometer: 4,829
super nice job on the gs!
Old 02-12-2013, 06:01 PM   #9947
ferals5
800+652
ferals5's Avatar
Oddometer: 1,191
Originally Posted by Spyker View Post
All smiles on her new bike!
The smile says it all...great job Spyker
ferals5 is offline   Reply With Quote
Old 02-12-2013, 07:59 PM   #9948
grumpyoldbstrd
Oddometer: 278
Originally Posted by GSBS View Post
My 03 Dakar had no issues with water pump seals until after it was crashed at 72K miles, then sat up for 18 months before I fixed it up to make it roadworthy again. 5K miles later it was dripping coolant from the weep hole in the bottom of the lefthand engine case.
So I replaced the seals and impeller at 77K miles and have been keeping a wary watch on the weep hole since. Today, 5K after replacing the seals, I noticed a single droplet of coolant on the inside of the skid plate and when I looked closer I could see it had blown down from the weep hole. I removed the faux tank trim on that side and found that the coolant overflow reservoir was still at the "Max" level, so it hasn't leaked much yet. I also checked the oil for coolant and no evidence of any there, so I'm thinking it's only the seal on the coolant side leaking and not the one for the oil side (same as it was before).
My question is about my installation of the new seals 5K miles ago. When I put those in, I simply pressed them in and reassembled. Is there some lubricant I should've used to condition the seals as well?
I've also read that the part of the engine casing where the impreller shaft seats can become wallowed out over time to an elliptical shape and this will cause premature seal failure. How do you check for this? Also, if this turns out to be the culprit, is there a "fix" for a deformed casing or do I have to just to buy another one?
Any advice from those who've gone thru this before will be greatly appreciated.
G’day GSBS,
Like you, I finally became pissed off with the rotten OEM water pump. The impeller shaft bore in the clutch cover had opened up to 10.04mm and the bore in the engine case was 10.03mm. I reckon this was allowing the impeller shaft to “flop” around too much and subsequently chew out the seals and groove the shaft.
I’ve just replaced mine with an electric water pump – (see Post 9881). Have done about 1,000kms since in some 35+ degree C days and have had no leaks and no cooling problems. The fan still comes on when required (no more than normal) and shuts off as normal. Wired it up so that the pump comes on with ignition – just tapped into the tail light wire.
The Davies Craig (DC) 9001 kit I used is almost as cheap as the OEM replacement kit – about AUD150 (on line, excluding postage). The DC unit is small & light enough to be mounted in-line. However, I did fabricate and mount a small alloy strap bracket down from one of the starter mount bolts and cable tied it to the pump for a little bit of extra support… not sure it was really required.
The DC 9001 kit provided everything I needed. Their hoses fit snugly inside the OEM hoses & the adaptor couplings were easily modified to provide a solid sleeve to enable a hose clamp.
Because of my computer illiteracy I can’t post pics (don’t know how & don’t have a Smugmug account thingy), but can send pics to an email address. If you’d like, send me a PM with an email address and I’ll send some pics. I’m happy if you then want to post the pics on this forum.
BTW, I have no affiliation with Davies Graig.
Cheers,
GOB
Old age and treachery will always beat youth and enthusiasm, however, there has been an alarming increase in the things I know absolutely nothing about.
grumpyoldbstrd is offline   Reply With Quote
Old 02-12-2013, 09:30 PM   #9949
Spyker
Oddometer: 186
Originally Posted by nomad5326 View Post
Beautiful job. The matte/flat black and slate decals look great. Are those Got2motographics.com ones? He made mine for all my bikes and love them. The Pink rocks!
Yes, the decals are from him. I actually shamelessly copied your Dakar, apart from the red subframe. I printed a copy of one of the photos of your bike and pinned it up in the garage. Was my source for inspiration!
Originally Posted by scottie boy
If you calculated the money spent versus time actually used, vaginas cost more per hour than the space shuttle.
Spyker is offline   Reply With Quote
Old 02-13-2013, 01:57 AM   #9950
nomad5326
Xventurous
nomad5326's Avatar
Oddometer: 305
I can't take all the credit. PO did the frame and front swap. I just had the front/rear suspension rebuilt and did the re-shoeing, bodywork /repainting and guards.
nomad5326 is offline   Reply With Quote
Old 02-13-2013, 02:21 AM   #9951
ferals5
800+652
ferals5's Avatar
Oddometer: 1,191
GOB's water pump
Originally Posted by grumpyoldbstrd View Post
G’day GSBS,
Cheers,
GOB
GOB's pics
ferals5 screwed with this post 02-13-2013 at 02:25 AM Reason: added one more
Old 02-13-2013, 05:24 AM   #9952
seanfenick
Oddometer: 101
Okay I guess nobody will help. Thanks anyways
seanfenick is offline   Reply With Quote
Old 02-13-2013, 05:58 AM   #9953
1911fan
Master of the Obvious
1911fan's Avatar
Oddometer: 3,252
Originally Posted by seanfenick View Post
I have an easy question to answer an one that is a little more difficult, & one that probably a little easier to answer. The easy one first. What is the most common problem that makes an abs light, light up? Second when I gear down to first for when I'm stopping more often then not my bike is going into neutral. The third my bike likes to cut off within like 10 minutes from starting it from a cold start. Any ideas????
Had to go back a bit to find your question.
1) Not a simple question. The ABS system goes to the front and rear wheels, with wires and a pump/reservoir under the seat. I've heard the most common fault is the rear sensor being bumped out of position or the mounting bolt gets loose and it moves; check the front also. More below. (I'm considering removing my system entirely.)
2) Not unusual, at least IMHO.Mine does it frequently, so I usually just downshift to neutral and then into first when I'm stopped or nearly stopped.
3) No idea. Pretty sure your bike is at operating temp by then, so it's not a sensor/closed loop problem. Does it start right back up, or do you have either wait a while and then it starts, or does it start right up but have to crank a long time? Check your sidestand switch, too.
1 and 3 may require the MW diagnostic computer to find.
1911fan
Read The Patriot Post -- It's Right. It's Free.
http://patriotpost.us/subscribe/
Sometimes the light to see your way forward is provided by the bridge burning behind you.
1911fan is offline   Reply With Quote
Old 02-13-2013, 02:36 PM   #9954
BeachGuy
Alabama & Costa Rica
BeachGuy's Avatar
Oddometer: 475
Any one tried these yet?
Need some new clutch and brake levers, has anyone tried these yet, ad list the F650 GS on it's site.
Ebay listing: http://www.ebay.com/itm/BMW-F800-F80...sories&vxp=mtr
BMW F800 F800GS F800ST 06 07 08 09 10 12 Black Red Brake Clutch Levers
Or any better suggestions.
BeachGuy
2010 Ride Report: Orange Beach, AL to Jaco Beach, Costa Rica
2011 Ride Report: Costa Rica to Panama back to Costa Rica
2014 Ride Report: Ring of Ireland in 30 days
One of the beautiful things about riding solo is the quality of the social experience.
BeachGuy is offline   Reply With Quote
Old 02-13-2013, 10:52 PM   #9955
Gravel Seeker
Thomas
Gravel Seeker's Avatar
Location: Dreary old Norway, dreaming of adventures past
Oddometer: 4,020
Without checkeing your link; beware that BMW royally fucked up when they renamed the single to the "G" and intruduced the new paralell twin as "F"....
F650GS after a certain year is actually an 800cc street version of the F800 GS.... confused yet ?
'01 F650 Dakar - modified as best I can
2005: Australia - 8 months/ 26.000 km (anti clockwise circle)
2009: Norway - 2 weeks/ 6000 km (Lindesnes to North cape)
Gravel Seekers.com
Hey !
It's the African ant eater ritual !
Gravel Seeker is offline   Reply With Quote
Old 02-14-2013, 04:44 AM   #9956
Ebbs15
Parttime Saddletramp
Ebbs15's Avatar
Oddometer: 501
I have an easy question to answer an one that is a little more difficult, & one thtat probably a little easier to answer. The easy one first. What is the most common problem that makes an abs light, light up? Second when I gear down to first for when I'm stopping more often then not my bike is going into neutral. The third my bike likes to cut off within like 10 minutes from starting it from a cold start. Any ideas????
this got buried... but don't know much about 1. as I don't have ABS on my 01... 2. I've had trouble with that from time to time, just had to make it a deliberate shift, ie don't be lazy about it, shift with a purpose. never had it stop at neutral when I was doing that.. and 3.. again... I'm no help... sorry
Part-Time Saddle Tramp
Ebbs15 is offline   Reply With Quote
Old 02-14-2013, 05:01 AM   #9957
GSBS
FunHog
GSBS's Avatar
Oddometer: 3,979
Belt vs. Chain Drive Rotax Engines
Now that my 2003 Dakar is approaching 85K miles, I'm looking for a good condition Rotax engine to buy and keep on hand as a spare.
I'm looking on here, Craigslist and eBay and for some reason all the attractively-priced ones seem to always be on the other side of the country, meaning that shipping is a deal-breaker. I'm hoping to find one within a day's drive of me here in north Alabama.
Also, it seems the best prices I'm finding are for the CS and S engines that powered the belt-driven models.
I'm wondering whether the shaft for the engine drive pulley on the belt models is the same as the one on the countershaft sprocket on chain-driven models. In other words, could the pulley be removed and a CS sprocket installed?
If anyone knows, please advise. Also, are there any other known differences between the S and CS models and GS models of the EFI engines?
GSBS is offline   Reply With Quote
Old 02-15-2013, 11:53 AM   #9958
dwayne
Silly Adventurer
dwayne's Avatar
Oddometer: 3,575
You could check Max BMW's online parts diagrams and compare part numbers for the output shafts on each bike? If the PN's are the same it's a no brainer.
Edit: Just checked PN no matchy. The only things that may be different is the spline for the sprocket, and there may be a different shoulder/shoulder spacing behind the sprocket/pulley. FYI the CS model shaft is about $270, but no price is listed for the Dakar shaft because of a superseded pn.
Rum Runners Yukon, NWT & Alaska
Roads and Ruins Scotland
Kinbasket Lake Golden B.C.
A "Day" of Dirt Biking Rockies East Slopes
High and Dry Colorado and Utah
"When your only tool is a hammer, every problem looks like a nail"
dwayne screwed with this post 02-15-2013 at 12:05 PM
dwayne is offline   Reply With Quote
Old 02-15-2013, 01:48 PM   #9959
GSBS
FunHog
GSBS's Avatar
Oddometer: 3,979
Thanks for the info! I guess that's why the CS engines are going for less. Oh well.
Old 02-15-2013, 02:42 PM   #9960
ylc
Oddometer: 3
front brake issue!!!
hi guys.. I have got a front brake issue.If I pull very slowly on my front brake lever the lever will come back all the way to the grip without engaging the front brake. If I pull back faster the break engages normally and the lever acts normally.. bike is 2005 dakar.rear brake and abs working fine. fluids are replaced and bleed.no air in the system. i bought front brake master cylinder repair kit and changed master cylinder and seals.but still does not work as should be. any ideas about that. thanks
ylc screwed with this post 02-15-2013 at 03:00 PM
ylc is offline   Reply With Quote
Times are GMT -7.   It's 07:12 PM.
