Old 02-23-2013, 01:34 AM   #10036
Gravel Seeker
Thomas
Gravel Seeker's Avatar
Location: Dreary old Norway, dreaming of adventures past
Oddometer: 4,004
Originally Posted by WayneC1 View Post
The Pegaso front disc is 300 mm as per the GS, mounting holes etc are the same, bolt heads are recessed though
Caliper is the same Brembo as the GS withe the same mount. I have an ebay pic showing the part No etc
The front forks you linked to should slide in but dependant on sub model they came from may be only 140 mm travel
On the rear it looks like there are variations between year models with the later Pegaso swapping sides for chain drive when they moved to the Yamaha engine. It looks like there are differences in the Cush Drive on the earlier Pegaso so it would mean a Sprocket holed and wheel change if it was possible. This looks a bit more iffy than the front
Ok, thought some might benefit from another fork replacement option, but with travel that short it's not going to work.
On the rear I've obtained a BMW wheel so that won't be an issue for me, but good info for others.
'01 F650 Dakar - modified as best I can
2005: Australia - 8 months/ 26.000 km (anti clockwise circle)
2009: Norway - 2 weeks/ 6000 km (Lindesnes to North cape)
Gravel Seekers.com
Hey !
It's the African ant eater ritual !
Gravel Seeker is offline   Reply With Quote
Old 02-23-2013, 01:41 AM   #10037
WayneC1
Oddometer: 2,557
The Trail Variant has conventional forks, later one's are 45 mm, piston rod and 175 mm travel. They look like a good replacement for GS owners rather than the Dakar. Could be fitted with intiminators to improve them. Hopefully getting some measurements off one to confirm
WayneC1 is offline   Reply With Quote
Old 02-23-2013, 04:06 PM   #10038
GrizzLee
RubiKon Adventures
GrizzLee's Avatar
Oddometer: 538
Originally Posted by Gravel Seeker View Post
That was helpful.
Everything is back together. Those springs were tough.
Oh, and I installed a Hockey Puck on the bottom of the foot. The lean angle is a bit better. Still could use a longer sidestand.
Thanks.
Take Care, -GrizzLee
"Nature Sets the Boundaries; We choose to cross"
Blog: RubiKonAdventures
RR: Destination Nuxalk Nation
RR: Our Life Behind Bars
GrizzLee screwed with this post 02-23-2013 at 07:35 PM
GrizzLee is offline   Reply With Quote
Old 02-24-2013, 01:34 AM   #10039
Gravel Seeker
Thomas
Oddometer: 4,004
I'm confused
Isn't the 19" GS and 21" Dakar identical except for the diameter of the rim and lenght of the spokes ?
When looking for brake pads I get very confusing hits...
Are the 19" and 21" brake discs/ rotors and pads the same ?
Any variation between years ?
Ex
19" Front 99-03
21" Front 04-09
But then I come across these
Front 93-08
Another front 93-08
Gravel Seekers.com
Hey !
Old 02-24-2013, 02:49 AM   #10040
WayneC1
Oddometer: 2,557
Yes, Wheel all the same other than rims and spokes. Caliper, disk pad's same
I would not trust the info from fleabay sellers. Many simply specify the parts separately as per the BMW model but they are the same
EBC and here on Oz Metalgear are reliable on info. See details on disc below
http://metalgear.com.au/mgear-brake-...ht-p-5776.html
On Metalgear they give you all the spec on mounting details etc and if a part is common to many makes/models it will be the same part No
Another good ploy (works even better on KTM Fiche) is to use the part search on realoem, it then tells you what models a part is fitted to. I use it to see if sensors etc are used on the cars. Turns up interesting things at times
Old 02-24-2013, 04:33 AM   #10041
Gravel Seeker
Thomas
Oddometer: 4,004
That's fucking genius
Gravel Seekers.com
Hey !
Old 02-24-2013, 04:38 AM   #10042
Gravel Seeker
Thomas
Oddometer: 4,004
The recessed/ counterbored bolt holes in the disc doesn't really make a difference, right ?
I reckon I can buy Pegaso discs and just add washers to my OEM bolts or get hold of 12 (2x6) bolts with recessed heads ?
Gravel Seekers.com
Hey !
Old 02-24-2013, 05:22 AM   #10043
WayneC1
Oddometer: 2,557
The recessed holes may prevent fitting the ABS ring, that is all I can think of and I suspect I can hear you say I dont need or have any F...ING ABS crap
As for genius, no just Ozzy, you been there, know what I mean, now where is a red dust puddle to roll round in
Old 02-24-2013, 05:28 AM   #10044
Gravel Seeker
Thomas
Oddometer: 4,004
You're right, I don't ahve ABS, but not because I don't need that fucking crap - my bike's too old. They didn't offer ABS in 2001, but I believe it cames as standard from 2002 or 03 over here.
Gravel Seekers.com
Hey !
Old 02-24-2013, 05:34 AM   #10045
WayneC1
Oddometer: 2,557
There are 3 variations on the ABS, the first 2 for the 650GS are regarded as crap by some because you have to stop to turn it on/off. They even have different wiring harnesses on these first 2 so it cant be retrofitted as far as I know, my 2002 is like yours, no ABS and hey stepping the rear out when you make a mistake is all part of the fun isnt it ?
Old 02-24-2013, 06:05 AM   #10046
TobyG
be happy :)
TobyG's Avatar
Oddometer: 563
The first 2 production years of the Dakar didn't have ABS, that's right, but the normal F650GS had the ABS Option available right away.
And the ABS has always been optional, but later on it was so cheap that only a very few people bought the bikes without it.
EDIT: My th post.
And it's a smartass post.
"a scoot (that wouldn't go more than 28mph if you dropped it out of an airplane)" ~duck
"If loud pipes saved lives, then ambulances would run straight pipes instead of lights and sirens." ~Phlemdog
This is why I always wear gloves. How you gonna wipe your butt with hands covered in bandages? ~MrBob
TobyG screwed with this post 02-24-2013 at 06:35 AM
TobyG is offline   Reply With Quote
Old 02-25-2013, 08:58 PM   #10047
chileperro
Chileperro
Oddometer: 19
wiring harness repair
So I shorted out my harness and it melted at the connection to my ABS unit. I'm looking at removing the abs and replacing the harness with a new one. The bms-c losks in good shape to the naked eye with no damage to the plug. I removed the cover plate and as far as i can tell, the circuit board looks clean and in good shape.
I am wondering, does anyone have any advice on how difficult it is to replace the harness?
Removing the abs seems straightforward as long as I get a non-abs harness.
Tips, thoughts? Am I crazy to attempt this?
chileperro is offline   Reply With Quote
Old 02-25-2013, 09:02 PM   #10048
WayneC1
Oddometer: 2,557
Well it is a bit of work, out of interest what exactly do you mean by "I shorted out my harness" ?
Old 02-25-2013, 09:22 PM   #10049
chileperro
Chileperro
Oddometer: 19
It means someone wasn't paying attention doing a jump start and clipped the negative cable to the wrong bolt on the bike and shorted it out; melted some leads to the battery and the plug to the abs sensor.
The bike ran after the incident, but suspecting things were not right, I dug a bit deeper and found the abs plug was melted along with the negative battery cable. All the diodes and fuses were okay.
Old 02-25-2013, 09:37 PM   #10050
WayneC1
Oddometer: 2,557
That will likely mean it is only the wiring bundle between the electrical box around the RHS which splits and goes to ABS/BMS and the starter motor is damaged, you could probably unwrap that section of the harness, repair and recover without complete harness replacement. Post up the pic's we love destruction, promise we wont be too hard on the comments
Would be worth unwrapping to look at what was carrying the current and which wires had insulation melted as a result.
There is a thread on advrider by Dwayne describing unwrapping that section to relocate his battery to under the seat it may help you
If you do attempt it it would be worth rewrapping the harness with the main power leads in a separate bundle
Times are GMT -7.   It's 01:22 PM.
