Old 03-12-2013, 06:33 AM   #10096
KG6BWS
KG6BWS's Avatar
Oddometer: 895
Originally Posted by Gravel Seeker View Post
Too bad you need an account for most things on that site.
I'm thinking the ring with the speedo tabs is #24 here (called the "Front wheel drive key") ?
http://www.ultimateparts.net/aprilia...ne-OEM&i=17622
You dont need an actual account, youre just registering with the site. Anybody can buy anything off there.
"But I swear, a woman's breast is the hardest rock that the Almighty ever made on this earth, and I can find no sign on it." Bear Claw Chris Lapp
Justin
01 F650GS Dakar
KG6BWS is offline   Reply With Quote
Old 03-12-2013, 03:53 PM   #10097
Got2Moto
Got2MotoGraphics
Got2Moto's Avatar
Oddometer: 505
Oil plug
I know I don't ever ask brilliant questions
so here's another
I just want to switch out the oil plug for an
oil drain valve.
Do I absolutely have to drain the top oil tank
or can I just drain the motor?
Got2MotoGraphics.Com
Got2Moto is offline   Reply With Quote
Old 03-12-2013, 04:12 PM   #10098
herrhelmet
A Serious Man
herrhelmet's Avatar
Oddometer: 2,369
so here's another
oil drain valve.
Need to drain that one separately.
"Your bike is too heavy" www.motolithium.com TWITTER
herrhelmet is offline   Reply With Quote
Old 03-12-2013, 05:04 PM   #10099
divimon2000
divimon2000's Avatar
Oddometer: 628
Just the lower sump drain.
divimon2000 is offline   Reply With Quote
Old 03-12-2013, 05:26 PM   #10100
BeachGuy
Alabama & Costa Rica
BeachGuy's Avatar
Oddometer: 482
[QUOTE=Got2Moto;20931181 Do I absolutely have to drain the top oil tank or can I just drain the motor?[/QUOTE]
If I understand your question correctly, I assume that you just want to install the new drain valve, not change the oil while your installing the valve.
Just for installing new valve you will only need to allow the bottom case oil to drain out. Then install the drain valve. Once this is done run the engine for a few minutes and leave the bike overnight. If in the morning you have oil leaking on the ground you get the privilege of removing the valve and adding some white permagasket tank sealant to the treads and re-installing it again, do not run the engine and wait until the next morning then run the engine. If you still have an oil leak, next step is drain, clean brass threads, install a new viton o-ring (local auto parts store), 24 mm gasket, more sealant and repeat the process. Sealant needs 24 hours to set.
Once it stops leaking you will thank yourself for doing it. Of course it might take two or three day to complete this little task, but that's why there's Rum or Beer.
I did not use the paper gasket which came with the valve. It was worthless. The bottom of the engine case seems to be machined to accept the 24 mm copper gasket and it was a sloppy fit with the new valve.
BeachGuy
2010 Ride Report: Orange Beach, AL to Jaco Beach, Costa Rica
2011 Ride Report: Costa Rica to Panama back to Costa Rica
2014 Ride Report: Ring of Ireland in 30 days
One of the beautiful things about riding solo is the quality of the social experience.
BeachGuy is offline   Reply With Quote
Old 03-12-2013, 06:45 PM   #10101
michael1968
michael1968's Avatar
Oddometer: 884
so here's another
oil drain valve.
Why don't you just wait until you need to change the oil and drain both...
michael1968 is online now   Reply With Quote
Old 03-12-2013, 10:48 PM   #10102
Got2Moto
Got2MotoGraphics
Got2Moto's Avatar
Oddometer: 505
Thanks very much!
I guess I just have a bit of OCD and very bored looking for something to do.
But your right, I think I will completely drain it and go back to dino oil while
I'm at it. The shifting isn't as smooth with the synthetic for me.
Defiantly will get that 24mm o-ring gasket! Thanks!
Old 03-15-2013, 12:45 PM   #10103
Mr.Dabalina
Mr.Dabalina's Avatar
Oddometer: 188
After some research I am getting ready to order a new battery, any suggestions? But my real question is I have a new GPS I would like to hardwire onto the bike as well as a cigarette lighter plug so I can charge my iphone. Any suggestions as to what I should order to do this? The main thing is I don't want to be stranded b/c of these but I would like to be able to do these. Any pics of how you have yours set up would be great.
Mr.Dabalina is offline   Reply With Quote
Old 03-15-2013, 01:04 PM   #10104
the venturer
the venturer's Avatar
Oddometer: 1,421
What I once did on mine was to take power directly from the battery. Dont worry, it wont suck up your battery power. On my cigarette charger, I also charge my camera batteries and phone but keep it doing so while riding, especially while charging camera batteries, just in case.
For the hardwire set, refer to your GPS make and make sure to add a fusing.Hope this helps.
the venturer is offline   Reply With Quote
Old 03-15-2013, 02:55 PM   #10105
kion
kion's Avatar
Oddometer: 184
Dakar shock
Where I can rebuild a Dakar shock these days or what would be the cheapest aftermarket option?
kion is offline   Reply With Quote
Old 03-15-2013, 03:34 PM   #10106
nomad5326
Xventurous
nomad5326's Avatar
Oddometer: 305
http://www.le-suspension.com/shock-services/
nomad5326 is offline   Reply With Quote
Old 03-17-2013, 06:57 PM   #10107
mischief
misadventurer
mischief's Avatar
Oddometer: 650
Ed at LE did mine and changed out the spring also. It still wasn't stiff enough and so I shipped it back to him and he installed another one for the shipping cost. I'm happy with it now.
Christi
"I have this moment and no idea when it will end" - Andrea Gibson
"The adventure begins when the plan turns to shit." I don't know who said that first but I like it 'cause my plan turned to shit a long time ago
mischief is online now   Reply With Quote
Old 03-18-2013, 06:50 AM   #10108
docwyte
docwyte's Avatar
Oddometer: 1,180
Checked out my friends KTM 950 Adventure yesterday and he had a set of bigger pegs that bolted onto his stock pegs, making a nice, large foot bed.
I'd really like to add a set of those to my bike, he wasn't sure if they were available.
Does anyone know of larger pegs that are made for our bikes?
'06 KTM 640 Adventure
docwyte is offline   Reply With Quote
Old 03-18-2013, 07:06 AM   #10109
WayneC1
Oddometer: 2,724
CG2005 over at f650 is doing just that for people on a custom basis, cant say I like some of the creations but he makes what people want
WayneC1 is offline   Reply With Quote
Old 03-18-2013, 07:19 AM   #10110
tomatoe333
tomatoe333's Avatar
Oddometer: 2,306
I've got a set of Fastways on my bike. Don't remember all the details but they weren't difficult at all to install.
"Keep the standard settings will be useful to learn more about the bike. One should reach a sufficient technical level, when then humbly questioning calibration of your motorcycles."
tomatoe333 is offline   Reply With Quote
Times are GMT -7.   It's 04:47 PM.
