Old 12-29-2009, 11:41 AM   #1351
Gravel Seeker
Thomas
Gravel Seeker's Avatar
Location: Dreary old Norway, dreaming of adventures past
Oddometer: 4,013
Originally Posted by GSBS
I don't think you want to run the FI bikes out of gas, not so much because of the fuel injector but because - as I understand it - the fuel pump is lubricated by gas and if run dry it could damage or grenade the pump.
Just sayin'...
I'd rather never run dry, but I've done it (bone dry) 3 times and haven't experienced any problems with the fuelpump. Hope nothing happens [crossing fingers]
'01 F650 Dakar - modified as best I can
2005: Australia - 8 months/ 26.000 km (anti clockwise circle)
2009: Norway - 2 weeks/ 6000 km (Lindesnes to North cape)
Gravel Seekers.com
Hey !
It's the African ant eater ritual !
Gravel Seeker is offline   Reply With Quote
Old 12-29-2009, 12:52 PM   #1352
john_aero
john_aero's Avatar
Oddometer: 1,173
Originally Posted by tomatoe333
Did you reconnect the air temp sensor on the snorkel after you changed the filter?
Leave that disconnected, and she'll run richer than normal.
i taught i did bit it may be not fully connected or not fitting right as i have taken it off good few times now when working on bike
women are like clouds.......
once they fuck off it is a really nice day.......
john_aero is offline   Reply With Quote
Old 12-29-2009, 12:53 PM   #1353
john_aero
john_aero's Avatar
Oddometer: 1,173
Originally Posted by dang
Yup. I enjoy ethanol free fuel here. I carefully measured the difference at almost 4.5% over several summer months clocked on the same commute, same general conditions. That's significant to my wallet.
not sure what story is here but still ireland eb same as uk and they all have had no prob
Old 12-30-2009, 08:40 AM   #1354
Cap'n Crunch
Smelly Adventurer
Cap'n Crunch's Avatar
Oddometer: 241
got it unlocked!
Push and pull on the bars while turning the key. It can sometimes stick.
Got it unlocked. I used the other key. Turned easy. Lucky I didn't bust off the other key. Happy New Year.
Pal
Cap'n Crunch is offline   Reply With Quote
Old 12-30-2009, 08:47 AM   #1355
pyrate
Walking the plank
pyrate's Avatar
Oddometer: 1,177
Pal
Whatcha go there, a valet key? Opens the trunk but nothing else?
"but why is all the rum gone?"
pyrate is offline   Reply With Quote
Old 12-30-2009, 09:55 AM   #1356
Cap'n Crunch
Smelly Adventurer
Oddometer: 241
Hmmmm. One key is a normal looking BMW MC key. That is the one that unlocked the steering. The one that locks but won't unlock is a round metal cylinder, the size of a plastic soda bottle top, with a key sticking out of it. Is that a valet key? It unlocks the trunk, starts the bike, and locks the wheel.
Any problems using 10% ethanol blend fuel? It's hard to find non-blended fuel in my area with octane above 87.
Old 12-30-2009, 10:14 AM   #1357
pyrate
Walking the plank
pyrate's Avatar
Oddometer: 1,177
Seems odd that it will do everything but unlock the forks. Both of my keys work identical. I have only owned my bike since April so don't have the back ground that others do. Perhaps a stop at your local dealer can at least tell you what the key is for, especially since they look different.
I only burn 87 octane fuel and have no issues with it. All of my other bikes I have always burned the highest octane I could get but after reading here and on the chain gang site it was highly encouraged to stick with 87. Great mileage (high of 68, low of 59) and no performance trouble at all. I ride a sea level most of the time but have been up to over 10,000 and flawless performance in every condition.
Old 12-30-2009, 11:08 AM   #1358
soloyosh
Dad and husband
soloyosh's Avatar
Oddometer: 5,480
Looks like your previous owner bought one of these:
http://cgi.ebay.com/ebaymotors/Key-H...Q5fAccessories
Same key just customized.
2007 Aprilia RXV 5.5
soloyosh is offline   Reply With Quote
Old 12-30-2009, 02:06 PM   #1359
talltony
Oddometer: 138
Originally Posted by john_aero
Anone else having probs with fuel MPG. i am getting 140miles before fuel light comming on where as i know should be getting a lot higher till it gets that low for light go on.
is there anything that you have seen that may cause this?
The float switch that controls the fuel light is adjustable therefore the mileage at which it comes on is no indicator of fuel consumption.
Take note of how much fuel is needed to top up the tank and work out the mileage from that.
If it proves to be excessive,then there are some fairly simple things to check but
get the MPG first!
Tony
02 F650 Dakar
95 XR250
talltony is offline   Reply With Quote
Old 12-30-2009, 07:20 PM   #1360
Cap'n Crunch
Smelly Adventurer
Oddometer: 241
That's the key I've got. On close examination, the fancy farkle fob doesn't allow the key to go into the cylinder fully. Just enough difference to cause trouble.
Old 12-30-2009, 07:41 PM   #1361
pyrate
Walking the plank
pyrate's Avatar
Oddometer: 1,177
Don't you hate farkles that screw you up and make you wonder what is wrong? All for nothing.
Great that you figured it out before it stranded you.
Old 12-30-2009, 11:22 PM   #1362
mcgiggle
Oddometer: 272
temp sensor
Just a quick heads up. I'm not sure if this is common knowledge, the fan has stopped working so I checked everything, putting 12v onto fan and it worked, checked wiring and fuses all OK so thought it must be the sensor.If you unplug the sensor the fan stays on permanently while the engine is running, OK not a cure but if your somewhere relatively hot it's better to have it on all the time rather than not at all.
Pete
UK-India-UK 2009/2010
Current trip Buenos Aires-NYC
http://www.facebook.com/curryhunt
mcgiggle is offline   Reply With Quote
Old 12-31-2009, 10:02 AM   #1363
Uhuru
Wildest place I've been
Uhuru's Avatar
Oddometer: 153
Happy New Year!
Happy New Year, everyone!
I'm starting it out right with a wintry ride on my baby, all decked out with new Ohlins and new progressive wound front springs I gave her for Christmas. I'm excited!
What did you give your baby?
Butch to gambler: "What would you think of maybe asking us to stick around? You don't have to mean it or anything."
Uhuru is offline   Reply With Quote
Old 12-31-2009, 10:12 AM   #1364
Yukon65006
Yukon65006's Avatar
Oddometer: 536
Suspension front and rear, Racetech springs and emulators already installed awaiting the return of the Sasquatch rebuild for the rear. Also having the seat redone by XPC with alittle custom embroidery on it.
______________________________________
Turn signals are like farts, never trust them.
Yukon65006 is offline   Reply With Quote
Old 12-31-2009, 10:16 AM   #1365
Uhuru
Uhuru's Avatar
Oddometer: 153
Awesome. I've been in line for a Renazco seat for months. It won't be built until sometime in March.
Times are GMT -7.   It's 09:24 AM.
