01-22-2010, 08:42 AM
#1471 | |
Walking the plank
Oddometer: 1,152
"but why is all the rum gone?" ![]() 2008 YAMAHA FJR |
01-22-2010, 09:01 AM
#1472 | |
The Old Fart
Oddometer: 1,624
Thanks for clearing this up for me.
Can you tell me something about the shims? Are they a standard size that I can find locally, or do I have to go through a BMW dealer to get them? I'd like to find a box of them like the guy in the ChainGang DVD has. I can't imagine getting everything pulled apart and then having to wait a couple of weeks to get the correct shim size mailed to me.
"Fiona" - 1982 R100RT - Hacked - EML suspension, Squire ST2 chair "You can tell a woman's mood by her hands. If she has a gun in one, she's probably mad." |
01-22-2010, 09:10 AM
#1473 | |
Wildest place I've been
Oddometer: 151
If the total height of the wheel/tire combo doesn't change going from a 21 inch rim to a 19 inch rim, as you state, it sounds like there would be no difference in handling, assuming the tires were the same design, but somehow that seems wrong to me, with a 2 inch shorter diameter rim. Now I'm really scratching my head. Anyone able to help me understand?
Butch to gambler: "What would you think of maybe asking us to stick around? You don't have to mean it or anything." |
01-22-2010, 09:34 AM
#1474 | |
Walking the plank
Oddometer: 1,152
19" Rim with street tire, with a taller sidewall, gives a bit more because of the sidewall of the tire. Depending on your choice of tire and how stiff the sidewall will make all the difference in the world.
01-22-2010, 09:36 AM
#1475 | |
Walking the plank
Oddometer: 1,152
The big difference would be if you went with a super motard kind of set up where the front and rear wheel are the same size with the same size tire. That will change things dramatically.
01-22-2010, 09:48 AM
#1476 |
Oddometer: 151
Thanks, Pyrate, I get your explanation about low profile tires and dirt tires, but...what if you had, to be specific and avoid confusion, a new 21 inch Metzeler Tourance tire on a 21 inch rim and you want to compare its total height and performance to a 19 inch Metzeler Tourance tire on a 19 inch rim? That is the part I don't get...the overall tire height isn't still going to be the same, is it?
01-22-2010, 10:01 AM
#1477 | |
Ravening for delight
Oddometer: 8,645
Anyway, the shims... I honestly don't know. I have been fortunate enough to never need to change one yet. I bought the chain gang valve check kit, which included a small selection of shims, and only hope that if I need one it will be there. Since the engine is a Rotax, I suspect that obtaining shims from a snowmobile dealer or something would be very possible. I just have no experience with doing so.
Why did I drink all of the ingredients for vomit? "Used to be Man vs. Nature.. then Man vs. Space.. then Man vs. the Moon. Now it's Man vs. Food" - Dalar "you cannot reason a person out of something they were not reasoned into." - Jonathan Swift |
01-22-2010, 10:13 AM
#1478 | |
Oddometer: 543
What's wrong with your 21 inch on a long trip? Do you have any complain so far? Most of the highways in US are straight. Unless you are taking your bike supermoto style and do a lot of twisties and tracks, I don't see why you can't live with the 21 in rim? You will probably get better handling if you drop the fork and rear shock. But hey what's why you have a Ducati for, right?
01-22-2010, 10:36 AM
#1479 | |
Oddometer: 151
Forget most of the highways in the U.S., I live in Colorado, so mountain roads are where I ride. Think needing to make many very tight 10-15mph turns climbing up to a mountain pass--that is what is common where I ride. (I know, I know, this is a GREAT problem to have). A favorite ride of mine, Trail Ridge Road, is over 12,000 ft. This is what makes me think a smaller 19 inch front wheel would be more nimble than the 21 inch stock, thus better for my kind of riding.
01-22-2010, 12:25 PM
#1480 | |
Oddometer: 28
I just re-re-re-re- use the o ring and anneal the copper washer. donno if its considered as bad practice, but its sure frugal
![]() Quote:
01-22-2010, 12:36 PM
#1481 | |
Walking the plank
Oddometer: 1,152
My bikes previous owner obviously thought of this and when purchasing the 19" front wheel and tire, bought a tire sized in such a manner that it is the same exact overall height. I would never buy the same exact brand/model tire for a 21" and 19" wheel (Metzeler Tourance for example) because it would not make any sense for my use to do so. When I have the 21" wheel on the bike I am more prone to ride in the dirt so will run the knobby TKC-80. When I run the 19" it is for street use so would run the street Metzeler for example. So I guess I have never made the comparison you are trying to do running the same type of tire for both wheel sizes (i.e. - 100/90-19 & 90/90-21 Metzler)but rather run two completely different types of tires but keep the overall diameter of wheel and tire the same. Clear as mud?
01-22-2010, 12:39 PM
#1482 | |
Walking the plank
Oddometer: 1,152
Thanks for the response.
01-22-2010, 12:57 PM
#1483 | |
Oddometer: 151
01-22-2010, 02:58 PM
#1484 |
Oddometer: 450
voomvoomgood on you for annealing the washer. Look around Adv a little and you'll see people get pretty freaky about only using new parts though. When I trained for my aircraft mechanics license in the 70s we were allowed to anneal copper washers. Dunno about o-rings though. Oddly reusing them wasn't recommended but you could make them from a roll of stock with superglue. Go figure. |
01-23-2010, 03:55 AM
#1485 | |
Thomas
Location: Dreary old Norway, dreaming of adventures past
Oddometer: 3,390
'01 F650 Dakar - modified as best I can 2005: Australia - 8 months/ 26.000 km (anti clockwise circle) 2009: Norway - 2 weeks/ 6000 km (Lindesnes to North cape) Gravel Seekers.com Hey ! It's the African ant eater ritual ! |
