Old 05-16-2011, 05:53 PM   #1666
Sean-0
Kicker Brother
Sean-0's Avatar
Oddometer: 3,048
Ok kennyrob , gave it ago , no success , can get blinkers to power up but wont flash , tried remove bulb from dash no luck , will go to jaycar and get some load resistors , so i can see if that works , no pwr sav with this effort but it may work using the stock flasher and ill look further into it
Sean-0 is offline   Reply With Quote
Old 05-16-2011, 07:17 PM   #1667
KASUYAHO
Road Hog
Oddometer: 2,892
Originally Posted by rocketmanphil View Post
I Had been bidding on a Good used 6.3 Acrebis tank and early this am checked to see how it going and found that it had Hit US $243
unreal ! as the new price is $309
Crazy hey how some people get wrapped up in it.
I got mine from Justgastanks, $330 landed here around there anyways.
The Safari tank is cheaper to buy from the US and ship it here,
than buy it here in Aussie.
Just shows how our tax structure here is just so against business here
and for business overseas.
Old Harvey Norman did have a point.
KASUYAHO is offline   Reply With Quote
Old 05-16-2011, 11:49 PM   #1668
kennyrob
Oddometer: 95
http://nbboss.en.made-in-china.com/product/ybuEgFwJEDVk/China-Auto-Flasher-LED-FLL006
found this website where your flasher unit came from.
http://nbboss.en.made-in-china.com/p...D-FLL006-.html
doesn't tell you much but you can see all the different types they make.
First of try testing your flasher unit on the bench with a 12v battery & one LED light (it might be a dud)
have a look at this gives a bit of instruction
http://www.ebay.com.au/itm/12V-LED-F...item1c1baf75b1
try with your standard blinkers fitted
then try leaving the - disconected
then try joining the - to the L (can't hurt)
Just for a bit of info, I run a 2 terminal el-cheapo aluminium flasher can with the 2 gray wires joined to one terminal. It's what the P/O had in the box of lights etc I had to put back on.
It has worked fine for the last 2 years & I've since fitted LED globes to the rear blinkers to conserve power & stop the brake light flashing. works good.
Maybe it's true, YOU CAN'T FIT LED BLINKERS TO a BRP
kennyrob screwed with this post 05-17-2011 at 12:08 AM
kennyrob is offline   Reply With Quote
Old 05-17-2011, 12:14 AM   #1669
Sean-0
Kicker Brother
Sean-0's Avatar
Oddometer: 3,048
Thanks kennyrob , tryed a few different options , can get em to light up but no flash , went to jaycar a got 4 10wat resistors and still the same light up but no flash , i have a 3 pin flasher on my other bike that runs led blinkers and works fine , i will try that flasher to see if thats the problem , i just hate to have to start the bike to test my idea's , need to change my coolant out and sort out a fan to keep the temp down while i tinker
this is the flasher i have , http://cgi.ebay.com/ebaymotors/Elect...-/250725598329
Sean-0 screwed with this post 05-17-2011 at 12:22 AM
Old 05-17-2011, 02:14 AM   #1670
rocketmanphil
rocketmanphil's Avatar
Oddometer: 186
It's Alive
Well then here goes
Here is a breakdown of parts that I have either repaired or replaced on my Friggin Red Pig. I sourced parts from a local dealer to interstate and even usa (via ebay)
The work that I have done has not been possible without the help of all of you from the ADV site. And there has been a lot of help ! For that I thank you.
I had missed out on the purchase of an old XR600 so began a search and found the PIG
When I bought the PIG it had been badly treated but was in my price range and I knew that over time (more than a year) I would be able to re-build it back into something that I wanted.
when I got the bike home and started the arduous task of stripping her down I soon found that this was going to take awhile :) it had been prettied up as a motard ! Not that there is anything wrong with them okay ? But this one had been ill treated :(
first to strip was all the plastics ! Then the fun began :(
To date some of the parts that I have either replaced , repaired, or rebuilt in some form or other
Both chain adjuster Bolts frozen solid....... drilled out and re-tapped
front forks rebuilt and all seals replaced
rear end was rebuilt, re-gas'd and re sprung all by Eiback
fenders front and rear replaced
chain block,sliders and rollers replaced
sprockets front and rear replaced
DID chain installed (X ring)
Retainer replaced (one that the disk guard bolts onto)
steering head bearings replaced
bash plate installed
frame guards left and right installed
clutch cover installed
radiators replaced
radiator guards installed
all hoses replaced
thermostat replaced
Acrebis hand guards installed
left hand switch block installed
replaced headlight and shroud
made a small windscreen
brake switch (attaches to front lever) installed
Speedo re-calibrated
fork guards installed
Fork boots replaced with rubber ones (OEM were shit)
Rear support bracket re-installed (holds the indicators)
side covers replaced
Pivot Pegs ( I've got big feet )
Right hand Foot peg bolts replaced
Arrow Exhaust system (muffler re-packed & rebuilt) shortened 20 mm
headers re polished (by hand covered in shit)
headers wrapped in heat resistant wrap
Tyres replaced, Kenda knobbies trail mastersi know there are better out there)
Continental 4mm tubes installed
re wire of headlight and switch gear using same colour as OEM
re-wire of rear loom again to OEM
this was all hard soldered to survive !
And a Bag full of bolts/screws/nuts/clamps !
All this work was made possible by my Makita hammer drill and Impact Screwdriver coupled with the good old hammer ( I Kid Ye Not )
Again it would have been very difficult to do all this work without your assistance.
Rocketmanphil Thanks you and this top site ADV
A man may smile and bid you hail
Yet wish you to the devil;
But when a good dog wags his tail,
You know he's on the level.
rocketmanphil screwed with this post 05-19-2011 at 02:07 AM
rocketmanphil is offline   Reply With Quote
Old 05-19-2011, 05:11 AM   #1671
KASUYAHO
Road Hog
Oddometer: 2,892
Phil,
Did you run a book to see how much it cost you all up ?
Old 05-19-2011, 06:58 PM   #1672
rocketmanphil
Oddometer: 186
tooooo much
Originally Posted by KASUYAHO View Post
Phil,
Hi there Kasuyaho
in reality the further that I dug into the Pig the more I found wrong so ...
cost me tooo much, all up on the re-conditioning of the Friggin pig has been $2500 (other half would say stupidity) but I was unable to spend more on a bike at the time that I purchased it.
But the gain has been that I was able to do most of the work and in an event when I get high sided or etc I will know how to fix it.
I still have a wish list of Tank, racks of some form and a few other items
but they will have to be over time and discreetly done if you know what I mean
Old 05-23-2011, 06:12 PM   #1673
MymoJoe
Ride Ride Ride
MymoJoe's Avatar
Oddometer: 2,332
Solice LED lights
http://www.andystrapz.com/products-d...Id=101&Level=1
Hey groovers, I am looking for more light for my XR650R. I have a cracker Cyclops HID, but it needs a battery to ignite the starter... so I have put that on my tiger, does anyone know if the XR will drive one of these LED spot lights from Andy Strapz?
They seem like the real deal... I will look at getting the Stator upgraded at some point, but for now I just want a quick fix.
Joe
Simpson Trip 2008
http://www.advrider.com/forums/showt...33#post7397233
Life should NOT be a journey to the grave with the intention of arriving safely in a well-preserved body, but rather to skid in sideways, body thoroughly used up, totally worn out and screaming "WOO HOO - what a ride!"
MymoJoe is offline   Reply With Quote
Old 05-24-2011, 12:29 AM   #1674
digga1111
broooommmm brooommm
digga1111's Avatar
Oddometer: 2,737
Joe
they look alright ey. the headlight circuit is ac and that requires dc. just needs a rectifyer.
i got these on the way
https://www.bajadesigns.com/2009/art...tealthpop.html
middle 6 in spot and 2 each side in spread. has hi and lo beam and strobe function. yes yes i know its not really hi and lo but it will do
gunna try and fit em in this
https://shop.rallyraid.co.uk/proddet...?prod=RRXR650F
iam going to ask the fella at betta bikes if i can change the whole bike to dc and be done with it
iam just not ready to be an adult
digga1111 is offline   Reply With Quote
Old 05-24-2011, 12:49 AM   #1675
KASUYAHO
Road Hog
Oddometer: 2,892
Joe
If you mean the output of the stator will it drive this light yep.
The formula is:
Amps by voltage = watts
.75 amps multiplied by 12.6 volts = 9.45 watts drawn from the stator.
Watts / Volts = Amps
The output of the stock stator is what ? 45 watts?
45 watts divided by 12.6 volts (roughly) = 3.57 amps stator output
KASUYAHO screwed with this post 05-24-2011 at 12:57 AM
Old 05-24-2011, 01:03 AM   #1676
kougar
go hard or go home
kougar's Avatar
Oddometer: 406
come on joe,dont start them again on the bloody headlight thing , just get rid of the brp and buy something with a battery. and buy the way how are you mate.
kougar is offline   Reply With Quote
Old 05-24-2011, 04:03 AM   #1677
MymoJoe
Ride Ride Ride
MymoJoe's Avatar
Oddometer: 2,332
hmmm
hey AClown, been a while mate. If I could find some donkey to swap my hot XR650R (with newly fitted pumper carb) for his KTM950 (SE or ADV) I would get another 950 in a heart beat... I have spent way to much on the BRP to sell it now, owes me crazy money, but I would suggest it would be one of the best around.. anyone want to swap a hot BRP and 955 tiger for a 950SE????????
When are you off on your trip mate? we should drag (speaking of drag queens) Doug out on his gay sewing machine for a ride soon.
Joe
Simpson Trip 2008
Old 05-24-2011, 11:57 AM   #1678
kougar
go hard or go home
kougar's Avatar
Oddometer: 406
Joe
mate get the bus back in 2 weeks,house 4 sale now,i reckon we do a ride soon,real soon,acouple of day ride somewhere,i can get a few others 2 come who dont mind riding at full noise.
Old 05-24-2011, 01:28 PM   #1679
MymoJoe
Ride Ride Ride
MymoJoe's Avatar
Oddometer: 2,332
Full noise?????
good news with the trip mate.. will be fantastic
what is this riding at full noise mate... you know I don't like to get my hair messed up by going to fast!!!
Simpson Trip 2008
Old 05-24-2011, 01:40 PM   #1680
galbo950
galbo950's Avatar
Oddometer: 483
Full noise for Kougar isn't fast, its just him yelling and screaming as he gets left behind. So Kougar where are you heading first?? You coming up this way or for our winter or are by the time you leave it'l be summer and getting a bit to hot to be up this way?? If you come outside our wet season, your more than welcome to park the bus down on the back paddock. If you decide to come up in the wet you can still park there but just keep in mind the river can come up a little high and it would mean you may be stuck on your own little island for a few hours to a day at the most. With this years wet it came up extremely high only once at about 2am but it was back down by 6am. Only other problem was that the bridge out was under water for 2 days.
galbo950 is offline   Reply With Quote
Times are GMT -7.   It's 11:07 AM.
