Old 05-26-2011, 12:36 AM   #1696
Sean-0
straya carnt
Sean-0's Avatar
Oddometer: 4,423
I shot beta bikes an email Monday no response
Sean-0 is online now   Reply With Quote
Old 05-26-2011, 12:38 AM   #1697
digga1111
bann ed
digga1111's Avatar
Oddometer: 3,515
ring im up mate, he might be old school.
iam just not ready to be an adult
[QUOTE=troy safari carpente;24254589]
... the XR is the greatest off road motorcycle ever constructed. There's nothing it can't do, hasn't won or will not outperform.
digga1111 is offline   Reply With Quote
Old 05-26-2011, 12:46 AM   #1698
Sean-0
straya carnt
Sean-0's Avatar
Oddometer: 4,423
LOL yea i was gonna on monday arvo , i went kicking and screaming into the new age several yrs ago , but these-days im so glad i did
Old 05-26-2011, 02:11 AM   #1699
rocketmanphil
rocketmanphil's Avatar
Oddometer: 187
quick as
Hey Sean-o
he is not the quickest responder to emails, but will get there !
It is on my wish list to have one of his setups, I think what he does is built to live a bit ! instead of a horizontal headlight they are vertical twins, but obviously he will do it all.
A man may smile and bid you hail
Yet wish you to the devil;
But when a good dog wags his tail,
You know he's on the level.
rocketmanphil is offline   Reply With Quote
Old 05-26-2011, 02:22 AM   #1700
Sean-0
straya carnt
Sean-0's Avatar
Oddometer: 4,423
Yea its all good , This was and is on my list of things to do , nxt is the suspension , need good light tho , I just need a time frame when suits them , ill rip it off what he needs and send down to them ,
Old 05-26-2011, 03:19 AM   #1701
rocketmanphil
Oddometer: 187
all lit up
let me/us know what you end up with, Sean-o ........... that is way into next year for me that is of course if i survive this year
Old 05-26-2011, 04:39 AM   #1702
KASUYAHO
Road Hog
Oddometer: 3,641
Has anyone seen a 4 inch light as in reflector, 4 inch that can take a HID high low lamp in it ?
KASUYAHO is offline   Reply With Quote
Old 05-28-2011, 03:50 PM   #1703
KASUYAHO
Road Hog
Oddometer: 3,641
Head lights
This is what i am thinking of having a play with down the track.
Then use these HID lamps at either 35 watt or 55watt lamps.
Apparently from what i amke of it the lamp is on all the time and then
to go from low to high beam the lamp angle changes.
Nifty idea.
http://www.delonixradar.com.au/hid-xenon/
This is what they say:
Most standard halogen light bulbs in your vehicle are 55watts. They produce around 700 – 1000 ‘lumens’ of light onto the road. 'Lumens' is simply the word given to the measurement of light output. Another word sometimes used to describe the amount of light output is "Candlepower". The difference between using "lumens" and "Candlepower" to describe the brightness is that "Candlepower" also takes into account the optics of the light (including reflectors, lens etc) whereas "lumens" is simply a measurement of the light output without any optics. Since optics vary from different light sources, there is no linear conversion from candlepower to lumens (or vice versa).
So for the pupose of discusing brightness in HID kits, we only use "lumens".
Traditional Halogen globes put out around 700 - 1000 lumens of light.
35watt HID kits by comparison put around 2800 – 3200 lumens of light onto the road (around 3 times brighter than normal halogen globes).
55watt HID kits put almost 5000 lumens of light onto the road – around 5 times brighter than normal halogens.
55watt HID are best suited for spot lights or high beams.
People always ask us which one to go for. Our opinion is that 55 watt HID lights are simply too bright for use in normal / low beam headlights. You may find the glare being reflected from wet roads, or street signs back into your eyes is too much with 55 watt on low beam lights.
Therefore we always recommend using 35 watt globes on any lights that will be used for low beam, and save the 55 watt HIDs for spotlights or single beam high's.
KASUYAHO screwed with this post 05-28-2011 at 04:30 PM
Old 05-29-2011, 09:22 PM   #1704
rocketmanphil
Oddometer: 187
cost
Found an email that I had sent to Betta bikes, for the vertical headlights ( The ones that I like) it is around $675 (they use Hella and Narva) and for the Stator re-wind it is $295
The Stator rewind is dependent on what you want ! i.e full on burn the eyeballs outa skippies sockets !
or to having the chance to wire in your GPS/Phone, but still need to add into it a battery.
So all up they will re-wire the handle bar switch to handle the heat, extra wires from the stator,
Headlights and brackets that are polished and laser cut, so it depends on what you want
Old 05-30-2011, 12:24 AM   #1705
digga1111
bann ed
digga1111's Avatar
Oddometer: 3,515
got my new fairing the other day
gives heaps of room for other stuff up front now
Old 05-30-2011, 01:25 AM   #1706
KASUYAHO
Road Hog
Oddometer: 3,641
Very flash there Digga
Old 05-30-2011, 02:36 AM   #1707
AdventureXR650
Esquire
AdventureXR650's Avatar
Oddometer: 147
Set for 6 weeks in the desert
Refreshed the top end of the motor, upgraded the electrics (no AC all DC), steering damper and some bling bits too to make life easier.
What's money for if you can't spend it ay?
AdventureXR650 is offline   Reply With Quote
Old 05-30-2011, 02:50 AM   #1708
Sean-0
straya carnt
Sean-0's Avatar
Oddometer: 4,423
my red tank would look so much better on your bike now digga screen look good mate , whats the space for , a stubby cooler
AdventureXR650
You look set mate , bike looks ready to rumble , may i suggest seat-concepts for a nice ride in the pants department ,
6 weeks of bliss , plz take pics
Old 05-30-2011, 02:55 AM   #1709
digga1111
bann ed
digga1111's Avatar
Oddometer: 3,515
luggage setup looks the goods 6fiddy. what sort of frame you got
Old 05-30-2011, 03:15 AM   #1710
vonkas
Oddometer: 57
back home after 6500 KM Outback
just back:
trip pics:
prep stage:
tech pics:
vonkas screwed with this post 05-30-2011 at 03:56 AM
vonkas is offline   Reply With Quote
Times are GMT -7.   It's 01:47 AM.
