Old 03-25-2009, 03:50 AM   #46
jack82 OP
jack82's Avatar
Oddometer: 263
Originally Posted by ADVJake
rock up to your local bike shop and find the highest bend you can, along with some bar risers to adapt to your stock bar clamps.
I'll be fitting a scotts dampener once i get some CR500 triples for the USD front end with a forward post.
That's the problem tho Jake.......I can't use risers unless I change the mount arm setup [arm aint long enough].......just need higher bars,.
jack82 is offline   Reply With Quote
Old 04-06-2009, 03:48 AM   #47
jack82 OP
jack82's Avatar
Oddometer: 263
Anyone know where I can get some longer throttle cables that will fit the stock housing ??
Old 04-06-2009, 05:24 AM   #48
pRICK
Oddometer: 316
Most bike shops will make cables, even mower shops make cables. When I had longer cables made they used the old adjusters and fitted longer outer and inner with new ends. Very simple to do.
pRICK is online now   Reply With Quote
Old 04-08-2009, 01:52 AM   #49
rowdy_im
KTM 625 Snowy Mountains
rowdy_im's Avatar
Oddometer: 365
Wicked
[quote=jack82]
Don't think you'll have to spend $6.5..........that sort of $$$ would get you a near new one.I paid $4500 for an 03 with 15,000 kays.....12 months rego....scotts damper.....bashplate etc.
Did a 400 km bush ride on the weekend with a mate on an XT600..... ......his bike ewas nicer (more comfy,smoother) on the road and easy firetrails but everywhere else I'd take the XR.
I've only had this bike for a week but I think it's a keeper.The motors a gem.......it's happy plodding around or ripping it up.
are ya heading up to Delegate this year
good to see ya brought a real bike ,hows the Buell going....
got a mate that will be a Delegate that knows shit loads about XR 650R
had one for years
Rowdy
ar
rowdy_im is offline   Reply With Quote
Old 04-08-2009, 02:54 AM   #50
jfn68
Oddometer: 620
Do the xr650s have/had any problems with choke butterfly breaking on the std carb?,see ballards do a update for the 600 and also showed a updated/stronger whatever chokeplate for 650 models......any info gents?
jfn68 is offline   Reply With Quote
Old 04-09-2009, 07:47 PM   #51
jack82 OP
jack82's Avatar
Oddometer: 263
[quote=rowdy_im]
had one for years
Rowdy
ar
Yeah mate........Delegate is on the list.
Buell's going good.......the XR's a bit easier to punt on the dirt tho.......
Old 04-09-2009, 10:00 PM   #52
Phil_Fong
Labelled Extremist
Phil_Fong's Avatar
Oddometer: 10,100
I bought one for the xr400. Apparently the butterfly is the same on the 600 and 650's. The standard has two holes in the plate right across where the pin sits to swivel the butterfly plate, causing fatigue.
The Ballards plate has no holes, no weak points.
Ballards run a special purchase, buy the choke plate and get the CDI protector plate too, for $29 all up.
tEAM nONG - Quorn Schnitzel Club
Phil_Fong is offline   Reply With Quote
Old 04-09-2009, 10:31 PM   #53
jfn68
Oddometer: 620
Thumb
Old 06-03-2009, 04:27 AM   #54
jack82 OP
jack82's Avatar
Oddometer: 263
Okay.......I'm starting to love the XR and thinking it could be a really good bike with a few mods,.....first being the suspension,
I'm told "teknik" are the boys to see ??......whatayareckon ??
Also looking for some shorty levers that will fit the stock perches ??
Old 06-03-2009, 05:11 AM   #55
touser
canned fruit
Oddometer: 325
I bought one about a month ago and I'm liking it more each time I ride.
2005 with 8,000k's and a few goodies thrown in for $5,500, so there about.
I know the voices arn't real, but they do have good ideas.
touser is offline   Reply With Quote
Old 06-03-2009, 05:13 AM   #56
af300e
Oddometer: 275
Spent the weekend riding around Dargo.......$4500 well spent I think.
Nice motor....but I did notice alot of mechanical noise coming up at me.....put it down to the bashplate but......how noisy are these things ??.......this ones waaayy louder than my WR450.
Mine is pretty noisy, like a clacking. Sounds like piston slap or even big end.
Apparantly it's nothing to worry about..........mine has the stock plastic bashplate.
Changed the carb for a 40mm FCR. Has changed the bike profoundly. I had to machine an adapter and massage the tank, but it's the best $250 i could spend on the bike. Also added a 16l tank and i'll put an alloy bashplate and sort the bars a bit better.
I've done about 500km on mine, about one third proper trails, a third windy mountain roads and a third hwy.
Sounds as though we need a Vic pig ride :)
af300e screwed with this post 06-03-2009 at 05:25 AM
af300e is offline   Reply With Quote
Old 06-03-2009, 05:35 AM   #57
jfn68
Oddometer: 620
Anyone after chains/rear sprockets,chaingang has rears/good quality chains still for sale,got a couple of 46tooth rears and a gxw rk last week from them
Old 06-05-2009, 02:46 PM   #58
TB650
Would be Adventurer
TB650's Avatar
Oddometer: 535
Hi ya
My XR650 is ex GHR thats was never raced it has had the suspension done by teknik's couldnt say enough about them.
My shorty levers I got from Fathead at Battyes Bikes Sydney 02 95435133
I have a MSC damper under bar mount with K Windham high bend Pro Taper bars as per picture and I run standard length cables
I have raced and ridden mine now for 4 years and haven't had a problem that wasnt caused by my stupidity and mine has HRC engine kit
TB
XTZ660, GHR XR650
www.obtrailriders.com
TB650 screwed with this post 12-13-2010 at 02:21 AM
TB650 is offline   Reply With Quote
Old 12-30-2009, 01:28 PM   #59
jack82 OP
jack82's Avatar
Oddometer: 263
Brake light wiring ??
I've got three wires coming from the brakelight to the loom under the seat.....red/black and black&white...
Can anyone tell me what colour wires these plug into...???......cheer's.
Old 12-30-2009, 09:27 PM   #60
1coolbanana
1coolbanana's Avatar
Oddometer: 1,221
The kick only is no hassle once you get them setup right, and learn how to kick em'
What do you mean by set up right?
Mates got one, bought it with 10k on it, couldnt start it (the guy he bought it off had no problem), uncorked it, put a carby kit through it and still cant start the damn thing without 20 goes at it
Spend half our day waiting for him to start the bastard.
Any tips I can on setup and kicking give him? (apart from sell it)
1coolbanana screwed with this post 01-01-2010 at 12:05 AM
1coolbanana is offline   Reply With Quote
Times are GMT -7.   It's 05:36 AM.
