Thread Tools Rating: Thread Rating: 306 votes, 5.00 average. Display Modes
Old 02-17-2013, 07:06 AM   #2236
Lil Earle
Sweatin, not scared
Lil Earle's Avatar
Oddometer: 105
It is a 63cm frame. It fits just fine. I cleaned it up and put new tires, tubes and brake pads. It will be my Sunday morning cruiser on the local bike paths.
Originally Posted by zouch View Post
pretty, but dang! judging by the looks of it, you and your friend are both, what, about 6'5"?
original rubber?! must be because of that fancy double kickstand,...
throw that rotten old rubber stuff away before you try riding it and it puts you on the ground. (hopefully it's got 700C rims, and not 27",...)
One more repossession and I'll be out of debt.
Lil Earle is offline   Reply With Quote
Old 02-17-2013, 07:18 AM   #2237
ducnut
Oddometer: 3,320
that Raleigh was never *that* nice a bike that it's worth hermetically sealing.
ride it!
Oh, definitely ride it.....just not into the ground. Now, don't you be laughing at my Raleigh Reliant I'm lightly restoring.
Its aluminum components will look like this Schwinn hub I restored.
Sample lever.
'09 Triumph Tiger1050
'96 Ducati 900SS
'02 Suzuki SV650S (hers)
ducnut is offline   Reply With Quote
Old 02-17-2013, 01:16 PM   #2238
Andrew
Optimus Primer
Andrew's Avatar
Oddometer: 15,826
I'm testing out a set of Nitto Bullmoose bars on the QuickBeam. It's pretty fun being even more upright on the bike, and the wide sweep of the bars makes feel like a king, out surveying the countryside.
Splitting lanes, and splitting hairs.
Andrew is offline   Reply With Quote
Old 02-17-2013, 07:43 PM   #2239
soyanarchisto
soyanarchisto's Avatar
Oddometer: 3,584
Originally Posted by Nihon Newbie View Post
That's funny...I like it even more because of that little thing. I bet it makes wheel swaps easier, not having to hold so much tension as you do with fixies.
I guess I don't understand your comment that I initially responded to. You said you admired the simplicity. A chain tensioner detracts from that.
soyanarchisto is offline   Reply With Quote
Old 02-17-2013, 08:58 PM   #2240
Andrew
Optimus Primer
Andrew's Avatar
Oddometer: 15,826
This might be one of the best looking bikes I've ever seen online. Great simplicity, and elegance of design!
Nowhere near enough spokes on those wheels, and the chain tensioner is a silly thing to add, when using proper track forks would have been correct for a single-speed.
Old 02-17-2013, 09:01 PM   #2241
Nihon Newbie
Nihon Newbie's Avatar
Oddometer: 178
Nope, I still mean that I like the simple look of it, but I guess I didn't mean to imply that it was the model of austerity. I ride a 18 spd Tarmac, with external cable routing, regular rim brakes, a bottle cage, tail bag, visible derailleurs, etc...So I just meant "simple" by comparison to the vast majority of road bikes, like my own, which is my main area of experience.
That little basic tensioner seemed, to me, an elegant solution to accommodating various cog sizes without altering wheelbase too much, or complicating wheel swaps too much. The lack of decals gives the bike a stealth look to it, and the internal cable routing maintains the clean lines of the frame. So..."simple," as opposed to "simplest."
I'll admit the chunky fork looks a little overkill.
Nihon Newbie is offline   Reply With Quote
Old 02-17-2013, 11:21 PM   #2242
Andrew
Optimus Primer
Andrew's Avatar
Oddometer: 15,826
See ya in SLO, or come to Parkfield for lunch next time
Old 02-18-2013, 05:53 AM   #2243
DriveShaft
Oddometer: 4,493
If you're going offroad, then yes, 24 spokes is pretty sparse. But if it's just a road cruiser, it's not a big deal.
maybe I need an education here, bcs I'm confused. If you liked that particular frame, and wanted to singulate it, what option do you have that avoids the tensioner? It's got dropouts, period. The frame is distinct, no doubt.
DriveShaft is offline   Reply With Quote
Old 02-18-2013, 07:02 AM   #2244
ducnut
Oddometer: 3,320
Those are vertical dropouts; not horizontal. With no eccentric BB, what do you propose?
You do realize that's a MTB frameset, right?
I think it's a totally cool bike. I don't see why people feel the need to criticize what others are building.
'96 Ducati 900SS
Old 02-18-2013, 07:16 AM   #2245
DriveShaft
Oddometer: 4,493
+1...exactly my thoughts.
Again...I don't get why people are bent over the singulator. I've seen people try to fabricate other kinds of fixes like converting the dropouts to horizontal w/ bolt-ons...but those end up looking even sillier, and are less functional. The singlulator is absolutely the definition of simplicity and elegance here, giving adequate chain wrap, and versatility when it comes to swapping out the wheel, or changing up the # of teeth.
DriveShaft screwed with this post 02-18-2013 at 07:22 AM
Old 02-18-2013, 07:55 AM   #2246
PaulS
Österreicher
PaulS's Avatar
Oddometer: 970
the initial purpose was to use it as a commuter bike and I think it turned out pretty good. It should be functional, solid and simple -- which it is. I think the singulator is the only option for vertical dropout besides having an eccentric BB.
The plan is that I eventually put on a 10 speed and will post a picture for the chain tensioner haters...
In addition, this is MY project and I did post it here to contribute to the "Show me your bicycle" thread.
BTW, did I mention that it rides really nice...
PaulS is offline   Reply With Quote
Old 02-18-2013, 08:33 AM   #2247
Andrew
Optimus Primer
Andrew's Avatar
Oddometer: 15,826
My bad, you're right - the tensioner gets the job done when there are vertical dropouts and no eccentric bottom bracket. Another option might have been a Phil or White Industries eccentric axle, to get enough adjustability for proper chain tension. Or one could go all Ricky-hacky and file some flats on the axle, to gain some room for adjustment, or even further - shorten the axles and just let the quick-release bolt slide around in the dropout.
Sheldon laid out the basic options pretty well:
http://www.sheldonbrown.com/singlespeed.html
Old 02-18-2013, 09:49 AM   #2248
Oznerol
The Happy Machine
Oznerol's Avatar
Oddometer: 1,016
- Eccentric hub (though I'm not sure how well that'd play with the disc brakes, and it'd be a much more expensive and only marginally more elegant solution than the tensioner).
- Setting chain length very precisely, possibly using half-link.
(I'm not actually disagreeing with you, just listing options without regard to actual practicality.)
To the OP of the bike in question: One suggestion I've heard that makes a lot of sense is to position the tensioner so that its sprocket is on the outside of the chain, pushing up, rather than inside pushing down, as you currently have it. That way the tensioner causes the chain to engage with more rather than fewer teeth on the rear sprocket, extending sprocket life.
Oznerol screwed with this post 02-18-2013 at 11:40 AM
Oznerol is offline   Reply With Quote
Old 02-18-2013, 11:11 AM   #2249
DriveShaft
Oddometer: 4,493
Eccentric hub...news to me! Sometimes it pays to assume I'm clueless.
I'd never get one though.
Old 02-18-2013, 11:50 AM   #2250
PaulS
Österreicher
PaulS's Avatar
Oddometer: 970
In fact, the tensioner in the pic made too much noise and I changed it to one that pushes the chain up.
Here is a pic of a eccentric BB
Thread Tools
Times are GMT -7.   It's 05:29 AM.
