Go Back   ADVrider > Fluff > Shiny Things
Thread Tools Rating: Thread Rating: 319 votes, 5.00 average. Display Modes
Old 07-22-2013, 05:07 PM   #2986
thechickencow
Oddometer: 768
My family has 7 if that counts.
'03 ktm 640a
thechickencow is offline   Reply With Quote
Old 07-23-2013, 09:35 AM   #2987
Lewy
Minus the LC8
Lewy's Avatar
Oddometer: 1,969
Originally Posted by Rider_WV View Post
someone say #bikesonafence
IMG_2010 by Rider_wv, on Flickr
There is alway time for #bikesonafence even at 1.45am on the way home from work
Lewy is offline   Reply With Quote
Old 07-23-2013, 10:13 AM   #2988
Andrew
Optimus Primer
Andrew's Avatar
Oddometer: 15,962
Originally Posted by Ricardo Kuhn View Post
Because that will be much to easy of a challenge..
Actually far more work since you need to protect half the frame, take the pedals off, to much work, plus this thing is heavy so moving it around on the roof is kind of a pain..
Your tandem has oval tubing, so I guess that rules out using S&S couplers. I am worried about your rear wheel, so close to the pavement... one day you'll go back there and find a potatoe chip.
Splitting lanes, and splitting hairs.
Andrew is offline   Reply With Quote
Old 07-23-2013, 10:46 AM   #2989
Ricardo Kuhn
a.k.a. Mr Rico Suave
Ricardo Kuhn's Avatar
Oddometer: 12,507
You are right just for added safety I will remove the rear wheel just in case...
Wanted: worn, ugly, cheap motorcycle cover for a big GS 1200
Ricardo Kuhn is offline   Reply With Quote
Old 07-23-2013, 05:26 PM   #2990
trailer Rails
trailer Rails's Avatar
Oddometer: 4,910
Originally Posted by Gummee! View Post
S'what the scale sez...
No photochop. I've seen (and lifted) a similar bike
M
I don't doubt it is light but with the parts I see hanging off of it I see a 13-14 pound bike. A 13 pound road bike is extremely light. A digital scale is easy to fudge. Just calibrate the scale with a small amount of weight on it.
trailer Rails is offline   Reply With Quote
Old 07-23-2013, 06:59 PM   #2991
Gummee!
That's MR. Toothless
Gummee!'s Avatar
Oddometer: 28,828
There's at least two of em like that running around. One's at Fairwheel the other's at Freshbikes. Both are freaky light. I've picked up the one at Freshbikes.
I'm tickled with my 15.5# Giant TCR. Lighter than I 'need' based on my ability level.
M
I'm a cyclist that rides motos, not a moto rider that rides bicycles.
Gummee! is online now   Reply With Quote
Old 07-24-2013, 07:30 AM   #2992
HOT DAMN!
HOT DAMN!'s Avatar
Oddometer: 7,633
Bike Mechanics Wanted.
Hey guys, not a professional, but know my way around bikes for the most part, I have an issue that has me stumped and need some help.
I adjusted my rear derailleur last evening, high and low limits set perfect, fine tuned gear changes on stand with cable adjuster, shifts absolutely perfect with the exception of fourth cog to the fifth cog which results in a dead shift on the rapid fire. Click, derailleur has partial movement but not enough for a gear change and demands yet another click of the rapid fire. I've tried adjusting numerous times last night to no avail, I cannot loose the dead shift.
Any ideas gentlemen?
Shimano Alivio shifters and Deore derailleur, both clean of debris and lightly oiled with A.T.B.
Once in a while you get shown the light in the strangest of places if you look at it right
HOT DAMN! is offline   Reply With Quote
Old 07-24-2013, 07:37 AM   #2993
Ridge
Sinister Kid
Ridge's Avatar
Oddometer: 1,962
Can you see the cable physically moving with the click of the shifter?
Ridge is offline   Reply With Quote
Old 07-24-2013, 10:27 AM   #2994
HOT DAMN!
HOT DAMN!'s Avatar
Oddometer: 7,633
Yes, it moves fractionally Ridge, not enough to upset the chain or the cogs. Just an uneventful click on the shifter, click it again and it shifts up to the next cog.
Old 07-24-2013, 12:06 PM   #2995
Ridge
Sinister Kid
Ridge's Avatar
Oddometer: 1,962
My first hunch is a worn index in the shifter. If those are the most commonly used gears in the range, it's possible that the indexes have worn so much that shifting between them is negligible. IOW, shifting between those gears does not generate enough tension in the cable to actuate the derailleur.
Here's the Shimano Technical docs if it's the same shifter I'm thinking of.
http://www.shimano.com/publish/conte..._mountain.html
Old 07-24-2013, 01:00 PM   #2996
HOT DAMN!
HOT DAMN!'s Avatar
Oddometer: 7,633
That is the exact same one Ridge, and yes it is a very common spot of gear changes for me so your analysis makes all the sense in the world. Thanks buddy, a new shifter it is.
Old 07-24-2013, 01:05 PM   #2997
Gummee!
Gummee!'s Avatar
Oddometer: 28,828
Before you do that, make sure your derailleur hanger isn't bent. I've seen em ever so slightly off and it really messes things up
M
Old 07-24-2013, 01:08 PM   #2998
Ridge
Sinister Kid
Ridge's Avatar
Oddometer: 1,962
M
Agreed. Sometimes the most obvious answers are also the most elusive...
Old 07-24-2013, 01:08 PM   #2999
83XLX
83XLX's Avatar
Oddometer: 478
83XLX is online now   Reply With Quote
Old 07-24-2013, 01:46 PM   #3000
Ridge
Sinister Kid
Ridge's Avatar
Oddometer: 1,962
I bet you can't wheelie that... oh wait, it already is... sort of.
Thread Tools
Times are GMT -7.   It's 08:30 PM.
