Go Back   ADVrider > Fluff > Shiny Things
Thread Tools Rating: Thread Rating: 317 votes, 5.00 average. Display Modes
Old 07-28-2013, 10:07 PM   #3046
fz6kd7
Oddometer: 797
Cat0020
Could you post a pic of the back of the seat
Of your bent and make and model
I think that might fit my actionbent
fz6kd7 is offline   Reply With Quote
Old 07-29-2013, 04:48 AM   #3047
Cat0020
El cheapo
Cat0020's Avatar
Oddometer: 5,653
Originally Posted by fz6kd7 View Post
Cat0020
I do have an extra seat.. if you need one.
Mankind is doomed & Physics do not lie
Chances favor the prepared mind.
Cat0020 is offline   Reply With Quote
Old 07-30-2013, 12:06 AM   #3048
fz6kd7
Oddometer: 797
Thanks but from that angle neither back or bottom would work
Nice collection you have, i only have a bent and df
Thanks again
Old 07-30-2013, 05:26 PM   #3049
Gillmartin
Desultory Dilettante
Gillmartin's Avatar
Oddometer: 1,639
Question Why can't I find these?
Howdy all,
I know, this is a photo thread, but...
So I had my bike on the back of my car and got rear ended. The frame looks straight, but the wheels are toast. The problem is I'm having trouble finding a disc-brake compatible road wheelset. The bike is a Specialized Tricross. Need a 700c, 16-18mm internal width, and the rear needs to work with a 10sp Shimano cassette. I've found an Easton EA90 set at Jenson, but it's almost $900 for the set. I know, you get what you pay for...
Yes, I've tried directly from Specialized, but no luck. The LBS was also no help, strangely enough.
Any help, suggestions, or donations, greatly accepted!
edit: Rats, just realized the aforementioned EA90 only works with a 9-speed cassette.
Gillmartin screwed with this post 07-30-2013 at 05:31 PM Reason: No reason, I just like doin' things like that...
Gillmartin is offline   Reply With Quote
Old 07-30-2013, 05:39 PM   #3050
Cat0020
El cheapo
Cat0020's Avatar
Oddometer: 5,653
Cool2
700c disc wheels on eBAy
In lower to higher price order.
Old 07-30-2013, 05:49 PM   #3051
Dranrab Luap
E-Tarded
Dranrab Luap's Avatar
Oddometer: 32,058
Well, I couldn't help myself.
An as new Burley duet Tandem for $500. Tomorrow I will begin the process of modding it. It will get platform pedals front and back. Laurie likes cruiser ergos, so I'll bolt on some cruiser bars and a big goofy looking cruiser seat. The front compartment will remain unchanged initially, though I suspect I'll want a different seat. The tires are dry rotted so I'll slip on some 700x32 Bontrager hard case tires that are in the attic. The bike appears barely used. There are still rubber nipples down the center tread of the original tires. The front derailleur needs to be adjusted. After that, it should be good to go.
Dranrab Luap is offline   Reply With Quote
Old 07-30-2013, 06:17 PM   #3052
ducnut
Oddometer: 3,321
Sounds like the stoker won't be doing much stoking.
'09 Triumph Tiger1050
'96 Ducati 900SS
'02 Suzuki SV650S (hers)
ducnut is offline   Reply With Quote
Old 07-30-2013, 06:24 PM   #3053
Dranrab Luap
E-Tarded
Oddometer: 32,058
Nope. Just an inexpensive and different way of having fun and getting in a little exercise. We rented a cruiser tandem in the Keys and had a blast. These bikes retailed for about $1800 ten years ago. It was a steal!
Old 07-30-2013, 06:56 PM   #3054
Gillmartin
Gillmartin's Avatar
Oddometer: 1,639
Doh, hadn't even thought of eBay, thanks!
Old 07-30-2013, 08:56 PM   #3055
El Guero
V4 Whore
El Guero's Avatar
Oddometer: 9,727
There's these too
http://www.treefortbikes.com/#navbar...22387209___113
http://www.treefortbikes.com/#navbar...22387208___113
El Guero is offline   Reply With Quote
Old 07-31-2013, 03:02 AM   #3056
aposaric
Garden mechanic ;-)
aposaric's Avatar
Oddometer: 270
Howdy all,
The cheapest way is to get new rims, and take your bent wheels to the wheel builder and let him switch out your broken parts. I am not sure what the pricing for building wheels is at you region, but it is somewhere between 10 and 50 $ per wheel, a lot cheaper and the quality is much higher than a factory built wheel ;-)
aposaric is offline   Reply With Quote
Old 07-31-2013, 04:38 AM   #3057
trailer Rails
trailer Rails's Avatar
Oddometer: 4,894
Howdy all,
#1) the other drivers insurance should pay for any damage, have the frame checked for aglinment by a bike shop. There may be other damage you did not see right away like bent cranks or chainrings.
#2) 8,9 and 10 speed cassettes all fit on the same free hub bodys.
#3) I am a fan of Stan's wheels: http://www.notubes.com/Alpha-340-Dis...-P1068C58.aspx They are relatively light and inexpensive.
#4) If you just want to rebuild, I would buy a Stan's 29" Crest rim and rebuild with that, it will be a little wider than stock but it will work just fine. Or the iron cross rims, they are 1mm narrower.
trailer Rails is offline   Reply With Quote
Old 07-31-2013, 05:00 AM   #3058
Cat0020
El cheapo
Cat0020's Avatar
Oddometer: 5,653
$650 (without tires) for a set of wheels is more than his bike's worth.
Old 07-31-2013, 05:04 AM   #3059
Gummee!
That's MR. Toothless
Gummee!'s Avatar
Oddometer: 28,821
Howdy all,
Depending on your rear spacing, any 29er wheelset will work.
M
I'm a cyclist that rides motos, not a moto rider that rides bicycles.
Gummee! is online now   Reply With Quote
Old 07-31-2013, 05:07 AM   #3060
Gummee!
Gummee!'s Avatar
Oddometer: 28,821
Depends on who is building these wheels. I've seen some artistes and I've seen some hacks. I'm in the middle closer towards the artiste end but I'm no expert. When I'm on my own time, I work for pizza and beer.
If the wheelset in question is the stock wheelset, now's the time to upgrade. Nicer hubs, lighter rims, etc
M
Thread Tools
Times are GMT -7.   It's 06:50 PM.
