Thread Tools Rating: Thread Rating: 267 votes, 5.00 average. Display Modes
Old 08-04-2013, 05:31 PM   #3106
Ricardo Kuhn
a.k.a. Mr Rico Suave
Ricardo Kuhn's Avatar
Oddometer: 12,333
New bike for Kiersten, I need to make a bike rack for the new GS one of this days..
Wanted: worn, ugly, cheap motorcycle cover for a big GS 1200
Ricardo Kuhn is offline   Reply With Quote
Old 08-04-2013, 09:41 PM   #3107
Gillmartin
Desultory Dilettante
Gillmartin's Avatar
Oddometer: 1,638
Looks like Specialized is getting in on the FatBike craze:
Specialized Fatboy article
A little surprised it took them this long...
Gillmartin is offline   Reply With Quote
Old 08-04-2013, 09:56 PM   #3108
Geek
oot & aboot
Geek's Avatar
Oddometer: 31,285
From today's 11 miles of single track (and 89 million feet of vertical )
...above Fort Collins, Co
My Yeti SB95c and Dirtbro's Yet SB66.
What a hoot!
Old 08-04-2013, 10:25 PM   #3109
Andrew
Optimus Primer
Andrew's Avatar
Oddometer: 15,513
Originally Posted by Old fart View Post
Beautiful - did you rescue it?
Splitting lanes, and splitting hairs.
Andrew is offline   Reply With Quote
Old 08-04-2013, 11:14 PM   #3110
Old fart
Keen AG100 rider
Old fart's Avatar
Oddometer: 740
Yip, going to free the crank up and go looking for tyres I've been called a big girl before, thought I'd ride an appropriate bike.
Old fart screwed with this post 08-04-2013 at 11:16 PM Reason: grow constructivist policies
Old fart is offline   Reply With Quote
Old 08-05-2013, 12:12 AM   #3111
DriveShaft
Oddometer: 4,410
quick question
what bottom bracket tool do I need to get for this?
18-spline
roughly 24mm
DriveShaft is offline   Reply With Quote
Old 08-05-2013, 03:03 AM   #3112
LoJack
LoJack's Avatar
Oddometer: 1,571
For a square taper bb? That's so normal, I don't even know what model the puller would be. Good rule of thumb, take a washer and your crank arm fixing bolt and fix the tool to the bb cup so it doesn't slip off.
What's the frame? Smooth ti welds to me say '80s Merlin or maybe Spectrum?
LoJack is offline   Reply With Quote
Old 08-05-2013, 03:34 AM   #3113
Gillmartin
Gillmartin's Avatar
Oddometer: 1,638
18-spline
roughly 24mm
18 spline = Phil Wood? Try: http://www.cambriabike.com/shopexd.a...m=041604000100
Old 08-05-2013, 03:55 AM   #3114
LoJack
LoJack's Avatar
Oddometer: 1,571
Originally Posted by Gillmartin View Post
Didn't think of that, but I've never seen a black Phil cup (not saying it's never been done, though).
Old 08-05-2013, 06:31 AM   #3115
DriveShaft
Oddometer: 4,410
That's probably on target. It wouldn't fit my shimano tool, so I knew it was oddball. The guy's got Ti everything on this bike. I'm guessing he's got a Phil Wood Ti spindle.
It's a Spectrum for sure. The most god-awfully-neglected Spectrum I've ever seen. Well...the *only* spectrum I've ever seen, but likely the most neglected one TK's ever spec'd. Going over it cog by cog to clean it up. re-pack the grease, etc.
I don't live all that far from TK's old shop. I should see if I can get in touch with him and check out the history of this thing.
Old 08-05-2013, 06:44 AM   #3116
Gummee!
That's MR. Toothless
Gummee!'s Avatar
Oddometer: 28,357
That's no Phil BB. That's a standard Shimano BB. Get the Shimano BB tool from Park and go to town.
Turn towards the front of the bike (on both sides) to get it off.
Once you get it off, you should be able to read the #s on the shell. Should say something like '68mm x 122.5mm' or similar. Your choices are 68mm or 73mm then spindle length. If the BB doesn't say, you'll have to measure end-to-end to find out. It'll be 118mm, 122.5mm, or 127.5 if that came off a triple.
M
I'm a cyclist that rides motos, not a moto rider that rides bicycles.
Gummee! is offline   Reply With Quote
Old 08-05-2013, 07:04 AM   #3117
Rider_WV
Rider_WV's Avatar
Oddometer: 2,297
not quite a bike on a fence but a guardrail is close
IMG_2030 by Rider_wv, on Flickr
Rider_WV is offline   Reply With Quote
Old 08-05-2013, 07:05 AM   #3118
DriveShaft
Oddometer: 4,410
M
That's what got me confused. BBT-32, BBT-22, and the old BBT-2 are 20-spline. It's definitely not a 12-spline campy. I started running out of ideas, so I took a pic.
Old 08-05-2013, 10:00 AM   #3119
LoJack
LoJack's Avatar
Oddometer: 1,571
What's the brand and vintage of the parts? That may help.
No drive side fixed cup... don't see that a lot. Did you check Sheldon Brown?
http://www.sheldonbrown.com/harris/t...ombracket.html
Phil Wood is 18 spline (and I counted the number on mine), not much else.
LoJack screwed with this post 08-05-2013 at 10:51 AM
Old 08-05-2013, 11:31 AM   #3120
DriveShaft
Oddometer: 4,410
Sheldon sorta corroborates the theory that it's a blackened phil wood. So would the fact that the drive side cup floats, since that's also characteristic phil inboard bbs.
I'm like 90% sure it's phil. Regardless, I'm getting their extractor, since it is the only 18-spline option I see. Even I have to modify the extractor witha cut-off wheel, I'm pretty sure I'll be able to take it off and get a look-see without having to resort to destructive measures (on the Bb).
Everything was filthy when I started to take it down, with a "frosting" of what I'll assume is some sort of salt compound and old lube over the entire drivetrain...evidence that it sat a good long time in a dank concrete storage area. It wouldn't surprise me if a thorough scrubbing revealed a normal-looking phil bb cup.
Other components are old maybe mid-90's 8-speed dura-ace pretty much throughout, Morati cranks (!). I was casing out the likelihood of me being able to outfit the bike more for hill climbing and touring, and noted it was an RD7402 short-cage in the back, so a bit limiting on the range of take-up offered by the derailleur. I bet it shifts pretty snappy though. RD7402...hasn't been made since '96, according to the references.
DriveShaft screwed with this post 08-05-2013 at 11:44 AM
Thread Tools
Times are GMT -7.   It's 12:56 AM.
