Thread Tools Rating: Thread Rating: 267 votes, 5.00 average. Display Modes
Old 08-20-2013, 07:20 AM   #3331
Plasticjesus
random roadburner
Oddometer: 32
Originally Posted by Off the grid View Post
The bike comes with a double crank. I need to buy shifters and would like to swap to a triple crank in the future, but plan to ride with the double for a bit. Want to know if the triple shifter will work with the double crankset.
I'm thinking the "throw" on the triple shifter might be too "short" to use it for a double crankset. (ie 1-2 on a double shifter has a longer "throw" than the 1-2 on a triple shifter)
buy the triple now if thats the way you wanna go
set it up on the 2-3 throw works better on a double crank
lower end groupos are mostly 3 lh option only even if the bike comes specced double chainring
but triples are kinda out now unless you love big hills
compact size double is better ratios and less complicated than triple
Plasticjesus is offline   Reply With Quote
Old 08-20-2013, 10:56 AM   #3332
YakSpout
Obstacle Allusion
YakSpout's Avatar
Oddometer: 6,000
Ugh. Hed freehub seems to have nearly locked up on the way into work this morning. It'll spin free-ish, but not until it dumps some chain on the chainstay while taking slack out of the rear derailleur.
This goes beyond my 'fiddle with this barrel until the shifts are smooth and I don't hear clicking' level of bike maintenance. Before I mounted the cassette, I saw what I thought was a grease hole in the freehub. Will going to town with WD-40 to wash the old stuff out and hitting it with new grease/oil work?
I've got an email sent off to Hed to ask, but figured you all might have a quicker turn-around.
Dang. This was supposed to be in the Bicycling thread. I'll repost over there.
YakSpout screwed with this post 08-20-2013 at 11:07 AM
YakSpout is offline   Reply With Quote
Old 08-20-2013, 10:58 AM   #3333
YakSpout
Obstacle Allusion
YakSpout's Avatar
Oddometer: 6,000
Triples seem to be going the way of the dodo. That front derailleur is just too fiddly.
A compact with a 28 or 30 tooth cog on the rear cassette will get you just about there unless you're pulling a load or you have to head up major climbs on a regular basis. (>15%)
Old 08-20-2013, 01:04 PM   #3334
DriveShaft
Oddometer: 4,413
A I like my mtb to climblike a goat. 2x does shift nice. But gain ratio trumps trimming if sheer functionality is the measure of your mtb
DriveShaft is offline   Reply With Quote
Old 08-20-2013, 01:21 PM   #3335
YakSpout
Obstacle Allusion
YakSpout's Avatar
Oddometer: 6,000
MTB? Oops. Thought we were talking roadies.
Aren't MTBs heading into 1x11 territory now to get rid of any front der?
Old 08-20-2013, 01:48 PM   #3336
DriveShaft
Oddometer: 4,413
Yep...if you get to ride a lift up to the top of the mtn, 1x11 is a great way to go. Alot less probability of dropping your chain.
Old 08-20-2013, 01:53 PM   #3337
Rider_WV
Rider_WV's Avatar
Oddometer: 2,300
shit i have been running a 1x9 MTB since 2008. 36t front with 11-32 cassette. Simple and plenty of gearing for the hills of WV. a granny ring is useless around here.
Rider_WV is offline   Reply With Quote
Old 08-20-2013, 02:16 PM   #3338
DriveShaft
Oddometer: 4,413
Oops, for me... I bet he *was* talking road, not mtb, since he mentioned sti shifters. Yeah...3x roadies are pretty much getting into loaded touring territory.
Old 08-20-2013, 04:05 PM   #3339
Hay Ewe
Just a Wannabe
Hay Ewe's Avatar
Oddometer: 2,868
My 2012 Felt Team 9 came with 2x10
Changed it to 3x9.
For me it gives a better spread of gears and more speed - which for where and what I ride is good. With my non standard chain ring teeth numbers I still get a close equivlient to a 2x10 but then when we hit the more open trails, road, tracks, I can go up to the big ring and put some gap in them
I also ride with roadies a fair bit
tailor what you have to the kinda of riding you do.
Hay Ewe
Moments before you die, your life will flash before your eyes - make sure the film is worth watching - my Grandad
Don't go gentle into the long final good night from which no man has yet returned.
Moose Antlers need love too.
Hay Ewe is offline   Reply With Quote
Old 08-20-2013, 04:57 PM   #3340
clevishook
stevedore
clevishook's Avatar
Oddometer: 1,613
2x10speed?!? I can only afford ONE speed!!
And my mechanic has no clue what he's doing!
Very cool bike. I'm working on my second single speed project bike, posted my first build earlier on this thread. The second is also a budget bike but an over sized seat post jammed into the seat tube is giving me fits. It just doesn't want to be removed. I'm at the sawzal point trying to get the seat post out as in cutting down the inside of the seat post and try removing it in sections. Wish me luck.
clevishook is offline   Reply With Quote
Old 08-20-2013, 05:21 PM   #3341
DriveShaft
Oddometer: 4,413
Youch... would a star nut fit down there? With a star nut, a long screw, and a few washers, You could fashion a slide puller, and try to hammer that fucker out with something heavy striking the washers.
You could also dremel out three holes in the seat post and stick in a *real* slide puller reverse-jaw tool too.
Apply some serious impact.
I know it's insane, but I really like my singlespeed. :) I've no use for it except for shits n giggles, and getting a good workout in.
DriveShaft screwed with this post 08-20-2013 at 05:28 PM
Old 08-20-2013, 10:23 PM   #3342
Tripped1
Likely Lost.
Tripped1's Avatar
Oddometer: 7,828
Yeah starting to, some of them, however, the special chain and $350 cassettes are a pretty big turn off for me.
As it is I rarely really use the granny ring, and when I do its on the small end of the casset, if I must I can run a 2x9 or even 2.8 and just deal with the front derailer.....its always the rear that gives me issues on my bike anyway.
Originally Posted by RottenScummyTroll View Post
Show folks something with a clutch and carburetor, and it's like teaching a baboon to use a Macbook.
Tripped1 is offline   Reply With Quote
Old 08-21-2013, 07:24 AM   #3343
Attico
Wrong way 'round
Attico's Avatar
Oddometer: 1,866
That is really nice.
Originally Posted by JimVonBaden View Post
Is this bike worth $800? My friend thinks so.
Jim
“If you think adventure is dangerous, try routine; it is lethal.” (Coelho)
Attico is offline   Reply With Quote
Old 08-21-2013, 04:42 PM   #3344
Eugene
Oddometer: 1,138
Question, can you run a double crank with Shimano STI 3x10 shifters or is the "throw" different (shorter, to be precise) with a triple front shifter?
The bike I'm building has a double, but I'd like the option to put a triple on there, wondering if I can get the 3x10 shifters or am I stuck with the 2x10.
Hmmmm.
I don't know about the road world(if you're dealing with road components) but I have a Shimano XT MTB shifter and it has a toggle on the bottom letting you choose between 2 or 3 chain rings. The indexing(throw) is the exact same. Might be worth looking into or do what driveshaft said. I built up a MTB and wasn't sure what I was going to run and wanted options so I went with that shifter. I currently run 1x10(11-34/34); works well for this area. My crank is a triple so I have the option of running 1, 2 or 3 x 10.
And since this is a "show us" thread here's a crappy picture of the shifter not on the bike.
Eugene is offline   Reply With Quote
Old 08-21-2013, 10:09 PM   #3345
zouch
part-time wanderer
zouch's Avatar
Oddometer: 1,666
not sure what language you're referring to, or what you might have read about what they're doing now, but i can assure you that people have been known to pop the seals out of those bearings with an Xacto knife to refresh the grease in them. "maintenance free" doesn't necessarily mean "unmaintainable".
nowadays, i just replace the whole bearing when they become tired (and they do). on the FSA/C hubs, it's simple. on the BBs, not so much... but that's not as common and Phil's nearby, so that simplifies things for me.
cheers!
I think I may have mis-remembered language from their hub products wrt serviceability. Their new bb bearings sport double-labyrinth seals, which would imply maintenance free.
just a guy...
'02 GS Adv
zouch is offline   Reply With Quote
Thread Tools
Times are GMT -7.   It's 01:37 AM.
