06-20-2011, 06:31 PM
#706 | |
I bent my Flounder
Oddometer: 192
06-20-2011, 06:45 PM
#707 |
Oddometer: 282
Thanks. I should mention that I do put my own bikes together, and occasionally make parts. That bash guard is a little bit of a rip-off of a Salsa bash guard that they no longer make but that I had a buddy custom cut for me on a CNC waterjet. The N-Gear chain guide also had to have a piece custom fabricated by me to work on this carbon frame (small flat piece of aluminum stock that I used a mini-mill to cut two grooves in to relocate the metal part of the guide about 3/4" lower than the clamp would go).
This is also a recent build: ![]() That's an OnOne 456 Titanium XL frame with a Fox TALAS fork. It's built in a 1x10 drivetrain same as the Highball but without powermeter cranks and XTR's instead. Similar otherwise, but intended to be a little less race bike and a little more hooligan trail bike. I'm 6'2" and prefer a long cockpit, so you'll generally see a 110mm stem and a Thomson setback seatpost on all my mountain bikes (and an XL frame, of course). Other bikes in the herd...Santa Cruz XC carbon, Santa Cruz Nomad, Santa Cruz V10, Santa Cruz Jackal, (see a trend? I like Santa Cruz bikes!), Guru titanium road bike (custom frame), Guru steel road bike with the same dimension custom frame for the trainer only. I have a problem. All but the Jackal and the V10 see a good bit of love. But one day I'll start leaving the earth more...I keep saying that. :) --Donnie
My blog |
06-21-2011, 05:34 AM
#708 | |
That's MR. Toothless
Oddometer: 25,658
Its PEDAL dammit! ![]() M
There. I've moved back to VA. Can you PLEASE change the weather?! |
06-21-2011, 06:00 AM
#709 |
I bent my Flounder
Oddometer: 192
06-21-2011, 06:04 AM
#710 | ||
Oddometer: 894
Running higher tire pressure is not the solution. Running high tire pressure caused the bike to deflect off of ever little bump and actually slows you down. Low pressure will absorb the bump and allow you to continue. Low pressure will also act as suspension. I weigh 180 lbs dressed and I run 24psi in the front and 27 in the rear on a 29x2.0 tire. I have never gotten a flat after I went tubeless. I used to get pinch flats every couple rides with tubes. I do still carry a pump and a tube for that day, but usually they are used on my ill prepared riding buddies bikes. I don't care what you do, I was just trying to offer some advice. Quote:
I run clipless pedals for the same reason you run flats. Bacause of the roots and logs. I like to be able to loft the bike at the last second in a corner. I like the pop I can get when I am attached. I run flat pedals on all of my other bikes. I really like flat pedals but when riding tight trails there is nothing like being connected. I can understand you not wanting to use them when you are as old as father time and have been riding since the Wright brothers still owned a bike shop. I was trying to offer some advice on tire pressure to help the issue of slipping out on roots. |
06-21-2011, 07:59 AM
#711 |
I bent my Flounder
Oddometer: 192
Besides the usual "Deflection" off of roots, I have never gone down because I lost the front end because of roots. I normally run Kenda Karmas, SB8s or Nevagals at 50 psi in the rear and 45 up front. My point about the roots and using flats instead of clipless is because I have seen several of my riding buddies go down in those technical sections because they didn't get clicked out fast enough.
And yea, I know about having more power, whatever! I get ribbed all the time with my locals about using flats up until they lay there bleeding and my old ass is smoking a fatty! ![]() I tried using clipless several times and just never felt comfortable with them. I just don't like them, don't like the idea I'm stuck to the bike, and I HATE that sound of clicking in and out. But, if I was a leg shaver or rode in non technical areas, well yea! I'd clamp in! But that's not what I do. ![]() As far as tubeless, too much hassle for me. I like the idea of losing a little weight as far as rotating mass goes, but I'm already at 23lbs flat. I'm no rookie! I don't buy store bought bikes. I build em.
06-21-2011, 10:19 AM
#712 | |
Oddometer: 1,917
06-21-2011, 12:37 PM
#713 |
Oddometer: 25,658
Peddle is something you do to southerners when yer trying to make a quick buck.
Buy junk, peddle it to unsuspecting rednecks, make bank. ![]() [Klay]To make a bicycle move, regardless of where you are in the world, you PEDAL it. Spell-check thinks both are OK cause they're both words.[/Klay]M
06-21-2011, 12:48 PM
#714 | |
Oddometer: 25,658
I wanted it so badly, I actually rode road shoes with smooth, stiff bottoms on my clip and strap mtn pedals. Quickly found out that wasn't a good idea, but there wasn't a viable alternative, so I kept at it. Finally got some OnZa HO pedals and like the post above, had to be dynamited out of my pedal on a few rides. Found Speedplay Magnum pedals (now Frogs) and didn't look back. So... if you don't like the 'clicking in and out' sound, get some Frogs. I've found that I can move the bike around BETTER with my feet attached. Need to pull the back wheel up and over something? Do it. Need to skootch your back wheel a few (many?) inches to avoid a rock/root/whatever? Do it. Bunny hops are made simple. Waist high logs? No worries. Get your front wheel on it and heave. (not me, a buddy! I don't have cojones big enough)It takes more than a few times to get comfortable. I've unclipped while going over the bars. I've unclipped while going sideways, backwards, almost upside down, etc. Once the movement is ingrained into your muscle memory, its a non-issue. The learning curve is pretty steep. Shouldn't take too long......but it isn't my bike and it isn't my ride. I'm here to sing the praises of better equipment = more fun but if 'you*' don't listen its no skin off my back. Enjoy your ride your way. I'll enjoy my ride my way.![]() M *generic 'you' not anyone specific
06-21-2011, 12:54 PM
#715 |
Rhymes with Heinz :D
Oddometer: 42,017
My family their SO's and our bikes.
![]() ![]() Posted because I like the picture... |
06-21-2011, 01:46 PM
#716 | |
I just wander.....
Oddometer: 1,287
The last set of "clip-less" I rode were Shimano 858's. Are you able to move your feet more laterally (float, I think they call it) on the new ones. The thing I don't like about them is I couldn't move my feet around. Trials bikes will make you HATE "clip-less" petals.
2007 Factory Husaberg 380FE 2007 Montesa 4rt 1984 Husqvarna 500AE |
06-21-2011, 01:58 PM
#717 | |
Oddometer: 282
I'm personally a huge Eggbeater fan. Love those pedals. --Donnie
My blog |
06-21-2011, 02:02 PM
#718 | |
I just wander.....
Oddometer: 1,287
06-21-2011, 04:00 PM
#719 |
I bent my Flounder
Oddometer: 192
Petals.
06-21-2011, 04:07 PM
#720 | |
ADV Risk Manager
Oddometer: 1,030
Regards, MillCreek Snohomish County, Washington USA 2012 Suzuki DL650A as the current bike Whole bunch of bikes in the past |
| Thread Tools | |
