Thread Tools Rating: Thread Rating: 42 votes, 4.90 average. Display Modes
Old 03-16-2009, 11:31 AM   #1
Aurelius OP
Aurelius's Avatar
Oddometer: 22,589
Economics of reloading ammo(e)
The topic of reloading has surfaced in several gun threads, so I thought it might be of interest to see how the economics pencil out. I did these calculations some 30 years ago when I got involved in reloading, and the savings were substantial even then. Below are two cartridges I shoot quite often, broken down by component. The .223 once-fired cases I buy locally, as well as primers and powder. Prices for a box of cartridges, bullets, and .44 Magnum brass were all taken from MidwayUSA's website. The cost per case is based on a conservative estimate of 10 reloads before the cases show signs of splitting at the neck. I'm told that annealing the case necks will increase their lifespan, but I haven't attempted it.
.223 Remington
Cases: 1 cent per case.
Bullet: (55 grain bulk bullets) = 10 cents.
Primers: ($27/1000) = 3 cents.
Powder: (25 gr. of Win. 748) 8 cents.
Total per: cartridge = 22 cents
1 Box of 20 .223 Winchester = $26/40 = 65 cents a piece.
Total savings for 1000 rounds (43 cents X 1000) = $430.00
.44 Magnum
Cases: 2 cents per case.
Bullet (240 grain jacketed bulk bullets) = 19 cents.
Primers ($27/1000) = 3 cents.
Powder (9 gr. of Bulleye) 1.5 cents.
Total per cartridge = 25.5 cents
1 box of .44 Magnum cartridges = $18/20 = 90 cents a piece.
Total savings for 1000 rounds (64.5 cents X 1000) = $645.00*
* Note that I prefer reduced loads of 9 grains of Bullseye, rather than duplicating factory loads. This not only saves more money in the long run, but makes my Super Blackhawk tame enough to fire many rounds in rapid succession without the punishing recoil of factory loads.
If anyone else has run the numbers and would like to share the results, by all means do.
Dizave opined: Why do you care where the premises come from? They are above reproach. For all intents and purposes, you can just make up all your premises, since they can't be proven anyway. That's why we need premises.
Aurelius screwed with this post 03-16-2009 at 01:02 PM
Aurelius is offline   Reply With Quote
Old 03-16-2009, 12:27 PM   #2
UPSam
All jacked up on Dew
UPSam's Avatar
Oddometer: 16,370
Your loaded round prices are kind of inflated.
I always used 8-10 gr unique in a reduced 44 mag load with a cast bullet. Bullets used to sell for $10-12/500. Cast bullet handgun loads are where the real money is. The cases last forever. I would avoid bulleye in 44mag. I do use powders like bullseye in my 38/357 loads.
In normal times, rifles is not really worth reloading for loadings that are available as surplus. I don't think I have ever paid more than 20c for 223 ball ammo. You save a bunch if you are trying to replicate Fed. Gold medal loads with sierra bullets or something. I played a little with 80ga sierra in 223. I don't think you could buy that loading. I bought a bunch of black hills 223 reloads with the 68gr sierra that WERE very reasonable and accurate.
Shotgun is not worth loading for standard trap, skeet, sporting loads. Hasn't been for years. Even if your club is buying major qualities of components. Remington gun club(which are excellent shells available in tons of shot and powder loads) were as little as $3 in the last 5 years.
"There was a lot of talk last year about how Barack Obama would be a “transformational” president — but true transformation, it turns out, requires a lot more than electing one telegenic leader." -Paul Krugman 8/30/09
UPSam is offline   Reply With Quote
Old 03-16-2009, 12:42 PM   #3
Aurelius OP
Aurelius's Avatar
Oddometer: 22,589
I pulled these prices off MidwayUSA's website. Their prices are hard to beat, but there are considerable differences in the prices for a box of factory loaded ammo. For purposes of illustration, I selected a common brand like Winchester.
My bullet casting equipment just arrived last week, and I don't yet have any cost breakdown per bullet. If you use wheel weights, you can make them for next to nothing.
I've used it in everything from .22 Hornet to 303 Enfield with good results. In NRA Hunter's Pistol and IHMSA Field Pistol classes, they recommend 8.5 grains of Bullseye with a 240 grain bullet.
I've been looking for .223 ball ammo at local gun shows, but no one seems to have any. It would certainly save me a lot of trouble full length resizing all those cases for my AR-15.
Old 03-16-2009, 12:49 PM   #4
Sniper X
De Oppresso Liber
Sniper X's Avatar
Oddometer: 33,343
Shoot, the only .223 ammo I have ever seen that expensive for loaded factory ammo was Federal Gold Mdeal Match! I get 55gr relaods for like $239.00 per 1000.
" The people who cast the votes decide nothing. The people who count the votes decide everything."
Straight Out Da Trailah!
Sniper X is offline   Reply With Quote
Old 03-16-2009, 01:08 PM   #5
Aurelius OP
Aurelius's Avatar
Oddometer: 22,589
This looks like ordinary Winchester ammo, which MidwayUSA lists for $25.99 per box of 40: http://www.midwayusa.com/browse/Brow...4&brandId=1390
The premium Federal Gold Medal ammo lists on their website for $30.99 for a box of 20!
Old 03-16-2009, 01:14 PM   #6
UPSam
UPSam's Avatar
Oddometer: 16,370
The current ammo prices are just nuts. Mail order prices on factory ammo are never very good.
I always bought cast bullets from gun show venders. Didn't seem worth the cost of equiptment and hastle to cast my own. I gave my black powder molds and pot away.
I don't like bullseye in large capacity cases because you can't see the level that easy when running a progressive loader. I don't seem to have my load books and notes anymore (I moved) but I am pretty sure a duplex load of unique over flows a 44 mag case or at least is right to the top. You do see a lot of blown up revolvers with bullseye. I am sure they were throwing duplex or worse loads. I always got better accuracy with unique but it is dirty as hell.
Old 03-16-2009, 01:28 PM   #7
Aurelius OP
Aurelius's Avatar
Oddometer: 22,589
I never bought any factory ammo for the .223. What was it commonly selling for prior to the recent price hikes?
The problem for me is that there's only one vendor at the local shows that sells cast bullets, and they specifically told me to keep velocities below 800 fps, because the lead alloy they use is too soft for anything else. That means I can't use them at the velocities I need for NRA silhouette matches.
That can be a problem. I always check all my cases with a bore light prior to seating the bullets, but that won't work if you're using a progressive press.
Old 03-16-2009, 01:54 PM   #8
HardCase
winter is coming
HardCase's Avatar
Oddometer: 10,622
For years you could get newly manufactured "military-style" stuff, 55gr FMJBT bullet, from Federal, PMC, and sometimes Winchester for around $5 for a box of 20. In the past two years that went up (at least around here) to $8-10 depending on make. Case lots of 1000 rounds of PMC were recently selling for between $375 and $399, but those supplies have dried up and now there is none available locally.
Μολών λαβέ
Hard cases make bad law.
HardCase is online now   Reply With Quote
Old 03-16-2009, 02:00 PM   #9
nevermind
sLOW Rider
nevermind's Avatar
Oddometer: 3,026
Where? I'd love to get some decent 55gr .223 for that price!
nevermind is offline   Reply With Quote
Old 03-16-2009, 02:08 PM   #10
Misery Goat
Positating the negative
Misery Goat's Avatar
Oddometer: 75,188
.40 SW winchester 165 gr are $30(incl tx)/100ct.
i don't think i can make an economic argument to buy a dillon xl 650.
"So what you gonna do when the novelty is gone.."-- Joy Division
Same as it ever was
My Wanderlust
Misery Goat is offline   Reply With Quote
Old 03-16-2009, 02:27 PM   #11
UPSam
UPSam's Avatar
Oddometer: 16,370
Is it possible the don't know what they are selling? Swagged lead bullets are soft as hell. I have never heard of anyone casting a bullet that can't go beyond 800 fps BUT you will see more leading the faster it goes. I was shooting 8-10 gr of Unique and 7 gr is almost 900 fps. Really no leading.
Casting might be a good idea if you are shooting high velocity competion. Long range. You could cast for rifle also. Sell your 223 and buy a 45-70 or some other buffalo gun.
Most surplus for 5.56 is good stuff. I used to buy that for -15-20c a round by the case. USA and the other 55gr cheap loads were about 20c too. Black Hills did have really good reloads with quality bullets for not much more. 500 rd cases in 50 rd boxes. I couldn't load much better on a single stage press
Old 03-16-2009, 03:08 PM   #12
Sniper X
De Oppresso Liber
Sniper X's Avatar
Oddometer: 33,343
I bought it twice at those prices when everybody had a ton but now....forget it! Glad I have a coul=ple K around....
Old 03-16-2009, 03:16 PM   #13
HardCase
winter is coming
HardCase's Avatar
Oddometer: 10,622
I just loaded 100 rounds of 308 yesterday. Here's the breakdown:
Brass.....I have tons of it, so it was basically free.
Bullet.....Sierra 168 Matchkings....box of 100 was $29, so .29.
Primers.....just shy of $3 per 100, so .03
Powder.....748, 45 grains per round, $22 per pound, roughly 150 rounds per pound, so .15 per round.
Total cost per round......47 cents.
New factory 308, when you can find it which is a problem right now, is minimum $16 per box, and ranges up to around $30, so a buck per shot is a good average. Reloading cuts that cost in half.
I find that with some of the more oddball rounds like the belted magnums, or a handgun round like the 500 S&W, the savings can be considerably more than that.
Μολών λαβέ
Old 03-16-2009, 03:30 PM   #14
Boston12GS
Boston12GS's Avatar
Oddometer: 3,886
When I used to shoot competitively, 10 years ago, my 45 ACP rounds could be reloaded for about 5 cents a round. At the time I was shooting about 10,000 rounds a year. My Dillon 650 paid for itself in short order.
Boston12GS is offline   Reply With Quote
Old 03-16-2009, 03:31 PM   #15
Sniper X
De Oppresso Liber
Sniper X's Avatar
Oddometer: 33,343
PM me your address and Ill send you a box of Sierra Match Kings in 168gr BTHP free if you pay shipping....I have a box I am not going to use.
Thread Tools
Times are GMT -7.   It's 08:40 AM.
