Old 03-22-2009, 02:33 PM   #1
2manyrides OP
shifty charactor
2manyrides's Avatar
Oddometer: 1,643
Steel tanks and storage
I'm sure this has been discussed here some where. Help me out.
After draning and drying, I had stored multipal steel tanks with their gas caps on and closed petcocks. Years later finding rust.
I know I could use muratic acid, and I found a link to this stuff;
(evapo-rust) in another thread.
http://www.orisonmarketing.com./corr...vapo-rust.html
Don't really want to have to coat them inside.
I'd just like to store these extra tanks with out them rusting up.
I have 1984 paint job on a tank still new and unused that's been stored since then in protective foam and shrink wrap. I worry about what I'll find if I open it up.
Any Ideas will help me decide which way to turn.
22manyrides
too many...
I have completely lost count
and here's my channel...
http://www.youtube.com/user/2manyrides?feature=mhsn#p/u
2manyrides is online now   Reply With Quote
Old 03-22-2009, 02:47 PM   #2
marksbonneville
marksbonneville's Avatar
Oddometer: 966
I give mine a coat of oil (atf or marvel) inside before I store them, plus I leave the cap and petcocks off and only cover them with a rag. I just pulled a tank out that was stored 15 years with no problems. I do not like coatings unless I have no other choice, I use vinegar to remove rust and coat it with oil. But I live in a dry climate so that helps.
marksbonneville is offline   Reply With Quote
Old 03-22-2009, 02:49 PM   #3
rufusswan
rufusswan's Avatar
Oddometer: 962
To store a raw steel tank and prevent it rusting you have to remove all water and air which rust feeds on.
Keep the tanks full of something. Kerosene, antifreeze, old motor oil? Check them on occasion and top up. Even if you do get either surface rust or sludge from your fill liquid ... both are easy to clean out when you want to use them.
1971 BMW R75/5 Toaster LWB
1974 Honda CL200
http://zenhuckfinn.wordpress.com/
rufusswan is offline   Reply With Quote
Old 03-22-2009, 05:21 PM   #4
2manyrides OP
shifty charactor
2manyrides's Avatar
Oddometer: 1,643
markbooneville,
Can you elaborate on the vinegar method?
Just a coating of oil has worked well for you then...
I Have not had, nor coated a tank yet and don't want to start. But from what I gather, once it's been infected with rust, it will keep coming back unless as rufusswan says, I keep it full.
22manyrides
too many...
Old 03-22-2009, 06:08 PM   #5
marksbonneville
Oddometer: 966
I have found that one of the nicest rust removers is apple cider vinegar. I soak rusted parts in it for a day or two and it removes most all of it. I had a triumph tank with some scale rust so I cleaned it with soap and water, dried it, capped the petcocks and filled it to the brim with vinegar, a couple days later all rust was gone. Then I cleaned it again put it in the wife's oven to dry and oiled the inside with auto tranny fluid, good as new.
I have been using vinegar for years, its cheap, safe and works as well as any expensive industrial stuff. I keep a 5 gallon bucket of the stuff in the garage.
When I'm done with the old stuff I spray it on my driveway to give it a nice redish brown tint.
Old 03-22-2009, 06:14 PM   #6
marksbonneville
Oddometer: 966
FYI on coatings
I had a tank here last year that someone used the coating product "creme" in it. What a mess, so I tossed in a gallon of acetone and within a few days ALL the coating was gone. I then did the vinegar soak and everything was fine. I never understood why they coated this particular tank, but I would not feel comfortable with the creme product.
Old 03-22-2009, 06:23 PM   #7
JeffS77
cheap bastard
JeffS77's Avatar
Oddometer: 3,372
i have used navel jelly and a bunch of bolts/screws with good success to get out really bad rust...as for storage it seems a light coat of oil would work well
JeffS77 is offline   Reply With Quote
Old 03-22-2009, 06:26 PM   #8
zookster
Chupacabra
zookster's Avatar
Oddometer: 738
+1 on the vinegar method. I've used it for years on tanks, metal brake lines, small metal parts etc. I use white distilled vinegar, so apparently the type of vinegar doesn't matter much. I too keep about 5 gallons on hand. It can be re-used several times before it gets too contaminated.
We Are A Circle Within A Circle, With No Beginning, And Never Ending
zookster is online now   Reply With Quote
Old 03-23-2009, 07:38 AM   #9
2manyrides OP
shifty charactor
2manyrides's Avatar
Oddometer: 1,643
Looks like I need to source some vinegar.
Right now I have 2 XS650 tanks, and a BSA tank to clean up.
These are all just mildly rusted so a clean up and a protective film is what I'm looking for. Thanks for the responses!
22manyrides
too many...
Old 03-25-2009, 10:04 AM   #10
2manyrides OP
shifty charactor
2manyrides's Avatar
Oddometer: 1,643
it works good
Hey marksbonnieville,
I got 3 gallons of white vinegar at smart+final for about 12 bucks.
Filled it to the brim and closed the cap.
Came back the next day and opened her up. Could see floating rust on the surface, but not a pristine clean look on the steel.
Touched it with a tooth brush on the center hump and all suface rust "wipes" off. There's no scrubbing needed, it just needs to be touched.
So now I need to get some sort of medium to shake up in it. Then do the rinse+dry.
Thanks a million times!
22manyrides
too many...
Old 03-25-2009, 12:16 PM   #11
marksbonneville
Oddometer: 966
I'm glad it worked out for you. I usually get whats left over removed with a good hot water rinse, then let it sit in the sunlight. You could always drop a 3 foot small chain in the tank and swish it around with water.
Mark
Old 03-25-2009, 04:49 PM   #12
Rich Dubbya
Pimpadimpolis
Rich Dubbya's Avatar
Oddometer: 244
What ever happened to topping off your tank and adding some Sta-bil ? Or long term just keeping it empty and no moisture ? Hang a clean dry rag from the top when you close it can absorb moisture which works .
Rich Dubbya is offline   Reply With Quote
Old 03-26-2009, 07:01 AM   #13
DoubleBit
DoubleBit's Avatar
Oddometer: 305
I've been wondering what to do about the rust in the tank of my gn250 for quite some time. The poor lill' thing sat in a carport shaded but not sheltered from wind born rain and filth for a decade before a friend at work donated it to me. I hope to get it rolling nice and reliable as a fun little mini-chopper trainer and have done quite well detailing it, put new tires on, replacing and unsticking things. This vinegar idea is giving me some hope that the project can be finished w/o too much more cash thrown into it.
Oh, and the tank was left full according to the PO, but that fuel evaporated and corroded into some awful looking crud that boiled out with hot water and soap in chunks of gritty grimy stuff. The next phase of rinsing w/ acid removed more but it was still ugly. Over the last couple of days, I even strapped it to the mouth of a cement mixer with bits in it to "roto-scrub" the insides. Hence leading us to the next phase the vinegar.. :)
I gotta get some pix of this posted, if I can figure out how.
Current rides: DR650, CT90.
Riding whatever runs, wherever I want.
DoubleBit screwed with this post 03-26-2009 at 12:02 PM
DoubleBit is offline   Reply With Quote
Old 03-31-2009, 06:28 AM   #14
DoubleBit
DoubleBit's Avatar
Oddometer: 305
I went with distilled white vinegar (it's cheaper and has the same acid concentration), all I can say is "Wow!".. The little GNs gas tank still needs a good rinse (the small chain idea sounds good too), and it should be ready to ride again. A fuel filter/contaminant separator will also be added to be sure all is well. I hope to get pix together,, what a wonderfully cheap way to get the rust out. I was poised to bite the bullet and buy some wonder goo for roughly 100$,, how silly that would have been.
Thanks y'all for sharing the ol' skool lore.
Old 04-04-2009, 09:45 AM   #15
DoubleBit
DoubleBit's Avatar
Oddometer: 305
I can't say enough about the effectiveness of vinegar...
I have lill' GN250 that was donated to me because it was so thoroughly corroded up. I just finished cleaning out the tank last week,, vinegar ate the rust, didn't just loosen it,, destroyed it.. Two stages of quick flushing, with hot soapy water and then mineral spirits and that baby is clean.
I rode it 100+ miles yesterday to work and then the long way home,, the fuel filter shows no signs of debris.
Incredible stuff..
Times are GMT -7.   It's 12:47 PM.
