Old 03-25-2009, 08:37 PM   #16
lamoson OP
something catchier
lamoson's Avatar
Oddometer: 665
Originally Posted by gvthnks
Running it without the airbox attached won't really cause the adverse effects you're describing. It just isn't wise to run it much that way as there is nothing to filter the air and the motor can injest sand or other debris that will harm the motor.
The forward end of the carb, the side that hooks to the engine is the intake side and there should be an oring between it and the intake manifold.
ok then i guess thats not my problem. yea the oring is there.
2005 KTM 250sx......love it!!!!!!
81' Cafe project http://www.advrider.com/forums/showthread.php?t=519776
80' XL80 http://www.advrider.com/forums/showt...highlight=XL80
lamoson is offline   Reply With Quote
Old 03-26-2009, 03:10 AM   #17
dbarale
Squiddly slow
dbarale's Avatar
Oddometer: 875
Bad news, you're probably just wasting time trying to get it running properly until you can get the carb open and really clean it up, all passages, jets, etc.
Good news, you know the bike wants to run so there is hope.
dbarale is offline   Reply With Quote
Old 03-26-2009, 03:48 AM   #18
JRP
Old guy
JRP's Avatar
Oddometer: 1,361
The small screw is an air mixture adjustment for the idle circuit. The screw will come out and has an o-ring on it. You need to get it out and clean out the passage behind it.
Spray carb cleaner and air pressure should do it. 1 1/2 turns out is a good starting point. When you get it running turn the screw slowly in or out until you get the fastest smoothest idle. The larger screw can then be used to adjust idle speed.
Good luck!
"What could possibly go wrong? " The Jerk
2012 TE 250
2010 F 650 GS
1983 R 80 G/S
JRP is offline   Reply With Quote
Old 03-26-2009, 06:06 AM   #19
DoubleBit
DoubleBit's Avatar
Oddometer: 288
To answer about using ATF:
Use it now while the engine is going through all this on/off, short runs and adjustings. I'd say a few hours of running time tops, it's roughly like 5-30wt. Then go to your correct oil. Happily these lill' engines only hold about a quart and a splash, so it isn't expensive to flush 'em with a few changes.
Sounds like you got plenty of input about your carb.
Another thing these old singles seem to often need is a valve adjustment.
I'm guessing about .004", just make sure there is sufficient play for now.
Current rides.
gn250, xl175, ct70k1
gsx1100G, sold, looking for a midrange touring rig.
Letting go of pretense, I'm riding whatever runs, wherever I want.
DoubleBit is offline   Reply With Quote
Old 03-26-2009, 06:37 AM   #20
gvthnks
gvthnks's Avatar
Oddometer: 503
Even if it's there, it can still leak vacuum. Sometimes the carb body can be warped a little which can let it leak past the oring.
I agree with the other post however that suggested to really clean the carb out. Once that is done, you can diagnose and chase after other issues.
Good luck
09 Kawi KLR 650
05 Road Kind Custom
01 Suzuki DRZ-250
96 Honda Shadow
93 Honda XR 80
87 Honda XR250r
83 Honda XR350r
73 Honda XL350
73 CB750
73 Yamaha DT-1
wife calls it a sickness. I'm running a M/C rescue
gvthnks is offline   Reply With Quote
Old 03-26-2009, 06:40 AM   #21
lamoson OP
something catchier
lamoson's Avatar
Oddometer: 665
thanks guys, i will give some things a try this weekend, see if i can get this scoot dialed in. it sure is fun making it happen. one of the screws to split the carb is stripped, should i drill it out, or just try and clean it with it still together? thanks
-double bit, i dig your sig.
Old 03-26-2009, 08:26 AM   #22
gvthnks
gvthnks's Avatar
Oddometer: 503
I'm assuming you're talking about one of the screws that hold the bowl onto the carb body.
I've had good luck using vise grips to remove those screws when they're stripped or wallered out.
09 Kawi KLR 650
05 Road Kind Custom
01 Suzuki DRZ-250
96 Honda Shadow
93 Honda XR 80
87 Honda XR250r
83 Honda XR350r
73 Honda XL350
73 CB750
73 Yamaha DT-1
Old 03-26-2009, 08:31 AM   #23
lamoson OP
something catchier
lamoson's Avatar
Oddometer: 665
i will give that a whirl.
Old 03-27-2009, 03:33 PM   #24
p3ga
p3ga's Avatar
Oddometer: 798
Thumb
Yep, what he said. Vice grips are a wonderful thing. I've used "Sea Foam" with good results on old carbs. I know Advance Auto Parts (at least here in Atlanta) carries it. Just soak the carb parts overnight, then continue with carb cleaner and use compressed air to blow the remaining crap out of every orfice.
Phil
Atlanta GA
p3ga is offline   Reply With Quote
Old 03-27-2009, 03:46 PM   #25
datchew
Don't buy from Brad
datchew's Avatar
Oddometer: 7,403
solvent, grease and oil, and a rattlecan or 2 of paint and make that beast LIVE!
Cool project.
On tap:Nada
Aging: 3 experiments in mead - blackberry, apple, and straight honey
datchew is offline   Reply With Quote
Old 03-27-2009, 09:44 PM   #26
lamoson OP
something catchier
lamoson's Avatar
Oddometer: 665
so i worked on it a bit today. i changed the oil and BOY was it nasty!
i got the carb bowl off and this is what i encountered, more filth.
this is about as clean as i could get it
i put it back together, and still couldn't get it started, it just kept flooding. so i pulled it apart again. I found that the float had a small hole in it and had gas inside of it. so yea the float wouldn't float. i got the gas out and fixed the hole with some apoxy.
I tried some more with no success. inmate djmase and his engine master father came up to check it out with me. we found some things wrong with the spark and the throttle cable, sorted a bunch of stuff, and got it to run. but the idle still can't be figured right. we came to the conclusion that it probably needs a new carb.
would the new carb need to be an OEM or does it really matter. What things do i need to look for? do i need a new throttle cable and slide with it, or will the stock work?
thanks
jameson
Old 03-28-2009, 03:33 AM   #27
gvthnks
gvthnks's Avatar
Oddometer: 503
If you need a new one, for ease of replacement I would buy an identical one. They're also cheap.
I wouldn't give up on the old one quite so easily however.
Soak it in Simple Green for a few hours or get some good carb cleaner and ensure all the small passages inside the carb are clean. From the looks of that bowl, I'd suspect the rest of the carb is pretty trashed. ALL the passages have to be clean and free of debris or it won't work correctly. I'd be willing to bet that if you took the carb apart some more you would find additional problems. Jets are probably at least partially clogged.
I've never found a carb that couldn't be resurrected with some elbow grease and a couple of gaskets or seals. That is unless something is broken.
Wish I was closer. I'd help you out.
09 Kawi KLR 650
05 Road Kind Custom
01 Suzuki DRZ-250
96 Honda Shadow
93 Honda XR 80
87 Honda XR250r
83 Honda XR350r
73 Honda XL350
73 CB750
73 Yamaha DT-1
Old 04-02-2009, 08:11 AM   #28
lamoson OP
something catchier
lamoson's Avatar
Oddometer: 665
cleaned out the carb again, and did some tweaking. got it running, and kind of idling. i was able to ride it around the block, and oh yea got yelled at by that ONE OLD LADY, "your not allowed to be doing that!!!!" so that was sweet. it would do fine when i was up in 3rd and 4th gear, but when i would slow down and shift into a lower gear, it would cut out on me, i think it is still getting too much gas.
But it LIVES!!!!!!
i can try and get a vid up soon.
i will do some more fiddling, and maybe to a teardown on the engine, we will see how motivated i get.
thanks again for all your help.
Old 04-02-2009, 11:15 AM   #29
crazydrummerdude
Wacky Bongo Boy
crazydrummerdude's Avatar
Oddometer: 6,899
Send a message via AIM to crazydrummerdude
A year or two ago, I rode my XT down the road and back.
I was sitting at my shop when a cop pulled in. "We got some calls that you've been riding up and down the streets."
"Uh..."
"You can't do that."
Right....
crazydrummerdude is offline   Reply With Quote
Old 04-02-2009, 07:58 PM   #30
Putts
Gettin' there.
Putts's Avatar
Oddometer: 10,955
Well said, mate.
Have a beer.
"Origin is right here, right now," said Klay. GTomic replied, "Many myth the point."
Putts is offline   Reply With Quote
Times are GMT -7.   It's 05:13 AM.
