Old 12-29-2010, 06:41 AM   #196
ebrabaek
Oddometer: 4,758
During the CF fairing build I changed the cockpit a little...... I like this setup a lot.......
Erling
Old 01-02-2011, 04:16 AM   #197
WOLVERINE
Keep her pinned!
WOLVERINE's Avatar
Oddometer: 625
Erling
Very Nice! Looks like it belongs there..
If you think you're free, there's no chance of escape!
2008 R1200GSA
WOLVERINE is offline   Reply With Quote
Old 01-02-2011, 08:16 AM   #198
ebrabaek
Oddometer: 4,758
Thanks........ I like the "factory look" as well. What surprised me was how much difference it made by raising the whole cluster about one inch. After the rox risers was installed...... they covered the bottom part of the gps...... And by raising the whole cluster...... it became more natural for me 6`2" reading the instruments. It was moved up, and to the right...... Anyone can do this....
Here is the build.......
http://advrider.com/forums/showthread.php?t=615213
Erling
Old 01-14-2011, 02:55 PM   #199
nibo
nibo's Avatar
Oddometer: 6
original garmin's handlebar mount
only 15
nibo is offline   Reply With Quote
Old 01-14-2011, 03:49 PM   #200
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,757
only 15
Yikes, that's a recipe for disaster. And I don't see a lanyard in that shot.
Old 01-16-2011, 06:26 AM   #201
nibo
nibo's Avatar
Oddometer: 6
It works great, I use it 2 years now and never left.
And look the picture better
Old 01-29-2011, 11:08 AM   #202
TheVelourFog
Oddometer: 28
Top of the line custom GPS mount.
...this actually worked out very well.
TheVelourFog is offline   Reply With Quote
Old 01-29-2011, 05:16 PM   #203
Motorfiets
Motorfiets's Avatar
Location: North of Jack Daniel's, South of Country Music
Oddometer: 2,997
thought this was bad...
Ben
My Photo's
Motorfiets is offline   Reply With Quote
Old 02-12-2011, 05:06 PM   #204
fjk
fjk's Avatar
Oddometer: 71
Garmin GPSmap 62s in the new RAM cradle for the GPSmap 62 series.
It is attached to the left handguard bar clamp with th RAM-B-367U part. The handguards are the BMW oem ones.
fjk screwed with this post 02-12-2011 at 06:20 PM
fjk is offline   Reply With Quote
Old 02-15-2011, 02:42 PM   #205
Corona
Dreaming of Dreaming
Corona's Avatar
Oddometer: 100
fjk, how do you power the 62 when its on the bike ?
2010 BMW F800 GS
Farkles: Adv Spec Crash Bars, Adv Spec Bash Plate, Bark Busters w/ Storm Guards, CalSci Touring screen, Remus Ti exhuast
Current Tyre: Conti TK80
2005 CBR600F4i
Farkles: Hell braided brake lines
Current Tyre: Michelin Pilot Road 2
Corona is online now   Reply With Quote
Old 02-16-2011, 02:15 PM   #206
fjk
fjk's Avatar
Oddometer: 71
Well, at the moment I don't. I am waiting to see how the AA's are holding up.
Old 02-16-2011, 05:03 PM   #207
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,757
If you use AAs, you should get a couple of sets of rechargeable NiZn which will last a lot longer than any of the alternatives, especially if the weather's cold out.
Old 02-17-2011, 03:01 PM   #208
Lucifer666
Lucifer666's Avatar
Oddometer: 99
I received my Zumo 660 today from Touratech together with the lockable handlebar mounting and the conversion kit with cut-off connector.
Here are the pics:
My view on the dash, I'm 1,84 m large.
The GPS is hard wired to the battery with a fuse. On the picture below you can see the cut-off connector from touratech.
Easy to lock and unlock your GPS:
Lucifer666 is offline   Reply With Quote
Old 02-18-2011, 03:17 AM   #209
AlanI
Oddometer: 201
More or less the same set-up as mine other than I have the TT lockable mount fixed to a centre bar. One thing you might find though is that located in that position the screen glare on a sunny day makes it almost impossible to see. If you find this to be the case then something like a Glare Stomper http://www.glarestomper.com/ comes in pretty useful and, whilst a tight squeeze, will fit into the Garmin case with it still attached to the unit.
AlanI is offline   Reply With Quote
Old 03-05-2011, 02:05 PM   #210
Baiazid
Baiazid's Avatar
Oddometer: 176
Got a 62s :)
I had a Zumo 550 and I sold it because I need to see the trailroads also. Zumo can plot routes and navigate only on roads.
For this purpose I bought a garmin gpsmap 62s. It's amazing.
Baiazid is offline   Reply With Quote
Times are GMT -7.   It's 03:39 AM.
