Old 06-12-2009, 07:50 AM   #61
Lost Rider
Unsubscribed.
Lost Rider's Avatar
Oddometer: 3,263
Updated Setup.
I'm using the Garmin marine mount to hold the GPSMAP 478, bolted to an aluminum plate, mounted to my quick release top box. The whole setup comes off very easy and I never have to unplug anything from the Garmin, instead a military grade waterproof connector is used on the box to supply power, and the audio comes out the front with a panel mount 1/8th jack.
Lost Rider is offline   Reply With Quote
Old 06-12-2009, 08:36 AM   #62
The Griz
North Forest Rider
The Griz's Avatar
Oddometer: 3,787
Anyone use the Garmin Nuvi 550 Waterproof? I'm interested in this one mainly because it's $260. And Touratech makes a lockable MvG mount for it.
Old 06-12-2009, 09:51 AM   #63
WoodWorks
House Ape
WoodWorks's Avatar
Oddometer: 2,204
That's quite a setup there, ChiTown. Does the position of top box interfere with your standing on the pegs at all?
Looks like that LX3 is well-protected in there. I'm having a blast with mine.
David
David
I'm tryin' ta think, but nuttin' happens!
--Curly
WoodWorks is offline   Reply With Quote
Old 06-12-2009, 02:19 PM   #64
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,850
Garmin 60CSx RAM Mount Power Cable Holder
I use a Garmin GPSMap 60CSx and the only thing I don't like about it is the fact that the power cable has nothing holding it in. It falls out often.
This is what the back of the gps looks like, in the RAM mount:
This is not helped by the pFranc power cable I made up, but I like the setup so I gave a little thought to the idea of keeping the cable in and came up with this:
This is just a flat piece of plexiglass which I cut up and is now sandwiched between the RAM diamond mount and the RAM gps holder, and which keeps the power cable from coming out unless I remove the gps from the RAM mount.
That should be the end of that problem, I hope.
Old 06-12-2009, 02:42 PM   #65
dukedar
60 easy payments!
dukedar's Avatar
Oddometer: 340
Griz,
Let us know what you find out on the nuvi 550. I am looking at that one real hard as well.
The Zumo 550 is too rich for me, and I do not need or want Bluetooth, XM, or Text to Speech. The Zumo 450 might be a contender, but it is discontinued, and only available on eBay now as a refurb.
Darren
'09 BMW F800GS
dukedar is offline   Reply With Quote
Old 06-12-2009, 07:24 PM   #66
Lost Rider
Unsubscribed.
Lost Rider's Avatar
Oddometer: 3,263
David
Negative, it's not in the way at all, I can see all the gauges too.
Old 06-13-2009, 06:17 AM   #67
JRWooden
Oddometer: 4,294
Originally Posted by dukedar
Griz,
I'm using the Nuvi 500 (same as 550 but with different maps, the 500 has topo.) I have seem them for as little as $225 USD.
I have it mounted like this ...
http://www.advrider.com/forums/showt...08#post9047608
Due to it NOT being wide screen it fits in very nicely in the space between the windscreen and the instruments. It does not have Bluetooth or XM, does do basic text-to-speech (no street names).
I initially had a cheaper one (Nuvi 265) but found out that the cheaper ones do not allow a custom route (they allow waypoints but you can't pick the ROADS so ... that caused me to upgrade).
Being waterproof, having a swappable battery (advertised to last 8 hrs), and the topo maps - I use it for hiking and camping also made it not hurt so much on the wallet. Bluetooth would have been nice as I could see WHO was calling during a ride and then decide wether to pull over and talk or roll on the gas but I can live without it...
The new units are small enought to fit in a pocket, so I decided not to worry about a locking mount... one more key to dick with ... that I could loose....
Old 06-13-2009, 11:01 AM   #68
Lindeberg
Lindeberg's Avatar
Oddometer: 88
Where can I find a modestly priced power cable which fits between my 800GS and my Garmin 60CSx? Preferrabily a short one.
Rock 'n roll roadster ('11 BMW R1200R)
Lindeberg is offline   Reply With Quote
Old 06-13-2009, 03:13 PM   #69
dukedar
60 easy payments!
dukedar's Avatar
Oddometer: 340
There is a good How-To on the F800 Rider's forum on making a GPS cable:
http://f800riders.org/HoW/showentry.php?e=29&catid=6
I am currently looking hard at a nuvi 550, and I plan on going this route. I will gt a moderately priced 12v car cable, and cut the end off to splice in the BMW connector like in the How-To
Darren
'09 BMW F800GS
Old 06-22-2009, 02:56 PM   #70
RobTheRigger
Thread Killer
RobTheRigger's Avatar
Oddometer: 673
Since I financed my bike, I said "Screw it." and got the Nav III, which is wired into the CANbus plug. I want to be able to use my eTrex as a backup, or if I want to let the wife use the Nav in the car. I found a car charger with a USB for a blue-tooth earpiece. I just wired a cigarette plug into the bike via an AP-1 and "Voila!" USB power!
Rob
I can imagine a no more rewarding career. And any man who may be asked in this century what he did to make his life worthwhile, I think can respond with a good deal of pride and satisfaction: "I served in the United States Navy." JFK
"I rode a lot of dirt bikes when I was younger, so I trust the chain and sprockets more than that newfangled voodoo shaft stuff!" DolphinJohn
RobTheRigger is offline   Reply With Quote
Old 06-22-2009, 03:58 PM   #71
Capt.Jim
b00b
Capt.Jim's Avatar
Oddometer: 20
Not sure that this is modestly priced ($32.95 USD) but its exactly what your looking for. I just received one for my setup.
Available from Powerlet. You can also get the empty Powerlet end to use for your own cables. Here is a link:
http://www.powerletproducts.com/shop...t-cable/236/23
jim
Capt.Jim is offline   Reply With Quote
Old 06-23-2009, 03:05 AM   #72
Lindeberg
Lindeberg's Avatar
Oddometer: 88
Thank you for that.
Old 06-23-2009, 08:18 AM   #73
innovathinker
innovathinker's Avatar
Oddometer: 34
Just what I was looking for!
My Silly Little Website: http://www.gsriders.us
innovathinker is offline   Reply With Quote
Old 06-23-2009, 11:16 AM   #74
LewisNClark
LewisNClark's Avatar
Oddometer: 1,062
GPS mounted with a Pelican Box
Can't justify a separate GPS in 4 different vehicles. So my solution was a Pelican box mounted across the middle of the handle bar with two U-bolts. Pelican box was $15 on eBay (wallyworld has a one for $10.) My Magellan 5310 has a 5 1/2 inch screen and the volume can be so loud I can easily hear the street by street directions without a headset. Box does not effect view of speed-0 or OBC. I never change a GPS while riding so opening and closing the waterproof Pelican is very easy. box also works well for I-Pod and Radio.
LewisNClark is offline   Reply With Quote
Old 06-24-2009, 11:25 AM   #75
dukedar
60 easy payments!
dukedar's Avatar
Oddometer: 340
Originally Posted by CrazyMike
I've got this setup with a Zumo. It does partially block the tach. I just flipped the brackets and now the bar is on the bottom. It doesn't block anymore. Good to go .
Any pics of your setup? Are you using the TT Cradle also?
Darren
'09 BMW F800GS
Times are GMT -7.   It's 12:32 PM.
