Go Back   ADVrider > Riding > Regional forums > Tejas and the Gulf States
Old 10-11-2012, 12:07 PM   #54061
joenuclear
Planning.....
joenuclear's Avatar
Oddometer: 5,242
Originally Posted by sc-razor View Post
That's some awesome seamstress work!
She's looking for her tits.
Ride safe enough....
joenuclear is offline   Reply With Quote
Old 10-11-2012, 01:24 PM   #54062
sc-razor
sc-razor's Avatar
Oddometer: 3,436
2009 XR650L
Steve
sc-razor is online now   Reply With Quote
Old 10-11-2012, 02:33 PM   #54063
wayno
wayno's Avatar
Oddometer: 4,811
You know we would all help her find them!
RIDE SAFE
wayno is offline   Reply With Quote
Old 10-11-2012, 03:23 PM   #54064
DrLewall
DrLewall's Avatar
Oddometer: 23,824
BS! We'd all be tripping over them!
DrLewall is offline   Reply With Quote
Old 10-11-2012, 03:39 PM   #54065
wayno
wayno's Avatar
Oddometer: 4,811
RIDE SAFE
Old 10-11-2012, 06:07 PM   #54066
DrLewall
DrLewall's Avatar
Oddometer: 23,824
Old 10-11-2012, 06:32 PM   #54067
DRZ Charlie
Old & beat up
DRZ Charlie's Avatar
Oddometer: 11,079
I need clutch advice.
I replaced the aftermarket clutch perch and lever with an OEM clutch perch and lever because I keep breaking clutch cables. The clutch was working perfectly but it is at a slight angle which may contribute to stress on the cable.
When doing this I used the same cable that was on the aftermarket perch (and working) but after the replacement, the clutch actuator won't disengage the gearing.
I thought the clutch plates were wet locked so I lowered the bike and started it in neutral and pulled the clutch lever in and clicked it into gear and the bike died.
I did this three times and adjusted the lever from loose to tight and got the same result. Figuring that there was slightly better pull on the after market perch I put it back on and got the same result.
The manual states the the clutch actuator post should be rotated counter clockwise toward the engaged position (towards the center of the motor). It is positioned as indicated.
What am I missing here? The only other thing I can think of is the clutch actuator fork has somehow become fouled up. Thoughts?
Ride, Crash, Visit the ER, Get a splint, Recuperate, Assess your mistakes, Repair Motorcycle, Gather courage to ride again, Ride, Rinse & Repeat
My SPOT - No tracks = not riding | Mapsource Tutorial | Rides
DRZ Charlie screwed with this post 10-11-2012 at 06:38 PM
DRZ Charlie is online now   Reply With Quote
Old 10-11-2012, 06:50 PM   #54068
joenuclear
Planning.....
joenuclear's Avatar
Oddometer: 5,242
Hve you checked the stator?
Old 10-11-2012, 07:02 PM   #54069
BIGASSDIRTRIDER100
BIGASSDIRTRIDER100's Avatar
Oddometer: 111
Yes it could now who do we know that knows Stator's
If loud pipes save lives what will knowing how to ride do for you?
BIGASSDIRTRIDER100 is online now   Reply With Quote
Old 10-11-2012, 07:34 PM   #54070
Vinduroman
Vinduroman's Avatar
Oddometer: 541
Charlie:
Is the clutch hard to pull at the handlebar lever? Or, is it very easy to pull it in?
V-man
1969 - 2012: 43 Years Of Riding And Still Counting!
Vinduroman is offline   Reply With Quote
Old 10-11-2012, 07:53 PM   #54071
mdawg12
Old and Slow
mdawg12's Avatar
Oddometer: 509
It was probably the guy that tighten the bolts holding the cable guide when the cable broke on the trail. Everyone knows how those engineers can screw up anything they touch.
‎"May your trails be crooked, winding, lonesome, dangerous, leading to the most amazing view. May your mountains rise into and above the clouds. May your rivers flow without end."
- Edward Abbey (1927-1989), American author, from "Desert Solitaire" (1968)
mdawg12 is offline   Reply With Quote
Old 10-11-2012, 08:05 PM   #54072
mouthfulloflake
Not afraid
mouthfulloflake's Avatar
Oddometer: 11,243
charlie, was your basket in good shape when you replaced the frictions and steels? ( the fingers smooth, no notches, or burrs?)
ive done alot of adjusting on the dr350 clutch too,( broken a few perches, and handles...) and its a very precise thing to get it right in the 'zone' where it will engage and hold, and disengage and release.
"A little inaccuracy sometimes saves a ton of explanation."
- H. H. Munro (Saki) (1870-1916)
mouthfulloflake is offline   Reply With Quote
Old 10-11-2012, 08:08 PM   #54073
DRZ Charlie
Old & beat up
Oddometer: 11,079
Nah, that works fine. The engineer knew his stuff.
Old 10-11-2012, 08:09 PM   #54074
DRZ Charlie
Old & beat up
Oddometer: 11,079
Didn't replace the internals just the clutch perch the engine only has about 2800 miles on it now.
Old 10-11-2012, 08:11 PM   #54075
mouthfulloflake
Not afraid
Oddometer: 11,243
that right fresh replacement engine... I forgot that.
its just tight man.
rock it back and forth, get it into neutral, crank it, let the engine and oil warm up, kill it, and then try adjusting the cable.
Originally Posted by DRZ Charlie View Post
Didn't replace the internals just the clutch perch.
Times are GMT -7.   It's 08:33 PM.
