Go Back   ADVrider > Riding > Regional forums > Tejas and the Gulf States
Old 10-11-2012, 08:17 PM   #54076
TRZ Charlie
That's MR. Asshole
TRZ Charlie's Avatar
Oddometer: 15,980
Originally Posted by Vinduroman View Post
Charlie:
Is the clutch hard to pull at the handlebar lever? Or, is it very easy to pull it in?
V-man
It's got some resistance as it should. The manual says 2-3 mm of pull where the clutch actuator lever attaches to the cable and that checks out too.
My SPOT - No tracks = not riding | Husky TR650 Thread Index | Husky TR650 OEM and Interchangeable Parts List | Cheap Beer & Tenderloins | "You know your getting old when a bad hair day includes your nose, eyebrows and ears" - Inmate - advNZer?
TRZ Charlie is online now   Reply With Quote
Old 10-11-2012, 08:23 PM   #54077
Vinduroman
Vinduroman's Avatar
Oddometer: 586
Okay. Was wondering if you have a tight curve/bend in the cable routing under the tank or somewhere that was increasing the load on the cable.
Is the end of the cable pulling off... or the cable itself breaking? If breaking, is it breaking near the handlebar lever... or down at the actuating arm at the cases?
Were the ones breaking OEM cables?
V-man
1969 - 2012: 43 Years Of Riding And Still Counting!
Vinduroman is offline   Reply With Quote
Old 10-11-2012, 08:27 PM   #54078
TRZ Charlie
That's MR. Asshole
Oddometer: 15,980
V-man
Breaking at the lever. The aftermarket lever was at a strange angle.
OEM cables and aftermarket cables.
Old 10-11-2012, 08:35 PM   #54079
mouthfulloflake
Not afraid
mouthfulloflake's Avatar
Oddometer: 17,494
probably time to take that clutch cover off for a look then Charlie.
should be able to save the gasket if you are careful, or even better if mama zuki has gone to an O ring there.....
Smoke em if you got em, and drink your glasses to the bottom...-Will Whitmore
Charter member: T.O. club.
mouthfulloflake is offline   Reply With Quote
Old 10-11-2012, 08:47 PM   #54080
TRZ Charlie
That's MR. Asshole
Oddometer: 15,980
I'm going to try to disengage it again tomorrow. When I tried to break it loose this evening I didn't have enough weight on the rear tire. I gotta think it is wet locked.
Old 10-11-2012, 09:41 PM   #54081
scotty69
scotty69's Avatar
Oddometer: 903
Good luck Charlie, I wish I knew enough about that to help.
Orchestrated Chaos
arkansas500.com
scotty69 is offline   Reply With Quote
Old 10-11-2012, 09:44 PM   #54082
ozarkrider
Discombobulated Sociopath
ozarkrider's Avatar
Oddometer: 5,628
You've gotta adjust the clutch at the hub first. The adjustment at the cable is for just the cable. Gimme a call and I can walk ya through it.
Originally Posted by DRZ Charlie View Post
I need clutch advice.
I replaced the aftermarket clutch perch and lever with an OEM clutch perch and lever because I keep breaking clutch cables. The clutch was working perfectly but it is at a slight angle which may contribute to stress on the cable.
When doing this I used the same cable that was on the aftermarket perch (and working) but after the replacement, the clutch actuator won't disengage the gearing.
I thought the clutch plates were wet locked so I lowered the bike and started it in neutral and pulled the clutch lever in and clicked it into gear and the bike died.
I did this three times and adjusted the lever from loose to tight and got the same result. Figuring that there was slightly better pull on the after market perch I put it back on and got the same result.
The manual states the the clutch actuator post should be rotated counter clockwise toward the engaged position (towards the center of the motor). It is positioned as indicated.
What am I missing here? The only other thing I can think of is the clutch actuator fork has somehow become fouled up. Thoughts?
O'Jay
I'm not weird, I'm Limited Edition!
Life is a sexually transmitted disease and the mortality rate is 100%
ozarkrider is offline   Reply With Quote
Old 10-11-2012, 09:45 PM   #54083
joenuclear
Planning.....
joenuclear's Avatar
Oddometer: 6,355
I've paid extra to be wet locked! just sayin.....
joenuclear is online now   Reply With Quote
Old 10-11-2012, 09:47 PM   #54084
ozarkrider
ozarkrider's Avatar
Oddometer: 5,628
I can't say it, just can't say it.
O'Jay
Old 10-11-2012, 09:50 PM   #54085
scotty69
scotty69's Avatar
Oddometer: 903
Orchestrated Chaos
arkansas500.com
Old 10-11-2012, 10:16 PM   #54086
TRZ Charlie
That's MR. Asshole
Oddometer: 15,980
I'm gonna put the bike back down on the ground and sit on it and try engaging it. If my weight isn't enough to break the discs from the wet lock I'm calling Joe.
Old 10-11-2012, 10:22 PM   #54087
joenuclear
Planning.....
joenuclear's Avatar
Oddometer: 6,355
Too late, I'm calling you.
Old 10-12-2012, 03:35 AM   #54088
DrLewall
The Human GPS
DrLewall's Avatar
Oddometer: 33,699
mornin fellers
load that bike on the trailer and haul it out to the shop..we'll get your tire swapped out and Doctor on your clutch some (coy will be there too! )
DrLewall is offline   Reply With Quote
Old 10-12-2012, 05:39 AM   #54089
TRZ Charlie
That's MR. Asshole
Oddometer: 15,980
I can't get up Travis' drive with the trailer in the mud with my baby truck
Charlie
Old 10-12-2012, 06:25 AM   #54090
Valentino Magoo
Like a speeding slug
Valentino Magoo's Avatar
Oddometer: 3,226
Looks like we may get a little rain!
I am stuck home with a stomach bug. Sucks.
Chuck, I'd ring O'Jay. Seems unlikely you got something going on internally after just changing out the perch.
Occams Razor: simple explanations most often the correct ones.
It's hard to kidnap fat people -- brother Steve
12 WR 250R, 11 Burgman 650, 00 HD softtail
Charter Member: T.O. Club | You can follow My Spot | Last Ride: 2014 3 Hogs Root in the WyCoUt
SmugMug Rocks!
Valentino Magoo is offline   Reply With Quote
Times are GMT -7.   It's 09:14 PM.
