Go Back   ADVrider > Riding > Regional forums > Tejas and the Gulf States
Old 11-09-2012, 12:35 PM   #54991
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 4,811
Originally Posted by joenuclear View Post
Bout time some of YFF's got out bed and started ADVenturing.... or working as the case may be.
Hey Chuck, Hey Albie! It a couple of weeks I too shall be unemployed, or retired depending on your point of view.
Congrats!!
Guess what doofus, nobody reads your lame blog.
Old 11-09-2012, 12:39 PM   #54992
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 4,811
Originally Posted by terrascout View Post
Ok, Ted and others after this mornings ride in I need some advice.
How do I keep myself from over reacting and or just forcing the bike further over in extreme braking in a corner?
I have been doning fairly well lately with this, hit a bit of gravel on the street mid corner and just let it slide a bit and not grab brake. However this morning I had two instances.
1.) accelerating hard coming up a hill and through a corner I run everyday on the way to work. Hit some gravel and I immedieately grab a bit of brake and let the bike straighten up enough to almost not make the rest of the corner on the pavement. Ted think of my crazy movements two years ago in CO. You know after most of the morning following Advhawg through some easy corner. I hit one at mod speed and just did the freak you saw in the mirror, or was I in front of you.
2.) Decide I need more practice after 1 so took an alternate rd with more curve on the way in. First couple fine then passed a jeep when I had the opportunity which lead me into triples as I went into the right hand corner. Well as I hit the appex I can see a friendly County PO sitting in the ditch in the right hand ditch just beyond the end on the curve.
Well I grabbed a lot of break to get it down to 55 in a 45 as I went by the nice PO again resulting in me scooting just over the center line just beyon mid corner.
Thoughts, advice beyond the common sense slow you arse down? Just concentrate on pushing the inside of the handle bar forward and down a bit harder?
Thanks,
The nut connecting the handlebars to the seat.
Couple things that will help a lot is to weight the inside peg and look through the turn.
Old 11-09-2012, 12:41 PM   #54993
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 4,811
Originally Posted by Valentino Magoo View Post
What is all this talk about leaning in corners?
Magoo.
It's how bikes TURN.
Old 11-09-2012, 12:45 PM   #54994
Valentino Magoo
Like a speeding slug
Valentino Magoo's Avatar
Oddometer: 1,724
Not at my speed
12 WR 250R
05 Burgman 650
00 HD softtail
Valentino Magoo is online now   Reply With Quote
Old 11-09-2012, 02:57 PM   #54995
DRZ Charlie
Old & beat up
DRZ Charlie's Avatar
Oddometer: 11,073
At your speed there needs to be a "third" wheel.
Ride, Crash, Visit the ER, Get a splint, Recuperate, Assess your mistakes, Repair Motorcycle, Gather courage to ride again, Ride, Rinse & Repeat
My SPOT - No tracks = not riding | Mapsource Tutorial | Rides
DRZ Charlie is offline   Reply With Quote
Old 11-09-2012, 03:05 PM   #54996
ozarkrider
Discombobulated Sociopath
ozarkrider's Avatar
Oddometer: 4,064
If you remember "Laugh-In" the three wheeler fell over a lot.
O'Jay
I'm not weird, I'm Limited Edition!
Life is a sexually transmitted disease and the mortality rate is 100%
ozarkrider is offline   Reply With Quote
Old 11-09-2012, 03:05 PM   #54997
terrascout
Oddometer: 1,352
Thanks Ted and Albie.
Oh, and the rest of ya all too.
It wasn't like I was taking any of these corners faster then the bike of I could handle safely.
It was just how do you work at keeping it leaned in when you do let you mind wander, Doh keep your mind on the road. Or need rapid controlled decrease of speed while in a corner do to a sudden PO, deer, boobs, or great ass appearing within your field of view. Oh wait those last two usually happen on campus and I ride around there extra slow just for a chance at such views.
terrascout is offline   Reply With Quote
Old 11-09-2012, 03:11 PM   #54998
terrascout
Oddometer: 1,352
Has anyone tried out the new Asian eatery in Farmington, right across from Arvest bank? Was thinking I need to try it out. But if someone has experienced it they can share info. It may save me from some really bad starchy food or get my behind in there quicker to try it out.
Thanks,
Old 11-09-2012, 03:27 PM   #54999
DrLewall
DrLewall's Avatar
Oddometer: 23,773
At 4:30 this afternoon, I got to drive my jeep again!
here is the busted mount
here it is fixt!
thanks guys for helping when you could..it really helped me alot!
DrLewall is offline   Reply With Quote
Old 11-09-2012, 03:29 PM   #55000
mouthfulloflake
Not afraid
mouthfulloflake's Avatar
Oddometer: 11,221
Hey guys need some advice here
Need to press a bearing off and back on an axle shaft
Last time 18 years ago I used mesplays machine shop in fayetteville
Need an arbor press and plates basically
Any ideas?
"A little inaccuracy sometimes saves a ton of explanation."
- H. H. Munro (Saki) (1870-1916)
mouthfulloflake is offline   Reply With Quote
Old 11-09-2012, 03:32 PM   #55001
DRZ Charlie
Old & beat up
Oddometer: 11,073
Ya gotta love Artie Johnson..
Old 11-09-2012, 03:34 PM   #55002
DRZ Charlie
Old & beat up
Oddometer: 11,073
Doc, glad you have a four wheel conveyance again.
Old 11-09-2012, 03:34 PM   #55003
DRZ Charlie
Old & beat up
Oddometer: 11,073
Any ideas?
Maybe you could talk Doc into ......never mind
Old 11-09-2012, 03:43 PM   #55004
DrLewall
DrLewall's Avatar
Oddometer: 23,773
Originally Posted by drz charlie View Post
maybe you could talk doc into ......fucking it up
fixt!
Old 11-09-2012, 03:47 PM   #55005
tokyoklahoma
Oddometer: 754
Thumb Push!
When I first started riding again, I had a couple of instances, just like what you described.
I "knew" what I was supposed to do, but my mind was second-guessing and over-thinking.
Entering our neighborhood from hwy 59 the road drops dramatically into a hollow and back up the other side. Leaning into the corner and having the pavement "drop" from under me "got in my head". It did this the first time I turned in from the right and the left.
Both times I literally yelled "PUSH!" in my helmet.
It sounds stupid, but it made me do what needed done, instead of second-guessing myself into the ditch.
Now that turn is just a fun sensation at the end of a ride.
tokyoklahoma is offline   Reply With Quote
Times are GMT -7.   It's 07:55 PM.
