Go Back   ADVrider > Riding > Regional forums > Tejas and the Gulf States
Old 03-15-2013, 07:46 PM   #62176
DrLewall
The Human GPS
DrLewall's Avatar
Oddometer: 32,861
Originally Posted by Elvis70 View Post
Howdy folks.
So is S.L.A.P. happening or what?
Was talking to one of our managers and he is riding his Moto Guzzi to the Mount Nebo ride, I told him to look on here for S.L.A.P. since he also has a KLR.
try to keep up there Hoss!
DrLewall is offline   Reply With Quote
Old 03-15-2013, 08:13 PM   #62177
jtwest
Redneck Adventererer
jtwest's Avatar
Oddometer: 2,785
Originally Posted by Scribe View Post
Swamped at work (sucks) so I shan't be camping tomorrow. Who's still around and wants to ride?
I'm still around...would be up for a ride...bike is takin apart for repairs but nothing that prevents riding can get back on the road by noonish saturday....let me know
jtwest is offline   Reply With Quote
Old 03-15-2013, 08:18 PM   #62178
jtwest
jtwest's Avatar
Oddometer: 2,785
just pickin some brains...especially maybe charlie...(if hes around)
radiator fan hasnt worked since I got the KLR...started tracing...fan works, relay works, temp sensor works..cannot short the relay to get the fan working...I checked voltage going into the relay; nada....
Checked all fuses I could find; all good..break in the wire somewhere I suppose..
any other ideas?
Old 03-15-2013, 08:33 PM   #62179
DrLewall
The Human GPS
DrLewall's Avatar
Oddometer: 32,861
any other ideas?
needs a new stator! asking charlie is the right thing to do too!
Old 03-15-2013, 08:33 PM   #62180
Arkmozark
M.C.
Arkmozark's Avatar
Oddometer: 95
any other ideas?
This might help.
http://www.advrider.com/forums/showthread.php?t=451043
Marlin
Arkmozark screwed with this post 03-15-2013 at 08:42 PM
Arkmozark is offline   Reply With Quote
Old 03-15-2013, 08:44 PM   #62181
jtwest
jtwest's Avatar
Oddometer: 2,785
Originally Posted by Arkmozark View Post
This might help.
AHA!!!! thats exactly what I needed...I need to find that ten amp fuse...that wire is the only break and I dont think I found that fuse
Where would it be???At leaast I have something to look for...
Thanks man...you rock!!!
Old 03-15-2013, 09:23 PM   #62182
Scribe
£Bob£
Scribe's Avatar
Oddometer: 7,186
Will do. Should be nice tomorrow.
"Do or do not. There is no 'try.'"
— Yoda
Man Ball Rolls Through Coloutahrado 2014!
Scribe is offline   Reply With Quote
Old 03-16-2013, 12:15 AM   #62183
TRZ Charlie
That's MR. Asshole
TRZ Charlie's Avatar
Oddometer: 15,595
I'd check the continuity of the ground wire from the battery to the fan and also the positive wire but take the positive loose from the battery for both tests. If it is open (no reading on the ohms setting on your meter) on either lead you have a bad fuse, broken wire, an OEM plug is intermittent or the fan switch is bad.
After testing the wiring for continuity continue on to the switch. It should be normally open (no ohms reading on the multimeter) when cold. To test it You can unscrew it and heat the element (not the whole switch) in boiling water while monitoring the switch with your multimeter set to ohms, it doesnt matter which lead is attached to what wire because you are looking for a short or closed switch condition.
Heat some water to boiling. and place the sensing element in the water.
When the switch heats sufficiently (boiling 212 degrees) it should close and show a closed circuit (dead short in ohms).
My SPOT - No tracks = not riding | Husky TR650 Thread Index | Husky TR650 OEM and Interchangeable Parts List | Cheap Beer & Tenderloins | "You know your getting old when a bad hair day includes your nose, eyebrows and ears" - Inmate - advNZer?
TRZ Charlie is online now   Reply With Quote
Old 03-16-2013, 12:41 AM   #62184
TRZ Charlie
That's MR. Asshole
Oddometer: 15,595
G'nite John Boy, and somebody get the lights.
Old 03-16-2013, 05:27 AM   #62185
DrLewall
The Human GPS
DrLewall's Avatar
Oddometer: 32,861
mornin fellers
Old 03-16-2013, 05:34 AM   #62186
mattmus4357
Oddometer: 667
http://youtu.be/J0j3-tmQLjg
mattmus4357 is offline   Reply With Quote
Old 03-16-2013, 05:36 AM   #62187
mattmus4357
Oddometer: 667
Baseball tickets
Anybody have an extra razorback baseball ticket for today? I've got 3 but the girlfriend's 'rents are in town.
Old 03-16-2013, 06:11 AM   #62188
TRZ Charlie
That's MR. Asshole
Oddometer: 15,595
You easily pick one up outside the stadium.
Old 03-16-2013, 06:19 AM   #62189
mattmus4357
Oddometer: 667
That's what usually ends up happening. I just like to try and get them before showing up to the game.
Old 03-16-2013, 06:24 AM   #62190
DrLewall
The Human GPS
DrLewall's Avatar
Oddometer: 32,861
you're up? wtf?
Times are GMT -7.   It's 09:26 PM.
