Go Back   ADVrider > Riding > Regional forums > Tejas and the Gulf States
Old 04-12-2013, 02:57 PM   #63721
mouthfulloflake
Not afraid
mouthfulloflake's Avatar
Oddometer: 17,384
If you need help with the garage door spring let me know JD.
ive messed with them a little bit, even made me some tools to make it less scary.
Smoke em if you got em, and drink your glasses to the bottom...-Will Whitmore
Charter member: T.O. club.
mouthfulloflake is offline   Reply With Quote
Old 04-12-2013, 03:02 PM   #63722
sc-razor
sc-razor's Avatar
Oddometer: 3,776
Originally Posted by JaiDee View Post
If you need to find that broken "whatever" just let me know. Today was the day for that.
Went to drive somewhere...the garage door doesn't go up. Close look = broken torsion spring. Part found online and ordered...ka ching. $$$$
Took the mower housing off the rider. Found a nearly broken drive belt. Found parts online and ordered...ka ching $$$$
Went to put blades that I sharpened back on the mower...found a broken mandrel housing. Parts found online and ordered...ka ching. $$$$
Went to turn on lights in shop. Nope. Found a broken switch. Fortunately, I had a few extras left over from remodeling.
Fortunately, when the lights didn't go on in the shop I failed to go inspect the bike. Otherwise, I have no doubt I would have found something broken on Ole Blue.
To prevent further problems I went to the frige, grabbed a couple of beers and locked myself in the office. Popped tops and Jeff Beck turned up high have prevented further challenges.
But if you need something bad found...just call.
-JD
Good choice on the music
2009 XR650L
2009 KTM 300XC-W
Steve
sc-razor is offline   Reply With Quote
Old 04-12-2013, 03:13 PM   #63723
JaiDee
Petrolhead
JaiDee's Avatar
Oddometer: 2,629
Thanks for all the sympathy guys! Yeah right. Y'all just want to come over and drink beerz. Can't blame you, but.....
Seriously, thanks! When I get the spring Matt I may have you help me with it. Sounds like it can be a SOB to get it wound up, adjusted and tightened unless you're an octopus.
And by the way, you're all welcome to come over and help me raid the garage refrigerator any time.
-JD
Two roads diverged in a wood, and I
I took the one less traveled by,
And that has made all the difference.
- Robert Frost
"Charter Member of the T.O. Club" '08 WR250R, '05 F650GS Dakar
JaiDee is offline   Reply With Quote
Old 04-12-2013, 03:15 PM   #63724
JaiDee
Petrolhead
JaiDee's Avatar
Oddometer: 2,629
Moved on to Joe Henry now for a bit more funk. I'm less apt to throw things when he's on.
-JD
- Robert Frost
Old 04-12-2013, 05:03 PM   #63725
k1w1t1m
Kiwi
Oddometer: 917
-JD
Use a long extension from a socket set to tension the spring. A small crescent wrench works for the grub screw. Adjust the spring until the door is nearly weightless when closed.
It's all for Jesus, CMA Faith Riders, Chapter 732
'01 BMW R1150GS
k1w1t1m is offline   Reply With Quote
Old 04-12-2013, 05:08 PM   #63726
mouthfulloflake
Not afraid
Oddometer: 17,384
I prefer an open/box end 7/16" so I dont have to fiddle with the adjustment on the grub screws.
and you will need 2 of the extensions to wind it down safely.
I cut some round stock a long time ago, slightly under .500" dia
they fit better than a socket extension, and they are about 20 " long so you get good leverage.
makes it a less scary process.
Old 04-12-2013, 06:01 PM   #63727
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,649
-JD
I just call the landlady.
Old 04-12-2013, 07:37 PM   #63728
JaiDee
Petrolhead
JaiDee's Avatar
Oddometer: 2,629
Many thanks Kiwi and Mouth. Sounds like you guys have replaced those stupid springs a time or three. I appreciate the advice, especially when Mouth comes over and shows me how.
Albie...why are you letting your landlady wind your spring? ...or replace your belt? ...or play with your housing? ...or flip your switch to turn you on?
Lions and tigers and bears...OH MY!!!
-JD
- Robert Frost
Old 04-13-2013, 02:12 AM   #63729
DrLewall
The Human GPS
DrLewall's Avatar
Oddometer: 33,474
-JD
Albie is so pampered!
DrLewall is online now   Reply With Quote
Old 04-13-2013, 02:49 AM   #63730
arraflipper
Oddometer: 462
Garage springs
If you have two springs you will have to unwind the old before you can remove it. Put a line across it while wound, chalk line or grease pencil mark. Then when you rewind it the line will be there to let you know you have it wound the correct number of turns. A lot of new springs have a line on then, so you can count the number of turns when you wind them. Make sure you don't reverse the way the shaft came off the door. If reversed you can have the spring come off the winding nut. You need to clamp the shaft so it doesn't turn when you are winding and while you tighten the set screws. Another clamp to keep the door from raising before you are done. Might want to stay away from the beer till you are done and watching it go up and down again.
arraflipper is offline   Reply With Quote
Old 04-13-2013, 03:56 AM   #63731
DrLewall
The Human GPS
DrLewall's Avatar
Oddometer: 33,474
here ya go JD
Old 04-13-2013, 04:52 AM   #63732
JaiDee
Petrolhead
JaiDee's Avatar
Oddometer: 2,629
I'll be standing next to the refrigerator videoing Mouth just in case anything exciting happens. I figure with the right video and number of hits on YouTube this could end up being a profitable venture.
Thanks for the advice on marking the spring & # of turns winding.
-JD
- Robert Frost
Old 04-13-2013, 04:53 AM   #63733
JaiDee
Petrolhead
JaiDee's Avatar
Oddometer: 2,629
Originally Posted by DrLewall View Post
here ya go JD
Thanks Doc!
-JD
- Robert Frost
Old 04-13-2013, 05:08 AM   #63734
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,649
-JD
You know you're jealous.
Old 04-13-2013, 05:10 AM   #63735
ozarkrider
Discombobulated Sociopath
ozarkrider's Avatar
Oddometer: 5,628
Boy oh Boy
It's a purty day outside. Time to saddle up the PandaBike and go stack on some miles.
Who wants to me in ES for lunch?
O'Jay
I'm not weird, I'm Limited Edition!
Life is a sexually transmitted disease and the mortality rate is 100%
ozarkrider is offline   Reply With Quote
Times are GMT -7.   It's 10:40 AM.
